MF01 Mini / MT07- Mod/Upgrade - Copper Heatsink Cover Plate
668 posts / 0 new
Dr.Phillip
Dr.Phillip's picture
Last seen: 1 month 1 week ago
man of light wrote:
I’ve just updated post #1 with new pictures, runtime graphs and an update on current status, so take a look on that.
Here are some more runtime graphs regarding this mod.
This results are only for technical interested for discussions and to compare the aluminum (V1) and the copper version (V2.1) to each other in their efficiency.
This results are not showing the effect before and after the mod, only variations in the material and the design of the heatsink plates.
Turbo mode test, both with fresh loaded Shockli 26650 IMR 5500mah, there is not much of a difference.
Here a special scenario with a freshly loaded high drain cell, Samsung 40T. In this case the AMC’s become hot very quickly, a good thermal transfer is necessary to avoid the step down.
!{width:49%}[img]https://i.imgur.com/MDQ6KfB.png[/img]!
Well I’ll be damned. I checked the updated 1st post and was very surprised. I didnt expect thid mode to influence the turbo so much. I know we are adding heatsink mass mostly to the head, but still. Very nice. And that max ramp looks great. Great job man (of light :D). I hope our chinase friends implement the aluminium mod, but I somehow doubt it.
Gerrit
Last seen: 53 min 19 sec ago
looks good Thumbs Up
crazylite
crazylite's picture
Last seen: 11 months 2 days ago
Interested for one.
gerasalex
gerasalex's picture
man of light wrote:
Thumbs Up What further reduction in time, after 11 minutes, from 1000 to 500 lm approximately, did you measure? (with mod)
"... God is light, and in him is no darkness at all..." 1 John 1:5 (KJV)
SKV89
Last seen: 1 hour 56 min ago
The results are very interesting! Thumbs Up
Looking at the graphs got me thinking. Can someone explain to me why the Olight M2R Pro weighting 95.8g with a single XHP35 emitter can sustain 750 lumens, but the MF01 Mini weighing 171g, more surface area, and 7 SST-20 emitters only sustain 1,000 lumens? In turbo mode, the MF01 Mini seems to only sustain about 500 lumens.
I understand the SST-20 is not as efficient as the XHP35 but with 7 emitters, the SST-20 emitters should be operating at an efficiency range likely comparable to the XHP35 or more likely even more efficient.
al_kol
Last seen: 10 months 3 days ago
Interested in 1
Thanks
middle age man
Last seen: 1 day 19 hours ago
Better driver and thermal design/efficiency with more expensive flashlights, e.g. ZL SC700d and Wuben TO50R are both smaller and lighter than MF01 mini yet can sustain 1,000+ lm for an extended period?
Stefan333
Last seen: 5 days 20 hours ago
Interested in 2
Brinkmann
Last seen: 3 days 6 hours ago
Interested!
Phoneas
Interested in 1 please. Thank you!
hasddie293
hasddie293's picture
Last seen: 7 hours 13 min ago
Interest in 1 piece
In search of the most ideal flashlight in town:
1. BRIGHTNESS
2. Durabillity
3. Design
4. Quality
5. Price$$$
Lexel
Lexel's picture
Last seen: 3 weeks 18 hours ago
The sustained lumens are proportional to the lights temperature and surface area
So if you get the temperature limit a lot higher it maintain more lumens
Of course especially with full battery good buck/boost drivers are more efficient, with reasonable discharged battery the sustained lumens of the MF01 mini increase
man of light
man of light's picture
I did not test that, but I assume there will not be a further step down, except the battery voltage sag.
Thro
Thro's picture
Last seen: 1 day 3 hours ago
Add me for an extra one, (already sent a pm yesterday with the reason why Oops )
so 2 total for me please
Dyrnwyn
I’m in for 2.
Bo4ka
In for one.
hasddie293
There 4 variant of Astrolux MF01 Mini and there are ; Full aluminium, alu + copper, full copper, full brass
Question Question, which one from 4 of these is a heat stable material? Man of light, what your opinion?
1. BRIGHTNESS
2. Durabillity
3. Design
4. Quality
5. Price$$$
JasonWW
JasonWW's picture
Last seen: 6 hours 58 min ago
What do you mean by heat stable?
Why are you asking a general flashlight question in a thread that is focused on the little cover plate?
Are you asking which will absorb the heat best before Turbo steps down? That should be the copper version.
Kennyboy
Last seen: 1 week 12 hours ago
Interested but cautious of shipping price
hasddie293
I know it general, but as I do my research on full copper mf01 mini vs stock alu mf01 mini stepdown result is pretty much the same. I’m not only count on turbo stepdown. I’m also look strpdown on top ramping, mid ramping…
So Jason, I guess you recomendd me the full copper right? What about the alu + copper version? I mean there less heavy and less expensive than full copper…I’m trying to figure out which one gonna buy?
1. BRIGHTNESS
2. Durabillity
3. Design
4. Quality
5. Price$$$
JasonWW
JasonWW's picture
hasddie293 wrote:
So Jason, I guess you recommend me the full copper right? What about the alu + copper version? I mean there less heavy and less expensive than full copper…I’m trying to figure out which one gonna buy?
Definitely not, full copper is very heavy and a pain to carry. It does have the best performance which is what you asked for. I would stick to all aluminum for a light you are actually gonna use. I think the other 3 versions are more for looking pretty and collecting.
I personally don’t use Turbo more than 5 or 10 seconds at a time anyway so there is zero advantage for me to get the copper version.
You have decide what’s best for your needs.
hasddie293
my plan is that, I’m gonna buy the ALU + COPPER MF01 mini and replace the plastic cover with the above mention special copper pill design, paste with thermal cpu compound and done! Hope to expect much longer stepdown for 1000lumen and 1800lumen. Turbo? nah..me too rarely rely to it, too much of heat…
1. BRIGHTNESS
2. Durabillity
3. Design
4. Quality
5. Price$$$
Dudu
Last seen: 11 months 2 weeks ago
one for me please
man of light
Thanks Jason for the explanation, I fully agree with you.
The full copper will bring some small advantages in turbo mode, but whether it’s worth it, everyone has to assess themselves.
My Ranking in case of thermal efficiency after the mod: full copper, copper+alu, full alu, brass.
1-10-100-1000
Last seen: 2 weeks 1 day ago
Would like to get one.
man of light
Please see the shipping costs and options in post #1, e.g. international postal delivery registered (with tracking) = $7,92
netprince
Last seen: 15 hours 45 min ago
ledlightfanatic
Last seen: 1 month 2 days ago
I need one pretty please! I cannot be stuck with a light that doesn’t live up to its full potential… One unit is all that I ask please, please bump out multi-orders as this is not fair if max is only 100. We all deserve a chance. Hat
ledlightfanatic
Also, I am even willing to pre-pay in order to secure the item in advance, if necessary.
Looking forward to your response.
AlexGT
AlexGT's picture
Last seen: 3 weeks 4 days ago
Want one
