Darn thing includes 2 "D" batteries, that alone has to be worth $2.
Thanks for posting this deal. I thought it was over but I got 2 with Prime shipping. I will get a few of these so I can use AA with it.
Awesome deal, thanks...I snagged two...that and a case of Hamburger Helper and hey, free shipping!
For those who missed it yesterday, it's back @ $6+change again. The price fluctuates between $22 and $6 throughout the day.
if someone gets theres, I'd love to hear about it, ie can it be disassembled and does it have any sort of, or a decent, pill
Also have 2 coming tomorrow. Thanks.
Is that CPF review for members only? Any other review with some beamshots?
Welcome to the site, REVENGE.
I got mine today and ordered another . It's a great light for the money, but I do get free shipping so that makes a difference.
The beam pattern is not too bad, I am putting one in each car and forgetting about them so if the batteries leak and destroy it who cares.
6.16 + 5.85 to ship =12$
if you buy 5 they are 30.80$ and free shipping
or you can buy other stuff to get the order above 25 $ to get free shipping
I have a bunch of the tenergy NIMH D's so there is no leaking in lights anymore
Key Features
- High performance LED lasts 100,000 hours and never needs replacing; lumens: 180 (high mode) and 80 (low mode)
- Adjustable spot to flood focus beam with a beam distance of 146 meters
- Machined aluminum with rubber grips, large on and off switch, DC/DC regulated circuit
- Runs on 2 D alkaline batteries (included); run time 4 hours (high mode) and 11 hours (low mode)
- Withstands a 15 foot drop test, IPX4 water resistant
Package Details
Shipping Weight: 1.45 pounds
Product Description
From the Manufacturer
True to its name, Rayovac Roughneck lights are tough and durable. When you need a light that works as hard as you, the Roughneck line will get the job done. With high performance LEDs and standard lifetime warranties, we’ve got the professional level lights for the work you do. Rayovac is a trusted brand of Spectrum Brands Holdings, Inc., a top manufacturer of consumer batteries in the United States and Latin America.
Product Description
True to its name, the Roughneck is the toughest, most durable flashlight Rayovac makes. With a shock absorbing bulb system, it withstands a 7-10 foot drop test, has spot-to-flood focus capabilities and is water resistant.
WOW ipx 4 .... what is that ?? splashed from the baby ppol or squirt gun from 3 feet
I have Amazon Prime account so the shipping was free so, that made the decision for me . I never thought about those batteries before......humm
Thanks
IEC 529 European (ECC) Water Protection Specifications
IPX# waterproof specifications are specified on instruments and equipment. Below is a table of waterproof test level definitions based on the IEC 529 Specifications.
Water Level Definitions
IPX-0-0 | No special protection |
IPX-1 | Protected against falling water Equivalent to 3-5mm rainfall per minute for a duration of 10 minutes. Unit is placed in its normal operating position. |
IPX-2 | Protected against falling water when tilted up to 15 degrees - Same as IPX-1 but unit is tested in 4 fixed positions - tilted 15 degrees in each direction from normal operating position. |
IPX-3 | Protected against spraying water - Water spraying up to 60 degrees from vertical at 10 liters/min at a pressure of 80-100kN/m2 for 5 min. |
IPX-4 | Protected against splashing water - Same as IPX-3 but water is sprayed at all angles. |
IPX-5 | Protected against water jets - Water projected at all angles through a 6.3mm nozzle at a flow rate of 12.5 liters/min at a pressure of 30kN/m2 for 3 minutes from a distance of 3 meters. |
IPX-6 | Protected against heavy seas - Water projected at all angles through a 12.5mm nozzle at a flow rate of 100 liters/min at a pressure of 100kN/m2 for 3 minutes from a distance of 3 meters. |
IPX-7 | Protected against water immersion - Immersion for 30 minutes at a depth of 1 meter. |
IPX-8 | Protected against water submersion - The equipment is suitable for continual submersion in water under conditions which are identified by the manufacturer. |
So rain proof. Not bad.
Got mine today too and am happy with it. The rubber protection around the head, tail and along the body make this a perfect light for the kiddos. Everything about it feels very sturdy. Thinking about ordering some for the cars too and just leaving them in the packaging so I don't have to worry about battery leak lol.
I bought 4 and these are great as Christmas presents, white elephant games. Yep, Christmas is coming soon.
Got some this morning...thanks for the heads up.
Mine came today. Not a bad worklight, but the beam is ringy as heck. It's worth $10 as a knock-around, short-range light. It is not going to replace an L2 or even a Maglight.
The biggest thing to dislike about it? #%$ *&@! CLAMSHELL PACKAGING. JEEEeeeeez, I wonder how many people get cut or injured trying to take things like this light and batteries out of the clamshell. I HATE that stuff. Had to use a serrated knife to get through it, put a nick in the body of the light when I did it.
BTW, this $6 light is almost exactly the same size as a TK41, just little thicker body. Very comfortable to hold, especially with the rubberized inserts.
It is an XP-E with some sort of moving-aspheric that is part of the flood-to-throw mechanism.
Edit again...the throw on this light is not too bad. Puts a very cool white hotspot out about 150 feet pretty clearly.
Or you can use one of those snap-off razor knives with the adjustable blade length . Just leave about 1/16 of the blade showing .
i use tin snips
