I received 2 black ShockLi 26650 5500mAh batteries yesterday and they both easily fit in the SP33v3
They were both at 3.85 volts when received and both charged to 4.2 volts at 1/2 amp. in an Xtar VC4
Hi BLFers and Sofirn Fans!
You can purchase direclty on our official website: www.sofirnlight.com now!
We uploaded flashlights, batteries&chargers. Some are the latest version, some are old models for inventory-clearance. Check all the products and see what you need! It doesn't matter where you are located.
Link: https://sofirnlight.com/collections/all
Furthermore, if you need some products online but no good place to buy, we can find the source and sell on the website at a great price!
oops, almost forgot the discount code: ALL$2OFF. Use it to save US$2 for your order. Only 18 times left to be used. First come, first served!
Any questions, please reply or PM.
Sofirn Team
I took some measurements of the SP33 v3.0 with the Texas Ace lumen tube calibrated with Maukka lights:
Sofirn SP33 v3.0 Turbo, 2991 lumens, 6810K, DUV â0.001, CRI 68.1, R9 â21.7, R12 42.9, Rf 62, Rg 97, Golisi 4300mah 26650
Sofirn SP33 v3.0 Turbo, 2896 lumens, Vapcell 5500mah 26650
Thanks for these measurements! 6800K, 68 CRI hmmâŚ
Nice info. Thanks.
6810K
Thanks SKV89 for the measurements. Would you happen to also have the Sofirn SP33 v2.0, and have the same kind of measurements for that model? So have an idea of the differences⌠Thanks very much in advance!
I do have the SP33 v2.0 but it is modded with 4xE21A
I am sorry if this seems stupid, but is 68 cri and 6800k good?
Thank you
Not to me, it isnât.
Thatâs going to be a fairly âcoolâ tint, and I much prefer warmer tints in the <\ 4000k range. Also, many CRI (color rendering index) ratings today are in the high 90s.
Now itâs true that a high CRI is not absolutely essential in a good light, but an icy cool blue/white tint does not appeal to me at all any more. In principal I like this light a lot, and if it had a warmer emitter Iâd be all over it. As it is, Iâm going to pass.
Thank you for the response.
From what little I understand a higher tint temperature is supposed to mean higher output. But according to what was posted above, the SP33 V3 does not make its 3500 lumens rating.
Donât let âoutput numbersâ lead you astray. Theyâre just numbers - and yes, cooler emitter temperatures do boast marginally higher numbers - but the overall usefulness of a light is judged by a lot more than an extra hundred lumens here or there. I can guarantee youâll never be able to tell the difference between 1,000 lumens and 1,100 lumens with your naked eye.
Itâs a bit like saying that a street rod will go 10 km./hr faster than a Mercedes. It might, but that doesnât necessarily make it a better car overall.
If you spend any amount of money on cool emitters for the simple reason of higher lumen numbers, it would be wise to brush up on your modding skills, because youâll probably be swapping them out before long. Thatâs where a lot of us beganâŚâŚme included.
I smile a bit when I read some posts on this forum debating the merits and faults of the range of Kelvin temperature LEDs in modern flashlights.
My youth was in the age of Lincoln Logs,Erector Sets,Gilbert Chemistry Sets and an olive drab boy scout flashlight that housed 2 Everready D batteries(notorious leakers).I like modern LED flashlights
Yes,the light's K temperature on an object will render observed color differently but of no concern when only adequate lighting is needed to find something in darkness or illuminate the path.
My SP33v3 with ShockLi 26650 5500mAhdoesn't appear to be too cool but that's only my novice opinion.My Nitecore EA41(2015)had a very easy to see cool blue tint but served it's purpose well until the copper tops leaked in it and it no longer functions.I'd like to rebuild it but for lack of knowledge.
I find the moonlight mode in flashlights useless but stepped low,medium,high and turbo quite useful.I'm on the fence with other functions.
Ah, erector sets. Iâm in agreement with you on ML or FF mode. At my age , the more light the better. And during the day, those very low modes make you look at the led to make sure it is not on before setting it down or putting it back in your pocket. They should be like turbo or strobe, not in the main cycle.
Added test results for all modes. Here goes:
Moonlight
Output: 2 lumens
CCT: 5292K
DUV: 0.0158
Ra (CRI): 68.1
Low mode
Output: 84 lumens
CCT: 6299K
DUV: 0.0035
Ra (CRI): 66.7
Mid mode
Output: 307 lumens
CCT: 6613K
DUV: 0.0008
Ra (CRI): 67.2
High mode
Output: 1277 lumens
CCT: 6740K
DUV: â0.0003
Ra (CRI): 67.4
Iâm not a fan of CW but it is not very blue like the cheap Amazon and Aliexpress lights. Itâs pretty good for gift lights because the UI is so simple.
I wish they made a 6V or 12V version with USB-C because you can mod those with some good tinted XHP70 emitters from Kaidomain
Thanks again!
The measured values diverge quite a bit from the official specs:
https://drive.google.com/drive/folders/1I_35e3aw3pNoMosh00ja-ZDvaW-3BtJE
Is it typical for CCT to vary so much, particularly that moonlight value? Is there any indication of the tint bin, if any? http://flashlightwiki.com/images/c/cb/Ansi-white.jpg
I havenât seen it in person yet, but Iâm thinking the CRI is the weakest point. I really didnât think I would care much about CRI, but after seeing the SST-20, I find myself slightly irritated by the hazy look of lower CRI light.
Yes it is very normal for CCT and tint (DUV) to vary that much. In fact this light is one of the more consistent ones except for the moonlight mode.
My TA light tube is calibrated with Maukka lights but I seem to be measuring on the low end of everyone with the same setup. The only manufacturers that I consistently measure higher than their official rating are Olight and Fenix. Emisar is âusuallyâ pretty spot on and sometimes higher or lower. All other manufacturers including Acebeam, Zebralight, Thrunite, Sofirn, etc. âusuallyâ measure lower in my lumen tube than what they spec.
Thank you for the responses.
I think I will pass on this light. The tint seems cold and the CRI is low. From what I have read on here this is not ideal. Also it does not seem to meet specifications.
I have zero buyer's remorse!
I very happy I purchased an SP33v3!
It's only a $30 flashlight/ w battery and serves it's intended purpose well.
Time will tell how it holds up doing it's thing.
