Negative. Not all models came with a clip, these did not.
What color temp is the 219b? 4500K?
Yes. I’m in talks with another user about that one, pretty sure it’s SPF but I do have more of them if you wanted me to swap one into the other light.
I’ll take the new one of the other deal doesn’t go through. Otherwise I will take the used one if you can put in a 219b.
I have a D10 in mint condition…somewhere. I gave up on it a few months after i bought it because the battery was always dead. There was some kinda parasitic discharge bug if i recall that Nitecore wouldn’t acknowledge. I would love to do an emitter/driver swap. What would you charge if i sent you mine?
Edit: I had to dig around and find it. I was wrong, it’s a D11 R5. Would still love to have it modded.
D11 is the same thing internally, just different body and firmware. My first piston drive experience & mod was an 11.2.
I sent ya a PM.
Ill take whatever is left
That is too cool, great job!
Interested in the used one if other offers fall through.
CK hasn’t been around for a while. I wouldn’t hold your breath.
Lmao I didnt realize this post was so old. whoops.
I had sent a pm a few weeks back and didn’t get any reply yet. hopefully all is well!
can anyone sleuth out what driver Cereal_killer used from this info:
I dont know what a Mini GT driver is, yet…
nor what driver is in the actual lights that a couple lucky people bought…
is it a Lexel thing?
@Cereal_killer I hope you’re ok, and returning again.
Might you be able to convert one of my D10s with an FET & Anduril?
Possible, but CK frequently made his own drivers. Hard to say unless a purchaser speaks up.
Edit: yup, see here: What did you mod today? - #8285 by Cereal_killer
thanks
I guess thats keyword oshpark = custom driver, not commercially available…
I can’t make it out in the boards, where does the e-switch path connect?
It looks like something that could be put together pretty easily. But I don’t have a D10 or anything remotely close to take measurements with or to test it on.
a ring around the outside of the driver
that is contacted when the sprung split ring is depressed by the piston
pics are links
All you would need is an anduril driver with the switchwire connected to a thin suitably sized underside insulated copper or brass washer fixed onto the driver.
I asked Lexel a while back if he had any suitable drivers, nothing came of it. If it helps, I snapped some (bad) photos of my D11 driver and can be seen in Lexel’s driver thread .
