Sunlikelamp.com SunLike10xss SOL Ultra High CRI E27 LED bulb (2700/3200/5000/5600K)
The LED bulb won’t give you a retinal sunburn or cause UV-related darkening of the eye’s lens, if that’s what you’re asking. It doesn’t emit enough invisible frequencies to hurt the eyes like sunlight does.
So… it’s not exactly like sunlight.
I guess it’s a matter of preference, but i prefer 2700K or a bit lower for indoor (home) evening lighting.
Let us know when you have them in stock, if you want.
I would buy 3 or 4 pcs of the 2700K 6 Watt SOL COBs
you can order it, and I will send it as soon as possible.
I will send you a PM tomorrow.
I will see it when i can order them in your shop. :+1:
The results here look really really good.
I would love to get a bunch of those in ~4000K.
4000k is most popular. And I like it more than others. But 4200/4300k is better. I will have it when I will mix 1pcs 5000k and 2pcs 4000k 3030 smd LEDs sunlike.
I’d be up for a 2700K option. Is there a way to pre-order/reserve?
Make order on my web-site. I will add 2700k in options.
Well done!
I just added 2700k in options (right now)
If someone ends up with the same bulb and wants to try out all the different combinations, here’s what works.
Note that there are other switch combinations which result in the same COBs being on, but this is just one that I first wrote down before testing and is not necessarily the most logical one. Going through the color temperatures is a bit more intuitive once you get your hands on the bulb, but it’s not super user friendly. This could use a remote or an app :wink:
If it says 3 up, it means all the others are down as there’s only two positions.
Looking from the side so that the bulb is facing upwards.
Single COB
2700K All switches up
3200K Rightmost switches (5+6) down
5000K Center and rightmost switches (3+4+5+6) down
5600K All switches down
Two COB mix
2700+3200K Switch 6 down
2700+5000K Switch 4 down
2700+5600K 1+2+3 down
3200+5000K 3+5+6 down
3200+5600K 3 up
5000+5600K 1 up
Three COB mix
2700+3200+5000 4+6 down
2700+3200+5600 3+5 up
2700+5000+5600 2+4 down
3200+5000+5600 1+3 up
All COBs on
2700+3200+5000+5600 2+4+6 down
Yes, that seems confusing, but actually not so. Cycling modes from warmest to coolest in succession without going through all the possible mixes is easy. From all the switches up, just keep pressing the switches down starting from the right one by one and you end up with seven steps, which should give you the desired CCT.
I will not do 9s model anymore =) It was unique - for rewiev SOLs LEDs from SmartEcoLightning co. (it is with the BEST spectrum in the world, better will be StarLike LEDs, but I didn’t tell you this, it is secret) Better than SOLs can be more cheaper LEDs with the same or better quality, but price of leds is not feeld in final price of my bulbs.
But when I produced this model, it was good idea in my mind: I will do S model (13s) with 4 switches, not 2 like in past, and it will be with resistors on it (ordinary and NTC). Previous idea was to use NTC resistor (because with ordinary it will be too much energy when all curent will go to line with resistor) with 2 switches for 4300-4200k middle mode. With 2 switches it is 3 modes, but with 4 switches and resistors it will be 2 types of leds and 9 modes (not 3) with ~2700-3000-3700-4000-4300-4600-4900-5300-5600k
Now I am waiting for NTC resistors to do model in real.
If someone want MORE PHOTOS of SunLike10xss
upgade of LED drivers v1.4 (08.2019)
What inside SunLike10X (SunLike9) model? It is most cheap LED bulb from me
Without any tapes. I isolated body with mica
How much time need to produce SunLike6C?
How much time need to draw pcb board?
How much time will work ordinary LED bulb and why is so short life time?
use translator! LINK
Adam, I'm really glad to have found you online while searching for the Ultimate LED Bulbs, reached you, and that you put enough confidence in us to send you this nicely quadri-equipped bulb so your offering could be tested. With those results I hope many people will now contact you to get those nice bulbs!
And maukka, once again, thanks to have dropped in this Ultimate Light Bulb Quest willingly, and many many thanks for your amazing work with those thorough reviews!
Hats down to both of you guys!
I am going to have to measure my desk lamp to see if one of these can fit. I am a bit concerned about the size and weight though since it’s on one of those spring tension arms. Super high CRI, nice tint sounds like an ideal light for this type of application.
Nice review. I have a SunLike10x coming in the next week or two hopefully.
maukka, your PNG files is too large. It is easy to do it twice smaller with lossless.
Just use OptiPNG
If you want additional 0-10%, you can use after that PNGoutWIN, but it is really slow
LOL, you should see the .png a marketing company sent me yesterday. It was 627456 bytes originally, but compressed to just 20467 bytes with optipng. That’s 96.7% smaller.
I have no idea how they managed to bloat the image so much. It was bigger than a completely uncompressed raw version of itself.
They probably converted it to a raw format to ‘’enhance’’ it, not knowing how image compression works.
Like people who convert 160kbps OPUS audio to Youtube back to 320kbps MP3…
That was funny!!!
Congratulations for the results, although I'm not surprised. :THUMBS-UP:
Adam, would you be interested in selling us the bulbs as a parts kit?
It would make it possible for us to afford more SunLike bulbs. And that would save you a lot of work.
Yes!
I’m with JoshK on that one.
