Exactly what I am looking for!
Any plans on doing a runtime on 3rd and 4th mode? I use those more than I do 5th (highest mode).
Yes! I’m going to first figure out if the other output drivers are enabled for my lantern then will do more runtime tests for the default levels in step mode.
We might be able to tell if you post a close-up pic of the driver.
BTW, GreenCampfire your method of measuring current is much better than mine . . .
No need for the clip lead that keeps coming off, or to try to clip to the battery holder.
Almost 5 hours!? Wow! Thanks for the testing and welcome to BLF!
Well I did another test of my LT1, using the current measuring method of GreenCampfire above. With 5 channels enabled, I measure 2.2 A on my meter with neutral tint mixing (factory reset) using a 30Q, and 1.6A using a sofirn 2200mAhr battery. Both are button tops. Interesting the Sofirn cell is not really delivering. With my laptop pull cell I get 2.06A. The sofirn cell is near 3.6V, The 30Q is at 3.8V, and the laptop at 3.9V. Guessing that cell impedance somehow factors into current draw, even with the 7135s limiting the current? I don’t really get it, unless the voltage is drooping enough that the 7135s are not really limiting the laptop pull and Sofirn cell.
More experiments to follow, including a run test with 4 ~3000mAhr cells I have that I’m topping off right now.
Switch to the ohms (resistance) on the dial. Get the leads to touch each side of the 6/7 pads. If it’s low then they might be bridge, if it’s fairly high or out of range then they’re not bridged.
I get a reading so it looks like my 6/7 pads are bridged then?
Check left half moon of 6 and right half moon of 6. I’m too lazy to open paint and make a picture. Then repeat for 7. Sorry was not clear earlier. But from that close up picture does not look like they are bridged together, so you should get a pretty high reading.
I would expect that one side of pad 6 and one side of pad 7 would be connected. What was suggested (not clearly enough) is to measure the resistance between the two adjacent pads labeled 6, the two adjacent pads labeled 7, for both WW and NW. Zooming in on the picture, I would think they are not shorted together.
The recent measurements I made suggest that the pads are not connected, but somehow there is more current demand from the batteries than expected. I made some measurements in my previous post with a few different cells. I with my 30Q cells, I got numbers close to you. with other cells the readings were a bit lower.
I meant to change the tint to all one or the other direction, will check that out when I pause my current run test later this evening. The current changing with tint was an observation made in the early versions of tint mixing firmware, but I thought that had been addressed.
Welcome to BLF GreenCampfire! Awesome test with graph too That is about what i got on the production model with the 3000mah cells running it on maximum is between the 5 to 5.5 hours non stop. I usually run it on a mode or two down, (75 to 80%) and seems to nearly triple the run times, but i don’t remember if it was on the 3000 mAh , 3200mAh or 3500 mAh cells i was testing at the tome for that lower mode running.
I’m not sure if GreenCamper and I both have DVMs that measure high, or if there is some sort of change between the prototypes and the production units in terms of current draw. The video from Lexel below shows the early phenomenon with the tint ramping. In this case, the current during the “mixed” tints is lower than either end.
The measurements in this thread approach that of Lexel’s, but with only 5 of the 7 channels enabled. Are the 7135s wacky? or is there some other loss happening? 5x0.35A=1.75A, not 2.2 or 2.4 like we are measuring now.
I’m still reading a resistance when testing the adjacent pads labeled 6 and 7, for both WW and NW :exclamation: .
At 200Mega ohms it’s pretty much an open circuit You’re both getting roughly 2.5A, now I’m temped to measure mine also.
I got 2.1156A with the trusty fluke dmm with a LG HG2 at 4.1078V and 2.1245A with the sofirn included battery at 4.1202V
Also each of my 6/7 pads are measuring around 4.5 - 4.9 M ohms to each other.
I agree with atobe, the resistance would be more like 1.2 ohms or less, not 1.2 megaohm
Mystery solved. Its the tint ramping. with factory default, current at max level is 1.77A on my meter on either end of tint ramping. So with either just 4 WW leds, or 4 NW leds, I get 1.77A, which is what I would expect for 5 7135 chips each drawing their max current. But at the default mixing, I get 2.1A (this go around). I’m guessing there are small peaks and valleys of current draw throughout the tint mixing scheme.
Moral of the story, if you want max runtime, choose full WW or NW, else just enjoy your lantern.
As far as run time tests go, one also needs to specify the setting of the tint, which realistically can only be all WW, all NW, or default tint mixing.
I am assuming Sofirn has used the standard 0.350 mA 7135s on all the LT1s, ( as i remember there was a 0.380 mA version of the 7135 regulator?
That may be a part of it DBSAR, but it does appear that if tint mixing is in the middle of the range, that the current increases. In these cases none of the channels is at 100%, but some hybrid to keep the brightness constant. I recall seeing graphs that ToyKeeper posted some time ago regarding plotting total current versus tint mix, and it seemed reasonably flat. Not sure if running at the max level causes a peak for some reason, or ???.
Glad that is cleared up! My initial runtime test wasn’t with default ramping so I’ll reset the firmware and redo the test again. I’ll update the OP once I have the results.
Thanks for joining the gang, GreenCampfire!
I noticed that too, as there was less amp draw at the far-end of each of the tints then in the middle range, (3700K ~ 4200K) when all eight LEDs were running.
Neat that makes sense.
