FW3A Useful Information.....
ok… thank you for that referral as well, BabyDoc…
I agree . I was the one with the problem, and it got resolved in a couple of hours.
They are in the USA and ship quickly.
I am certain the copper is not calibrated by them because it is indeed vacuum sealed.
In fact, the clip corroded the copper a bit on the tube. I cleaned it up with a salt/vinegar combo, and a little toothpaste!
I have not calibrated the heat, but it gets so hot so fast you can not keep it above 800 lumens for more than a few seconds.
Thank you very much for the helpfull info and instructions.
Exactly the advice I was looking for without trying pushing it first and damage the LED MCPCB and the driver in the process.
Much appreciated :-)MonkeyLight
That's correct, we are NOT calibrating copper models to preserve the seal on the light. There should have been a note in each box saying so.
Calvin, can we tell by our order date/order number which version of Anduil is installed on a flashligh?
No answer to that question. Oh well.
Here’s a lanyard ring:
you can do that with rope
google ‘constrictor knot’
wle
Do you know of any good sites or videos for showing some excellent lanyard making?
You can look at toykeepers changelog and test what added feature is in your light.
Hank - USLight coincidentally started a thread asking the exact same question on the same day you did.
Assume you came across this already by now, but just in case you didn't here is a link for completeness in this Useful Information.
FW3A Anduril firmware version?
Summary:
There are so many references to the FW3A I get lost and confused.
I have an early version, first batc FW3A that is going to get an emitter transplant from the xp-l hi 3D to 3500K LH351D’s. While I am at it I want to update the firmware. The other FW3A I have is a later verson with the momentary that has a choice of 2 different levels when locked out. I want that.
Is the firmware version anduril.2019-08-05.fw3a.hex the best one to use? Can anyone verify if tis version has that 2 level momentary when in lockout? And does that version have the version check built into it?
Thanks much.
If you had to keep only one FW3A, which tint would you choose ?
The most recent FW3A firmware is here. However, I’m working on some pretty significant changes to the UI for Anduril2, and it could potentially be available late this month.
So, it depends whether you want Anduril 1 or 2.
It’s not a huge difference… mostly just catching up on some changes I’ve been delaying because they would break backward compatibility. The biggest one is that it defaults to muggle mode (er, “Simple UI”) unless the user clicks to remove the limits and enable the full UI. But it’s still in progress, and I don’t even know how some parts will look yet.
Of the official versions, I’d keep one with XP-L HI 3D.
Thanks so much for this. I found the information very helpful
Sorry if this is not the right place to ask, but I wonder how come there is a 8mm difference in length between the FW1A and the FW3A, the latter being shorter.
Same reason why “V” is taller than “w” even though they’re the same width.
More reflectors in the same space means they’ll be shallower.
Thanks ToyKeeper for the very convincing typographical analogy!
That’s correct, we are NOT calibrating copper models to preserve the seal on the light. There should have been a note in each box saying so.
[/quote]
CalvinIS. Would you consider calibrating the copper FW3A prior to shipping? Happy to pay an up charge on that. Doing so would give me a few day head start on the natural patina process (smile).
Tagged
