NITECORE TM9K
The Nitecore TM9K was sent to me directly by Nitecore for review.
For product specifications: https://flashlight.nitecore.com/product/tm9k
For the purchase: https://www.nitecorestore.com/NITECORE-TM9K-9500-Lumen-Rechargeable-Flashlight-p/fl-nite-tm9k.htm
The multilingual manual: https://flashlight.nitecore.com/Uploads/FLASHLIGHTS/download/1574321015.pdf
I am happy to review the latest product released by Nitecore, the TM9K a compact and rechargeable tactical EDC which provides up to 9500 lumens that can be activated quickly at the touch of a button. The first impression, just taken in hand, are the really small dimensions of the TM9K that you hold very well in your hand.
The Nitecore TM9K offers 6 light levels including the Strobe level that can be activated with a double tap.It has 9 CREE XP-L HD V6 LEDs and reaches the maximum intensity of 18000cd covering a distance of 268 meters.
The Nitecore TM9K is powered by a built-in 5000 mAh 21700 rechargeable battery. The charging port adopts the new USB-C interface which uses QC fast charge technology.
It is equipped with 2 tail switches: Power Button and Mode Button.
The Nitecore TM9K has an electronic lock and is IP68 certified with 1m impact resistance.
Features:
- Utilizes 9 x CREE XP-L HD V6 LEDs with a max output of 9,500 lumens
- Maximum beam intensity of 18,000cd and maximum throw of 268 meters
- An optical system combined with crystal coating and "Precision Digital Optics Technology" (PDOT)
- Lightweight and rigid CNC machined unibody design provides superior heat dissipation capability
- Built-in 5,000mAh 21700 rechargeable Li-ion battery
- Intelligent Li-ion battery charging circuit with a USB-C port
- Highly efficient constant current circuit provides a stable output for up to 60 hours
- Dual tail switches enable intuitive operations for tactical applications
- TurboReady' Technology (9,500 Lumens)
- The power indicator beside the dual switches indicates the remaining battery power
- The power indicator can display the battery voltage (±0.1V)
- Optical lenses with double-sided scratch resistant coating
- Constructed from aero grade aluminum alloy
- HA III military grade hard-anodized finish
- Rating in accordance with IP68 (2 meters submersible)
- Impact resistant to 1 meter
Specifications:
Length: 125mm (4.92")
Head Diameter: 40mm (1.57")
Tube Diameter: 26mm (1.02")
Tail Diameter: 28mm (1.1")
Weight: 218g (7.69oz)
Accessories:
Clip, Lanyard, USB-C Charging Cable, Holster
The Nitecore TM9K arrived without the classic Nitecore box. Wrapped inside the bubble wrap I found the TM9K inside its holster and some accessories like the lanyard, the Clip and the USB-C cable for charging.
The holster of the Nitecore TM9K is in fairly soft cordura with a tear-off closure. Behind we find at the top the D-ring and centrally a double loop including a tear-off loop. The TM9K must be inserted with the head up and once inserted in the holster it remains firmly in place.
The stainless steel clip, included in the package, once inserted in the torch remains firm and allows and easy insertion in the jeans. On the Clip we can insert, in its two slots, the supplied cord.
The Nitecore TM9K has good build quality, there are no strange edges or construction residues and it is a compact and manageable EDC. You can close it completely with your hand holding it perfectly. The line is very beautiful and massive, where the numerous cooling fins, that, even if not deep, allow a good heat dissipation. It is made of aluminum alloy with an anodized finish, black in color, hard of military type; very good and robust the coating. The TM9K has a CNC Unibody design and, since the battery is built-in, has no unscrewable parts.
The Nitecore TM9K has an IP68 waterproof rating (submersible at 2 meters) and holds the impact up to 1 meter.
On the head of the Nitecore TM9K, of 40mm, we find 9 small SMO dishes with the 9 CREE XP-L HD V6 LEDs. The optical system has a crystal coating and digital precision technology. The stainless steel bezel is really beautiful and well made. I really like the burnished color and it is slightly crenulated (Strike Bezel). Thanks to the TurboReady technology the TM9K emits a maximum power of 9500 lumens in Turbo in a fast way with just the long press of the Mode button.
Still on the head of the TM9K, we find the fast charging port with USB-C technology protected by a rubber flap.
This fast charging port allows the TM9K to be recharged approximately 80 percent in just 1 hour and 45 minutes when charging is done via a QC adapter (Quick Charge 3A), while the full charging time may vary from 3 hours and 30 minutes up, depending on the remaining charge of the internal battery.
When charging is fast, the blue LED in the queue will flash quickly, while if we recharge in a standard way the flashing will be slow. At the end of the charge the LED will remain on to indicate that the Nitecore TM9K is fully charged. According to Nitecore, the fully charged torch can remain on standby for approximately 12 months.
Well written and legible the writings all placed on the head of the TM9K
The TM9K has a built-in battery (I don't think it's user-replaceable). It is in the 21700 5000 mAh format. This solution may or may not like it; surely the fans or torch experts will not be happy with this solution which guarantees a simpler use, also eliminating the problems related to the replacement of the battery, but precludes the possibility of choice and limits in part the time of use of the torch.
On the central body of the TM9k we find two knurled circular strips, while in the rear we find the two tactical switches, Power Button and Mode Button as well as the status LED.The power switch is in relief and easy to find and operate even if it does not allow the TM9K to be put to candle. The click is noisy.
The Power Button (Tactical Tail Switch) allows you to turn on and off the torch and momentary ignition (Momentary-on).
The TuboReady Mode Button allows the variation of available light levels and direct access to Turbo and Strobe.
The TurboReady allows the TM9K to enter Turbo mode (9500 lumens) quickly with just a long press on the Mode key. The duration of the Turbo is approximately 7 seconds before returning to the previously set level.
The Nitecore TM9K has 5 levels + the Strobe.
Turbo: 9500 lumens
High: 1900 lumens
Mid: 460 lumens
Low: 130 lumens
Ultra low: 30 lumens
Strobe: 9500 lumens
Once the TM9K has been turned on with the Power Button, the blue status LED indicates the remaining charge level of the internal battery. When the light is on and the power level is close to 50%, the blue power indicator will flash every 2 seconds to inform the user. When the light is on and the power is near to depletion, the blue power indicator will flash quickly and continuously to inform the user.
Tactical Momentary Illumination
Half press and hold the Power Button to turn on the light momentariy. Release to turn it off.
On / Off
On: When the light is off, press the Power Button until a click sound is heard to turn it on. Off: When the light is on, press the Power Button until a click sound is heard to turn it off. (The TM9K has mode memory. When reactivated, the flashlight will automatically access the previous memorized brightness level or STROBE Mode.
Brightness Levels
When the light is on, short press the Mode Button to cycle through "ULTRALOW — LOW — MID — HIGH".
TurboReadyTM
When the light is on/off, press and hold the Mode Button to directly access TURBO of 9,500 lumens. Release to return to the previous status.
STROBE Mode
When the light is on/off, double press the Mode Button to access the STROBE Mode. When the STROBE Mode is on, either short press the Mode Button or click the Power Button to exit the STROBE Mode.
Lockout / Unlock
Lockout: When the light is on, click the Power Button while holding the Mode Button and release both buttons to access Lockout Mode. The flashlight will flash once before turning off to indicate this process. After that, the power indicator will flash to show the battery voltage.
Unlock: In Lockout Mode, triple press the Mode Button to exit Lockout Mode. The flashlight will flash once to indicate this process.
Thermal Protection Function
The TM9K has Thermal Protection Function. It will automatically lower its output to avoid overheating when accessing the TURBO or HIGH Level for a prolonged time.
Power Indication
When the light is on, click the Power Button while holding the Mode Button and release both buttons to access Lockout Mode. The flashlight will flash once before turning off to indicate this process. After that, the power indicator will flash to show the battery voltage (±0.1V). For example, when the battery voltage is at 4.2V, the power indicator will flash 4 times followed by a 1.5-second pause and 2 more flashes. Different voltages represent the corresponding remaining battery power levels:
The Nitecore TM9K next to other torches.
BEAM AND RUNTIME:
The color and the beam of the Nitecore TM9k are pleasant, resulting in no artifacts. Good work has been done with the parable; despite the 9 LEDs the beam is homogeneous even at close range to the wall. The beam is floody with a beautiful shade of white. Excellent the STROBE "ready mode", with variable frequency, which can be activated simply with two quick touches. The Turbo mode is impressive for how much light can get out of the TM9K considering the size of the torch. A bit of PWM is visible through the display of my reflex but not with the naked eye. The start of the spill from the walk is adjacent to the feet.
Runtimes were performed in a closed environment at a temperature of about 19 °C with the TM9K fully charged.
I should point out that the values expressed by the graphs must be taken, above all, as a reference because they are made with means and environmental conditions different from those used in the laboratory.
1 - Nitecore TM9K at the HIGH level without ventilation.
3 - Nitecore TM9K at the HIGH level with forced ventilation.
4- Nitecore TM9K at the MEDIUM level without forced ventilation.
5 - I tried to activate the TURBO level in sequence, from the graph you can see the duration of the Turbo and how many times you manage to operate it continuously. The Turbo switches the light output to the memorized level (HIGH) when it is deactivated.
VIDEO.
https://www.youtube.com/embed/4IuSzU-U59o
CONCLUSIONS:
The Nitecore TM9K is a complete EDC torch. The first thing that catches the eye are the small dimensions with an excellent grip in the hand and the excellent construction to the touch. The TM9K, through the two tactical tail switches, can be managed quickly and easily. Strobe Ready Mode and Turbo Ready Mode allow the TM9K to operate Strobe and Turbo instantly with the power of 9500 lumens. Good the Runtime and the levels (perhaps missing a Moon level) of the Nitecore TM9K which is powered by the powerful 21700 5000 mAh battery incorporated and is rechargeable through the fast USB-C port. In conclusion the beam, floody, is excellent and the color is not too cold.
Thank you for reading the review.
