RD new greatest power supply RD6006 DC power supply coming soon
1.you can see the screen is bigger, we change the screen from 1.44 inch to 2.4 inch
2.the settings will be much easier because we add a keypad, if you want to set output value, you just need to spend a few seconds
3.add battery charging terminal, for more detailed information, you can see the videos on the youtube, we uploaded a lot
4.PC software has been changed a lot, now it is not only a data recorder, you can upload firmware for new function and use calibration function
as for other functions, it takes much time to introduce, you can check the product detail page or watch the videos
detail page:70.89€ 20% OFF|Rd rd6006 rd6006w usb wifi dc dc spannungs strom abwärts strom versorgungs modul buck einstellbarer wandler 60v 6a batterie laden|Multimeter| - AliExpress
youtube channel:https://www.youtube.com/channel/UCy73jJ5-ZqhPzT7wJ6KTIaw?view_as=subscriber
RD6006 customer feedback:
set RD series and DPS series on the same panel
RD6006 link:https://www.aliexpress.com/item/4000282551930.html
The module arrived well packed. The size was smaller than imagined. The module was tested, all the main features and characteristics are in place. Special thanks to the developers of this device for removable fuses
RD6006 feedback:
Everything is super. Thanks. Packaging at altitude. Delivery to Domodedovo 20 days.
RD6006+S06A case feedback:
I am very satisfied with the items, both.(waiting for your assembly)
[Perfect quality items. Great seller. Everything like in a description.]
[He came to Moscow in 3 weeks. The packaging is great. Initial launch successful. I did not complete the full test.]
[Great body! There are no dents, which is not surprising - the body in the foam is completely and wrapped in 3 layers of bumps. I recommend the seller. We are waiting for the last device - the 60 volt switching power supply itself]
https://es.aliexpress.com/item/4000282551930.html
if you have any questions about RD6006, you can search RD6006 on youtube, we make many instruction videos to show the operation
Very nice box and easy to assemble. Just follow the instructions.
I make a video list on the RD6006 detailed page to show the operation and solutions when meet problem
RD6006 detailed page:https://www.aliexpress.com/item/4000282551930.html
video list:https://www.youtube.com/watch?v=irTbqfqtgU0&list=PLNcr2Rj_07PEVpDagutCmxWkREnAJwPUt
show me your workbench:)
picture from customer
RD6006 feedback
Very roomy body. For the cooling system is a separate plus. By the way, the fan changes the rotation speed depending on the heating. The default is off. Look for a detailed review on the КИТАЙ В ПОМОЩЬ YouTube channel.
RD6006 feedback
Perfect unit to build Lab PSU. Concerns: fan noise in case increasing temp. Very strange and not convinient wifi configuring and usage.
Is the fan noise so loud? you guys can leave message, we will make wifi connection better in the future
RD 6006 DIY case
here we show some DIY power supply based on RD6006, welcome to send me more!
RD6006:https://www.aliexpress.com/item/4000282551930.html
RD6006 feedback:
Everything is at the highest level! Delivery 22 days, packaging reliable, everything came in perfect condition. Thank you for the good service and for the gift.
RD6006 feedback
The unit took a tip from the reviews (it is praised), when unpacking it feels like it got a new iPhone (the quality of packaging and printing at altitude). For the block itself, it’s better to read reviews on forums or YouTube.
We have come back to work and we will ship the packages according to the order date. The logistics in China is gradually recovering. We will ship your packages as fast as we can.
We are deeply sorry for any inconvenience so caused.
RD6006 tips:
CC/CV mode depends on the load you connect. For example, if you are charging a battery, it will be CC mode first, and then CV mode when the voltage reaches the max value, the output voltage will be constant and the current decreases.
RD6006:www.aliexpress.com/item/4000282551930.html
RD6006 feedback
Great power supply. Delivery was delayed due to the virus. I get V1.26, updated to V1.28(use PC software). All is good.
