Well I did another test of my LT1, using the current measuring method of GreenCampfire above. With 5 channels enabled, I measure 2.2 A on my meter with neutral tint mixing (factory reset) using a 30Q, and 1.6A using a sofirn 2200mAhr battery. Both are button tops. Interesting the Sofirn cell is not really delivering. With my laptop pull cell I get 2.06A. The sofirn cell is near 3.6V, The 30Q is at 3.8V, and the laptop at 3.9V. Guessing that cell impedance somehow factors into current draw, even with the 7135s limiting the current? I don’t really get it, unless the voltage is drooping enough that the 7135s are not really limiting the laptop pull and Sofirn cell.
More experiments to follow, including a run test with 4 ~3000mAhr cells I have that I’m topping off right now.
Check left half moon of 6 and right half moon of 6. I’m too lazy to open paint and make a picture. Then repeat for 7. Sorry was not clear earlier. But from that close up picture does not look like they are bridged together, so you should get a pretty high reading.
I would expect that one side of pad 6 and one side of pad 7 would be connected. What was suggested (not clearly enough) is to measure the resistance between the two adjacent pads labeled 6, the two adjacent pads labeled 7, for both WW and NW. Zooming in on the picture, I would think they are not shorted together.
The recent measurements I made suggest that the pads are not connected, but somehow there is more current demand from the batteries than expected. I made some measurements in my previous post with a few different cells. I with my 30Q cells, I got numbers close to you. with other cells the readings were a bit lower.
I meant to change the tint to all one or the other direction, will check that out when I pause my current run test later this evening. The current changing with tint was an observation made in the early versions of tint mixing firmware, but I thought that had been addressed.
Welcome to BLF GreenCampfire! Awesome test with graph too That is about what i got on the production model with the 3000mah cells running it on maximum is between the 5 to 5.5 hours non stop. I usually run it on a mode or two down, (75 to 80%) and seems to nearly triple the run times, but i don’t remember if it was on the 3000 mAh , 3200mAh or 3500 mAh cells i was testing at the tome for that lower mode running.
I’m not sure if GreenCamper and I both have DVMs that measure high, or if there is some sort of change between the prototypes and the production units in terms of current draw. The video from Lexel below shows the early phenomenon with the tint ramping. In this case, the current during the “mixed” tints is lower than either end.
The measurements in this thread approach that of Lexel’s, but with only 5 of the 7 channels enabled. Are the 7135s wacky? or is there some other loss happening? 5x0.35A=1.75A, not 2.2 or 2.4 like we are measuring now.
I agree with atobe, the resistance would be more like 1.2 ohms or less, not 1.2 megaohm
Mystery solved. Its the tint ramping. with factory default, current at max level is 1.77A on my meter on either end of tint ramping. So with either just 4 WW leds, or 4 NW leds, I get 1.77A, which is what I would expect for 5 7135 chips each drawing their max current. But at the default mixing, I get 2.1A (this go around). I’m guessing there are small peaks and valleys of current draw throughout the tint mixing scheme.
Moral of the story, if you want max runtime, choose full WW or NW, else just enjoy your lantern.
As far as run time tests go, one also needs to specify the setting of the tint, which realistically can only be all WW, all NW, or default tint mixing.
That may be a part of it DBSAR, but it does appear that if tint mixing is in the middle of the range, that the current increases. In these cases none of the channels is at 100%, but some hybrid to keep the brightness constant. I recall seeing graphs that ToyKeeper posted some time ago regarding plotting total current versus tint mix, and it seemed reasonably flat. Not sure if running at the max level causes a peak for some reason, or ???.
Glad that is cleared up! My initial runtime test wasn’t with default ramping so I’ll reset the firmware and redo the test again. I’ll update the OP once I have the results.
I noticed that too, as there was less amp draw at the far-end of each of the tints then in the middle range, (3700K ~ 4200K) when all eight LEDs were running.
My runtime test 1 (no graphs, sorry) was 4 hours and 38 minutes with 4 recycle cells pulled from the recycle bin at work that measured between 2950 and 3050 mAhr Zanflare C4 charger. My charger is a bit optimistic for capacity measurements, or so it has been reported. I stopped the test when the lantern made a noticeable step down. I was starting to think they light was dimmer, then within a minute or so the light stepped down to about half, similar to the graph in the OP. I measured the cells all at nearly 3.0V when I stopped the test. Like GreenCamper, I didn’t want to run the cells down any lower, at least for this test. I can’t be certain what the tint was when I started the test, but I think it was the default. 2 hours into the test I paused it to make the observations noted above regarding tint mixing and current. Then I continued the test at the factory default tint mix.
I’m charging the cells back up in the lantern overnight, and will run a full NW tint run test tomorrow.
Nice measurement, thanks. But I don’t agree with the conclusion, at least before I see output measurements (even intensity would do).
The reason is that higher current likely means higher output. And if you want to prolong battery life - run it in the most efficient mode with just enough output to do what you need to do. If at level X tint-mixed variant is brighter than the end of the spectrum you should turn it down a bit to get a fair comparison of what is better for maximum battery life.
I suspect that the best might be cool simply because cool LEDs are more efficient. Though by tint mixing you’re doubling the number of LEDs and in effect halving current per emitter. This is good for efficiency…
So actually my guess would be that the most efficient for a stock LT1 would be either cool or (more likely) a farly-cool mix.
One could unsolder some 7135 from the warm side to make all mixes more coolish. I think that it would improve the peak efficiency of the lantern.
With my LT1 using a non-production firmware load (with SOS added, helping ToyKeeper test this for stability), 5 WW and 5 NW 7135 chips enabled, running the lantern at level 150/150, the longest runtimes appear to occur when the lantern is at either 100% NW or 100% WW in the tint mixing. I tested the firmware default above for approximately 3 of the nearly 5 hours of run time. For the remainder of the time I beleive it was also at the firmware default, but may have been just “somewhere close”, as I didn’t return to firmware default prior to the test.
Hows that?
BTW, I don’t believe my firmware version has anything different in the code regarding the way the channels are driven at the various tint mixing settings. I will repeat the 100% NW tint mixing later today, after I sleep more (hopefully) and my batteries finish charging. Unfortunately I have no way to measure light intensity.
Fyi, I’m using an Adafruit 4162 VEML7700 light sensor and Raspberry Pi Zero to measure the light output, along with a custom Python script to generate a csv file to import into Excel to create the runtime charts. Cost about $20 total and works very well :+1:
I tested my Fenix UC35 v2 flashlight with it on turbo and the runtime chart pretty much matches the one from Fenix.
I been getting 1.78 to 1.95 amps with 5 channels on the production model with 5 AMCs default, and with 7 i have been measuring between 2.2 and 2.46 amps with all 7 AMCs enabled, on the Sofirn 3000 mAh cells with the pedal-to-the-metal, (maximum) with three different meters i tested with. i noticed the amps change a little depending on the tint-range setting, and seems to draw a little less amps at the each end of the tint ramp range.
