Since I got a D4SV2 I’m a big fan of Andruil with 1634 and RGB LEDs.
Lexel, do you have any plans to migrate some of your drivers to that architecture eventually?
Okay, so I’ve pulled apart my MF01 driver (the buck one, v2.1) that I got from you; everything’s working fine, just re-wiring it. Just testing with the DMM and I seem to be getting 140-150 ohms between LED+ and LED-. Unsure if that’s expected behaviour; seems to be happening on both sets of emitter wires. Open to thoughts! I’m reflowing it now on a heating platform in case I’ve done something stupid somehow.
OR
Is it possible to get this image redone without the components on it, so I can trace and isolate?
Measuring this is no defect its just that the Shottky diode gets conductive by your DMM
they respond very fast and can deliver high currents but also have a quite considerable leak current
diode test shows me one side about 0.1V the other side 2.8V
a proper test would be a current-limited source of like 1A and then measure the current in both ways
Awesome, thanks mate. Was just re-doing my wiring on it, and got a short (thankfully tested before putting power to it), and have been chasing it down and then noticed that.
