BLF LT1M - LT1 Mini (link to project)
I discovered if the inside of the battery tube of the Fireflies PL47 21700 light was just barely half a mm larger, a 3-AAA plastic carrier from any cheap 3-AAA flashlight fits it and works with additional longer springs.
I like this idea, but I also dislike it. Flexibility is always a good thing, but what would be the result of someone having this carrier installed and accidentally / ignorantly plugging up the charge cable? Cooked NiMH or popped alkalines?
I’m sure it would be possible to design a mechanism that would prevent that, but it would complicate things.
…. a keyway, a switch that is activated when the 3xaa carrier is inserted……. everything and anything is possible. Is it worth the effort?
indeed that is a concern.
good points. Something to disable charging with a 3-AAA carrier in it.
Those carriers have a pogo-stick nipple to make contact, no?
Make a small center contact for power, and a concentric ring around it for charging. Should make contact with flat-tops, but not with the carrier.
good idea :+1:
Put me on the list for three. (When the list is started)
Would it be possible to add red LED’s operated as a separate mode in Anduril? Perfect for keeping bugs away when camping or fishing. Perhaps deep red XP-E? They are relatively cheap.
That would work, you could do a similar circuit to the yellow work lamps that take 18650 and AA, they have a series of diodes to prevent charging of the AA.
Big Clive has done a tear down and circuit
That way the LT micro could be a power bank too.
https://youtu.be/NAoISQaA5jY
it is possible, depending on if it will drive up the cost of the lantern or not.
Very Cool! I love battery versatility! Like the ZL SC80 and the CountyComm Single C and D lights that have AA and AAA carriers.
I’ll take 2 please!
Interesting. Count me in for at least one.
Also thinking plastic should be considered due weight considerations, and also cost. Assuming reasonable durability, but the lighter it is the less force acting on it to cause damage.[/quote
I think going composite (plastic or something else) is the way to go. The cost of mold-making might make the project unprofitable however. I would think 5000 units or more would have to be sold to break out on it. Personally, I would not carry a metal flashlight on a backpack venture. As Colin Fletcher once said, “Take care of the ounces and the pounds will take care of themselves.” I cut toothbrushes in half and stuff like that. Nothing metal in or on my pack is how I go, if possible. I’m keen on the aaa batteries as a power option, or aa would be fine too. I can’t imagine carrying power bricks in a backpack.
As I mentioned earlier, I’ll buy anything with the BLF monicker because I like the looks and function of everything I’ve seen. If the mini lantern is too heavy for me, then I’ll surely find a use for it elsewhere. So carry on dbsar, I’m sure it will be cool. Check me for one at least.
Carbon Fiber
Interested.
I just received this and like it a lot .
Something similar without the flashlight might be a winner !
https://www.amazon.com/Streamlight-Siege-Rechargeable-Lantern-Coyote/dp/B07Q583715/ref=sr_1_5?dchild=1&keywords=streamlight+18650&qid=1576184766&sr=8-5
If you start an interest list sign up in in for 2 (at least!)
If it’s anything remotely close to djozz’s lantern mod from the first page I’m in for two.
