I bought this holster for my D4SV2 and I love it. It’s a bit stretchy so it will fit several other lights with a similar size.
It can be rotated and snapped into 45 degree angles so you can use the light to shine in front of you with your hands free. If you don’t want the rotation at all, just glue the rotating part of it.
For a diffuser, this one in 36mm should fit snugly. I bought a similar one from Banggood, but it’s not available there anymore.
It should be possible but it is not the best idea because you loose a lot of runtime and brightness. Also the AA alkaline batteries are known for leaking.
If you use only the muggle mode with three rechargeable AA batteries it should work well. Most likely they won’t deliver more than 1000 lumen. Maybe you could also use a protected 26650 battery?
I looked at the topic closer…
Quite a few 26650 lights support 3*AA. But 3*AA holder is actually over 30 mm in diameter. Too large for D4S.
Protected 26650 probably won’t work - Emisar lights don’t tend to support protected cells.
Anyway - while I feel that protected Li-ion cell threadlocked in a rechargeable light would be a fair choice I would still feel better with NiMh.
There are a bunch of settings and you can have them different for different modes. I have mine set as a fixed color (usually red or magenta) when in “normal” mode and flashing or battery check when locked out.
If I recall correctly, the Nichia version has a Nichia-specific firmware that limits the current for the Nichia version (assuming the Nichia version Anduril firmware is used). Something like 80% of the max compared to the XPL-Hi/XPL-HD/SST20 versions of the D4S).
Yes, but I thought the current limit aims to bring the heat output of the Nichia down to the level of the non-Nichia version. But that does not appear to be the case. At least not on my D4SV2s. My D4SV2 Nichia runs much cooler than my D4SV2 XPL-HI, unlike my D4V2 Nichia, which runs as hot as my D4V2 XPL-HI.
