Interested in 2
Interested!
Interested in 1 please. Thank you!
Interest in 1 piece
The sustained lumens are proportional to the lights temperature and surface area
So if you get the temperature limit a lot higher it maintain more lumens
Of course especially with full battery good buck/boost drivers are more efficient, with reasonable discharged battery the sustained lumens of the MF01 mini increase
I did not test that, but I assume there will not be a further step down, except the battery voltage sag.
Add me for an extra one, (already sent a pm yesterday with the reason why )
so 2 total for me please
I’m in for 2.
In for one.
There 4 variant of Astrolux MF01 Mini and there are ; Full aluminium, alu + copper, full copper, full brass
Question, which one from 4 of these is a heat stable material? Man of light, what your opinion?
What do you mean by heat stable?
Why are you asking a general flashlight question in a thread that is focused on the little cover plate?
Are you asking which will absorb the heat best before Turbo steps down? That should be the copper version.
Interested but cautious of shipping price
I know it general, but as I do my research on full copper mf01 mini vs stock alu mf01 mini stepdown result is pretty much the same. I’m not only count on turbo stepdown. I’m also look strpdown on top ramping, mid ramping…
So Jason, I guess you recomendd me the full copper right? What about the alu + copper version? I mean there less heavy and less expensive than full copper…I’m trying to figure out which one gonna buy?
Definitely not, full copper is very heavy and a pain to carry. It does have the best performance which is what you asked for. I would stick to all aluminum for a light you are actually gonna use. I think the other 3 versions are more for looking pretty and collecting.
I personally don’t use Turbo more than 5 or 10 seconds at a time anyway so there is zero advantage for me to get the copper version.
You have decide what’s best for your needs.
my plan is that, I’m gonna buy the ALU + COPPER MF01 mini and replace the plastic cover with the above mention special copper pill design, paste with thermal cpu compound and done! Hope to expect much longer stepdown for 1000lumen and 1800lumen. Turbo? nah…me too rarely rely to it, too much of heat…
one for me please
Thanks Jason for the explanation, I fully agree with you.
The full copper will bring some small advantages in turbo mode, but whether it’s worth it, everyone has to assess themselves.
My Ranking in case of thermal efficiency after the mod: full copper, copper+alu, full alu, brass.
Would like to get one.
Please see the shipping costs and options in post #1, e.g. international postal delivery registered (with tracking) = $7,92
