Does anyone know, is Anduril able to control a digitally addressable RGB LED's ?
Also, what is the "optic nerve" / "VISION_PIN" (PIN 7) on the FWxA Tiny85 ? I've seen that Lexel used that pin for his AUX lights board mod for the FW3A.
My scenario is that I've replaced my FW1A's XP-L HI emitter with an XP-G2, thus with the lower power, I've removed the FET and 4 of the 7135's.
Thing is, now I've a free output (PIN 3 / FET) and I was thinking to use that pin to control an RGB addressable LED and poke a hole through the head to see the light.
Now, one problem is that I know that PIN 3 is currently set up as PWM and I've no clue as if that might be a hardware limitation, or if it could easily be remapped to anything.
Second, I've no idea if such digitally addressable RGB LED's are available at around ~3V or even lower "flavours".. Most of them that I've found allover the internet are 5V.
Just a question… When I’m in temp config mode and setting current temp, so clicking during the first buzz, and then not clicking during the second buzz, the max temp will be set to 30degC, or stay unchanged? And if I click only during the second buzz, will the current temp stay unchanged?
Hi, I’ll explain the thermal configuration well; I tell you right away that there is a shortcut to get to this configuration: 1) make 10 clicks from off 2) after the first flash set the current temperature: example: if the room temperature is 25 degrees ° do 25 clicks; wait for the second flash and after this second flash set the maximum temperature limit that the torch should reach before starting to lower the level; the temperature is set by default to 30 ° and therefore you have to click + 30: example: if you want to set the limit to 45 ° you have to make 15 clicks: 15 + 30 = 45; if you want to set 50 you have to do 20 clicks, 20 + 30 = 50; if you want to set the minimum you only make 1 click: 30 +1 = 31 etc. I hope I have clarified; of course you can get to this configuration also with the method you see on the diagram: click 4 from Temp Check Hello and good lighting !!
Hi all friends! Hank told me that the current version of the d18, version 11-20, does not have a muggle mode; unlike the others, it can be reset to factory settings; it also has automatic memory and manual memory and a protection if you keep the power button pressed for a long time: if you hold it down too long, the light will automatically go down to the minimum level after a while; I can’t tell if it has other new methods too.
Hi, also D4S - D4SV2 - D1 with Anduril UI, have the shortcut with 10 clicks from off to make thermal regulation; I know for sure why I have these torches.
I have the d4s right here in my hands, and I assure you that by making 10 clicks from off I get to the thermal configuration mode; as for the D1, I have the model with Anduril UI bought from Hang and not the model with the old IOS V2 UI interface; well, I can guarantee you that the D1 with Anduril UI has the thermal configuration with 10 clicks from off; summarizing: D4S and D1 with Anduril Ui, they have the thermal configuration with 10 clicks from off. I guarantee it at 100%. At least it may be that you are talking about an old version of D4S … everything is possible; mine has 10 clicks from off; Hello and good day from Rome … here it is cold and it always rains. Riccardo.
You might have an older version of Anduril on your D4S. I haven’t found any hint that it was included previously. Maybe it’s a build for a different flashlight.
Hi; I believe what I have in my hands; in my hands there is a d4s and a D1 with UI Anduril that have 10 clicks from off to go to thermal configuration; to conclude, it would be better to ask someone who knows more than the two of us; I always ask my friend Hank when I have doubts; you could do like me too; good day my friend.
You can also ask those who own a D4s or a D1 with Ui Anduril; my Italian friends have both torches bought from Hank and both torches have 10 clicks from off for thermal configuration; Hi friend, here in Italy it is 9 pm at night, my wife has prepared a nice steak and I go to dinner; See you tomorrow!
I don’t doubt yours (and maybe others) have 10 click thermal config, but it’s not included in the official Anduril code and my flashlight (that I flashed myself) don’t have it as well.
Are you sure that you have Anduril and not RampingIOS (the default firmware for these lights), which is very similar?
