streamlight stylus.
easy to mod, but uncommon batteries.
3 aaaa
Snake, can you drop some pics of internals/mod? Was thinking about this one
Stylus just has a little plastic carrier for the 5mm LED — so the shiny end pushes out the open end of the tube and the two wires go toward the other end; one wire wraps around the plastic carrier to make the positive connection, and the other wire rubs the metal tube for the negative. So you just push really firmly on the existing LED with batteries removed, and it and its plastic carrier will slide back into the battery tube and can be removed. Make sure to note the orientation of the LED plus and minus wires in the plastic carrier.
That’s all I remember from replacing LEDs in Stylus penlights many years ago. I think I had to tap the original LED with a mallet to get it to slide back into the battery tube, and press comparably hard with a pencil inside the battery tube, to get the new LED to slip into place.
100%
and if you have a pushable led(ebay high cri or a nichia gs you can eliminate the resistor.
neg lead is pressed against the tube offering a bit of heatsinking.
Cheers!
photon Freedoms x 2 with Yuji 5mm 5600 and 3200 modded.
several photons/fauxtons here with ebay high cri and lir2032.
Has anyone managed to take a Nitecore Thumb apart?
The mod I had in mind had nothing to do with high-CRI, but with a 5mm UV-led.
My original goal was to put it in a Sofirn C01 host, but that is becomimg a matter of much patience.
As for the competition: a lot of lights in the OP are about to be (or already) discontinued.
And the remaining stock is facing rising shipping fees. Anyway, to where I’m standing: in NL
After a bit of *oogling I found one or the last remaining Sunwayman R01A
At Flashaholics.co.uk in the good old UK. Important: reasonable price, reasonable shipping fee.
(Sellers in Germany and France were more expensive plus and wanted €20 for shipping!!)
Minor issue, though not for me: only remaining color available is “tan”.
Edit: arrived in less than a week. In perfect order. Even the box. And it has a Nichia led.
Tan color ain’t half bad. Free battery added. These guys are definitely on my short-list now.
I guess I’ve fallen off the wagon. Again. Hard. This time it is just tiny lights.
But even so: I had to raise my (virtual) limit by a dozen (pieces).
Next victim was the Nicron N1, named a few posts before this one.
The old (Polish AE) link doesn’t work anymore. HERE is a new link.
I used a credit card. A bit of a gamble. With PP at least you know who is robbing you.
FYI. BLF-member ReManG wrote a nice THREAD about modding a Manker Boney.
I confess I didn’t get by past the sanding of the head of the led itself and sanding the “reflector” in the bezel. Years ago I bought a couple. The pill has to be pushed out by pressing the led (gently) in.
That went fine with the black copies. The grey one did not budge a bit, not even by force.
But when the pill is out, you have to dissect that for further access. That was a bridge too far for me.
The Fenix flashlight shop has tan and grey-olive. I got a black one from ebay some month ago, too.
I guess you already modded Nitecore tubes? With rngwn’s new 32K-C-EX LEDs those are nice hosts not requiring the resistor mod.
“Life Gear” brand glow stick/flashlight combo. I got these in an 8-pack at Costco for cheap, but I’ve seen them listed on Amazon and elsewhere.
One end is a single color 5mm LED that shines into the diffuser. The other end is cool white 5mm LED.
I immediately started replacing these with rngwn’s high CRI LED’s, as shown in the photo. Heating the solder at both legs at the same time made it easy to pull the LED out, which requires a twisting motion due to the way the legs having been bent past 90 degrees for install. Then a little flux and solder wick allowed me to clear the through holes.
I put a couple more details and a disassembly photo in another thread.
Modes are flashlight only, flashlight + blinking color, flashlight + steady color, blinking color only, or steady color only.
Aside from replacement batteries being overpriced, these are good for small kids. Access to the LR44’s is protected by a small screw. With a low power, warm white LED swap, it matters very little that children tend to shine lights in the eyes of others.
Oh man, I was really into these back in the day and I still have a lot of them. The smallest is a Photon-like squeeze light but using 2x CR1220 cells and I think a 3mm led, so it’s about half the size of a traditional Photon. Have lots of Arc, Peak, CMG, several Dorcy, etc., plus lots of Photon-style lights of various brands. I was just checking into the 5mm high cri led thread with the idea of modding some of these. Anyway I think there is not really a shortage of them, but if you’re looking for something specific and I have it, I’m probably open to persuasion.
thats beautiful! thanks for sharing a photo
Gratefully received my order from rngwn and much like others started raiding my old stashes of button cell lights from years past and feverishly modding. It raised a question though…
I’ve been combing data sheets and extensively reading threads but maybe my brain is just uncooperative at present - anyone have any notion on what kind of current I’m dumping into a 5mm LED direct driven from x4 LR41 in series?
It’s down to the resistance of the LR41 but those little keychain lights do get pretty bright, maybe 50+ mA. You could always check with a meter. (Added: The current will drop very quickly once the batteries aren’t new, so don’t worry about overdriving the leds for long periods. The batteries just don’t have that in them.)
I have a nice little 1x LR44 light with an actual boost converter inside and I love it, but that format never became popular. If you want a very bright keychain light not much bigger, try the Lumintop EDC Pimi. I’m down on Lumintop in general for various reasons, but that particular light has attractions that are not matched by anything else afaik.
You can add to the list Astrolux TB-01 “Bullet”.
Got a few of them. Easy to mod, widely available and comes in a few colors.
