Many people buying and actually using throwers have a different use case than you, simple as that. For them (myself included) a light with only 2/3 the throw but a beam that is more versatile makes much more sense. I would have to work hard to even find an area with something at >700m that isn’t already lit up because it’s a building, etc.
I like to walk several miles in the evening. One of the walking trails I use is 2.8km and is absolutely straight. One of the lakes I walk around is about 1km across. I’m looking forward to taking out the K1.
Every time I buy a light it’s “my last one.” But really, I (we on BLF, or some) use them. Some of us need to reach out, some need a mid range wider brighter light, some need an up close area light. The D18 is my current dog walking light with an MF04 or TN40s for throw. I’m hoping the K1 serves the purposes the D18 can’t, without being a total novelty. Hoping it’s a tool for what I need, aside from a work of art
The beamshots will have more information if something remote is illuminated, with the brightness setting and white balance fixed, rather a bit under-exposed than overexposed to show the differences better.
The TN42 is larger, but the wider beam is way more usable than this tiny beam. However, it’s a beautiful designed light and the throw is amazing for its size
Pure fun!
I did my own comparisons using same lights WW vs CW on foggy nights. With WW my eyes can see into the distance immediately. With CW it takes my eyes a little longer to focus due to the glare from the scattered light. However, comparing them side by side, they actually illuminate just as far to my dissappointment. I always thought WW would penetrate fog better. Though WW is more comfortable to use though especially if preserving night vision is important.
The MHVAST TS35 seems to me to be closely related to the Thrunite Catapult V6. It has about 800m throw; I expect the K1 XHP35 HI to significantly exceed that.
Even if the K1 is specced with the XHP35 when it is eventually available?
Specs on the MHVAST TS35 are:
XHP35 HI
Cool White: 6300K-6500K
Natural White: 4800K-5200K
Warm White:4300-4000K
296900 CD (Max.) - 820 Meters (Max.)
2100 Lumens (Max.)
142mm x58mm x 32.6mm (Height x Head diameter x Body diameter), so smaller than K1.
Type C usb charging.
26650 Li-ion Battery (Included)
My light has arrived in the USA. Now I have to wait for USPS to get it to me. This time of year, my local post office gets a little funky. They will incorrectly claim it was delivered and I’ll have to go the post office to get them to find it and give it to me. I assume they are just overworked at Christmas. Hopefully, this package will get delivered without the run around.
296900cd is 1090m FL1 throw, not 820. Given the reflector size and the performance of similar lights like the Catapult, I’m going with the 820m (168100cd) being closer to reality.
The K1 has a 72mm bezel, which is quite a bit larger, and I expect it to be driven at least as hard. The Acebeam T27 has a 70mm bezel and claims 1180m throw, also using the XHP35 HI. That’s the closest comparison I could easily find.
