Thank you, Simon,
I ordered mine from AExpress and been using it for 2 weeks on my Lumintop AA 2.0.
Such a wonderful brightness and the best thing is its high capacity.
Thank you for this BLF giveaway
I just inbox you and picked the:
GARMIN Cycling Bicycle Mount 3 packā> 2pack
Anybody knows what are the cells inside the Shockli and Vapcell?
Just curious why only a few brands are selling good quality 14500 and none of them is the actual producer.
Though a friend on Amazon I ordered the four cell button top pack.
The cells arrived with 3.89 - 3.9 volt charge, I did sample one cell with my Opus charger. The cell when fully charged has a capacity at 925 mah, wonderful. I donāt know of any other high capacity 14500 cells on the market.
Much better than āname brandā (NC and XTR) cells I bought in the past. For lots more too!
I use these cells in my JetBeam E10R, Skilhunt H15, AceBeam H40, and Thorfire TG06S. they fit and operate as expected. A great purchase.
BTW when I opened the shipping box an extra flat top 1000 mah 14500 was included.! Thanks Simon
Thanks for your support of Shockli brand, Now we are making a promotion of Shockli 14500 1000mAh battery from Nov 25th to Dec 3th in our aliexpress store , you can get additional $1 off using the coupon code L8P2H9204M1A.
Excellent design indeed, however reverse clicky is not my type of switch.
If they make it with an electronic switch and some kind of ramping UI, that would be amazing.
BTW after I wrote this comment I got the ThruNite T10 II and itās really nice, the only thing missing is a battery level indicator.
Still waiting for the project Sofirn SP10S with Anduril, fingers crossed.
I just received some shockli 1000 mah 14500 cells & im getting 30 minutes extra run time with my zebralight H52 headlamp on H1 compared to Pkcell 14500 750mah, fenix 14500 800mah & AW 14500 750mah ,
Thatās on first charge from new before any cycles , looks like very good cells.
Anyone know how many amps the Lumintop GT Micro and Lumintop Tool AA pull? Is 3 amps on these batteries enough for those two lights or do I need the Vapcell 650mah 7 amp batteries for those?
Using a Shockli 14500 660mAh at around 4.00v (ie. not yet fully-charged), I measure around 2.5 Amps on a Tool AA 2.0 with XPL-HD LED, and around 3.0 Amps on a Tool AA 2.0 with XP-L2 LED. Iām measuring around 4.0 Amps on a GT Micro.
Interesting. The 3A version does higher than 3A if you look at HKJās graph. It was rated way too conservatively so Iām guessing it is the same cell with a new wrap.
