One of my new(Convoy/Simon) 21700 cells will only charge to 4.10V, so is it knackered and/or degrade quicker than the norm.
Tom.
Tom.
I’m not very sure, but maybe the “iMax B6” charger was set to charge to 4.10v instead of 4.20v
(usually such chargers have settings/configuration to charge to 4.10v, 4.20v, 4.35v or other nearby voltage). I can’t be too sure, but check its manual.
Most Li-Ion batteries are supposed to charge to 4.20v to get the full capacity. Charging to 4.10v loses just a bit of capacity and can prolong battery life cycle, based on what I read…
If I remember correctly, my iMax B6 Mini didn’t charge up to 4.2 volts when Li-Ion was selected. Worked fine with LiPo. Even they both should use the exact same CC/CV charging algorithm to 4.2V.
It’s odd because the other cell, of the same spec, charges to 4.2V on the B6. When I contacted Simon he responded with the charger being the problem and, for that particular cell, I would have to agree because when I charged it on my Adeaska SQ2 it came up to 4.2V.
Tom.
Like your battery holder Tom
whats your safety timer setting?
deeper discharge=longer charge time.
