I do usually not destroy cells in my testing, most cells can easily survive that I go a little above rated current, but that is not really the reason for my holders. The reason I use these holders is to get 4-terminal connection to the batteries, this improve the result at higher currents.
The fact of the matter is that we do not need third-party tests, but familiar tables from the HKJ master, by which we can compare some elements with others. And what you show on the links (from a Russian guy with a terrible English accent ThunderheartReviews), I already saw a year and a half ago.
In addition, a test is carried out there with a current of up to 20 amperes, and we need to the maximum possible for HKJ 30A, as well as 40-50 amperes, even if the report on such loads will be outside the main table after the test. Elements at the end of the last test with the highest possible loads should be destroyed and suitable only for disposal in the scrap. This is the only way to truly explore the possibilities of these 26800 or any other powerful element. Therefore, the HKJ master absolutely does not need any holders with their contacts, which only interfere with tests with their transition resistance.
Wow, these look really good.
You can also solder four wires (two wires to each pole for plus and minus). It makes no difference to connect or solder the same number of wires. However, for 26800 it is still better to solder, because they will still be used only in large battery assemblies, for which there are only holders in which they are connected using electric welding or a powerful soldering iron with tin
The holders means I get as close to the battery voltage as possible, even welding strips on would not be better, but might be as good.
I can go up to 120A test current if I did the test manually, but it would require a couple of strips welded to each end of the battery.
Soldering is a bad idea, especially for my testing. I do not want any damage to the CID, the battery must be able to vent.
For the 26800 elements, 30 amperes is enough, and for an additional report in the details of the test, also mention the behavior of the graph of the characteristic of the element at load currents of 40-50A. Although, even 30A will be enough for a normal assessment of these 26800, because you still should not count on their long viability when working on currents even 10A (judging by the available graphs from another tester, for QB26800 the optimal discharge current is a maximum of up to 7 amperes). Everything above these 10A can be considered stress loads, completely unsuitable for their long life.
I did not quite understand what kind of ventilation you are talking about.
1) If we are talking about the possible overheating of the elements when soldering with a soldering iron due to the high temperature, then a high soldering speed and a minimum exposure time of the soldering iron to the poles of the element are required. To do this, at the very beginning it is really necessary to clean the diamond file, having diamond spraying, plus and minus contacts, apply soldering acid and with quick movements of a powerful soldering iron (100-200W) apply tin on the surface of the contacts. Only then should you attach two bare leads from the AWG wires and solder them also quickly. After that, you need to take air into the lungs and just blow into the place of adhesions. It will turn out without overheating. During the tests, the batteries also heat up with high currents, while their internal temperature is much higher.
2) If we are talking about additional air cooling during the test with an air blowing fan aimed at a highly loaded cell, this is not entirely true, because the 26800 cells are designed to assemble large batteries that will be carefully packed in protective films and shirts and at the same time in the real place of their subsequent work they will not see any fans for forced cooling. Then what is the point of such additional ventilation, if the test tests need to be brought closer to the real life of operation, and not only to theoretical?
volchyonok, try DeepL translator sometime, please.
I think HKJ does not want to mess with soldering batteries right now, i.e. he's not interested in soldering batteries. He also said “I do not want any damage to the CID, the battery must be able to vent” because heating the battery anode/plus pole may noticeably increase the chances of damaging the CID. CID is an abbreviature which means Current Interrupt Device:
Related article: Battery Safety 101: Anatomy - PTC vs PCB vs CID @ Battery Bro
P.S: I heartily recommend using a low temperature solder for batteries.
Wed, 12/04/2019 - 11:34
All right, then we’ll all stay in the same place in an endless wait.
It’s not clear how the positive terminal can be damaged if the soldered wires are to be soldered to the uppermost contact, which is located quite far from the dangerous area of the safety valve of the element, and you need to do it very quickly, having prepared in advance for normal soldering? In order for the process to take place in a matter of seconds, you still need to have a powerful 100-150W soldering iron with a copper stinger, a short touch of which will be enough not to heat the entire complex unit. I don’t know, but all over the world even ordinary people do it, i.e. not only masters of their craft.
Self-quoting me back from #748…
I think this was overlooked, so I am asking again. Did those cells arrive home and got tested?
Thanks. What a mess. I see one cell gave ≈3135 mAh at 0.5 A, while the other ≈3321 mAh at the same rate (3228 mAh average at 0.5 A). The shape of the curves matches closely. Do you think this is attributable to cells from different production batches, i.e. an old cell mixed with a new one, or more likely different cell model numbers?
I will not guess about that.
This is due to the fact that elements with a GTF sticker have nothing to do with genuine Panasonic NCR18650B elements. If you carefully look at the positive exit, you will receive evidence of this fact:
Panasonic NCR18650B
GTF18650B
We already know, volchyonok. Those “GTF” cells actually are manufactured by a chinese OEM (BAK, as far as I know), bought in bulk by someone, rewrapped with a fake wrap and then sold. Pretty common in china.
I recently ordered some cheap Colaier G35 cells, their top pole says it all:
An EBD-M05 battery tester is also on the way home, I will publish some discharge curves once I get them.
Apollo Max graphene power bank
https://www.indiegogo.com/projects/apollo-max-the-power-bank-recharges-in-19-mins
I did not understand what level of charging current was selected for this device in order to fill this battery with a capacity of 10 Ah in 19 minutes?
Depends on its battery configuration volchyonok. For starters, it has a 37 Wh rated battery and is powered by 100 W USB PD input so, technically speaking, if both its internal converter and battery were 100% efficient, a fully discharged 37 Wh battery charged at a rate of 100 W would take t = 37 Wh / 100 W = 0.37 hours. This is 22 minutes and 12 seconds so, without any need to refine my estimations even further by taking into account losses, we already now the claimed 19 minutes recharge time must be a lie.
It could also be that the battery capacity is actually lower (a different lie) and it meets the claimed time.
Concerning recharge current a 2S 5000 mAh graphene lithium battery (7.4 V nominal) directly connected to its charging converter would need between 16 and 17 A (I presume) of charging current to go from 0 to 100% in 19 minutes. My quoted range is because it depends on how low the internal resistance of the battery is (should be ultra low).
If the new battery has low internal resistance, then due to its charge with high currents, this resistance eventually starts to increase noticeably, quickly turning the new battery into the old one. Unfortunately this is the case. Long-life batteries turn into fast-discharging capacitors. Therefore, batteries cannot be charged with excessively high currents, and a sufficient amount of time is required for a normal life resource to charge.
The Apollo Max is a gimmick for people who wipe their asses with $100 banknotes. :-))
It is a USB power device and, unless the brand donates a review unit or a bunch of people here (!) raises funds to buy a review unit, no chance to see it reviewed.
