I have the same problem with one of mine. It is from the initial Nichia run. I’ve written to Neal about it - the driver is too much off center and must be shorting through the retaining ring. Neal acknowledged the problem and offered a replacement part.
Nothing happened since then. More than three months later I get no response from him and no replacement. My Nichia version FW3A is used as a peperweight. Meanwhile every second week a new praised version pops out. It’s a very frustrating experience.
Obviously the flashlight suffers because of hastly production, and because of the big interest the Nealsgadgets store does not have time to spare for warranty issues. A pleasure for the customer.
Mine did as well...so i asked Victor Zhou on FB for help since he’s Lumintop sales menager (or similar) and i got 2 drivers for 10$, shipping included.
Desolder led wires, remove retaining ring, desolder wires from old driver and solder them to a new board. Everything else is reversible as removal. Straight forward i’d say.
No the driver board itself, and it’s not straight forward. I have done several driver fixes/changes on the FW3A’s the new boards are over size, so the ones I have changed were do to improper fitting. One was so loose from the factory, when tightened down by the retainer, the signal ring was under the retainer ring? 2 from the factory were just thrown in and tightened down they were not properly fit/seated. Most of the material is taken off the key or the flat that locks the driver into the driver pocket, this keeps the signal ring on the driver centered, not removing material from around the main diameter of the driver.
Ok, well i had to hold the driver spring centered while tightening the ring. But i asume everyone will do the same. If the driver is a bit larger than the seat pocket then some rework of the head can be done via elbow grease system
Well, mine is mainly a shelf queen, due to the fact the button way-too-easily activates when pocket carried. But, after reading this discussion, I’m going to make it a shelf queen-on-a-metal-lid. I suppose I could take the battery out, but I prefer to keep cells in all my lights or I’d never use them.
The FW3A has a hair-trigger switch. To avoid accidents you can:
a- Lock it out. Turning the head ¼ turn does not really mechanically lock it out since there a two parallel electrical circuits. To make that happen you have to unscrew the head so far it almost comes of.
b- Electronically lock it out. But you still can drain the light accidentally because in lockout the switch provides you with a momentary moon mode.
c- Do what I have done HERE. The light is “alive” but it will take a miracle before you accidentally can press the switch.
As for the rest of it: on receiving a new light I always take it apart as far as possible. Look for coarse threads, foreign particles and debris, and lube various threads and rings before I put in a battery. And please do remember, this light was designed to accommodate an UNprotected flat top battery. Like the 30Q.
Hey there, thanks for the info. Mine are 3 prongs. That angle just makes it look like a 4 prong. Watch from this point: https://youtu.be/EncF1elFhyk?t=53
Those still don’t look correct. The prongs are way too big. Look at my picture and the spacing between the prongs, then look at yours. Or post an up close still picture
edit… looks you have a button top cell there. These FW3A’s require flat tops for spacing purposes. Button tops will add a few extra mm to the length of the cell. I’d bet that light will work just fine with a flat top 30Q
I cannot tell from the video clip, if that is a button top… you will likely have to stretch the springs to get it working with a true flattop. Don’t ask me how I know…
