FREEME ✌ ASTROLUX FT03S SBT90.2 4500lm 1428m 26650/ 21700/ 18650 Flashlight - EXPIRED
Im interested
How much estimate allowance for the spring when using a 21700? Fully compressed? What will be the cons for a fully compressed spring? Adding much more resistance and create more heat and having a chance that the spring will collapse?
I have some P42A that I have no confident or not comfortable using them on the FT03.
is nobody worried this host is a bit too weak for this kind of emitter and lumens on highest ??
Sent.
A few people already expressed their worries in this thread.
Myself I’m not worried, I like hot rods.
Interested
Are codes being sent yet? I’ll take one for sure.
Is the code available now?
Current is in the mid-twenties. I believe the tiny D4 already draws 16A, so you have only seconds on turbo but people are ok with that. Mass and surface of the FT03 is way higher so it should be ok. The main worry is if Astrolux has adapted the circuitry enough well to all those amps (the D4 has great connctions inside), any weak electrical joint will break eventually.
Interested in one
Interested
Thanks
wait…im confused. are codes being sent out?? cause i haven’t received one.
Interested.
Headline says the group buy is still at the ‘interest check’ status.
Interested depending on price.
Interested
Interested
Intrested.
Definitely interested…
Can you find out what Bin they are using?
Want one to compare to my FT03 90.2
Interested.
