I just hope my sample will be as good as yours. With DX you never know...
Thanks again!
Thanks again!
One more thing Huny74.
When you receive the flashlight don't be disappointed if the lens looks total crap and soap and water doesn't make it clean. I had to rub it very well with acetone to get it in shape. Must be some protective layer applied to the glass while being cut to size. It's the first time it happens to me.
Good luck!
No, no. That's only what DX is calling "coated glass lens" :D
Even surpassing spec data, like the current bit!
Thanks for the review, agedbriar. I had to pull out my M8 when I clicked on the link. Except for the shinier finish, pretty close to exact match in most details. That is a great price too.
As promised, here are my lux readings, taken at 8m, luxmeter in Max-Hold mode.
61.3 kcd Small Sun ZY-C10-S aspherical (1.37A)
59.5 kcd Jacob A60 (1.75A)
47.3 kcd UniqueFire HS-802 (1.60A)
40.6 kcd UltraOK Tactical (1.75A)
As expected, the aspherical wins, but not by much and with a smaller hotspot and a less pleasing/useful beam. Note that I kept Jacob's current within reason by using a low-quality battery, as I don't want to overdrive it too much for now. Small Sun, on the other hand, got a Panasonic grey unprotected, and 1.37A is as high as it would go.
UltraOK was not at its best tonight. I already suspected that the original plastic reflector might have been better than the current alu C8 replacement, but didn't switch back yet. Anyway, the difference could only be small, undetectable to the eye in real use.
I apologize if I made the wait for Jacob even harder to some forum friends.
Well I'm going to buy one of these.
Thanks.
Thanks for the info. I'm $15 poorer now.
Yeah thanks for making us want to spend more money. This forum is dangerous for the wallet.
You are welcome, guys.
I looked up 'flashlightlens.com' for an UCL lens, but Jacob's size 50 x 1.9mm isn't available.
Just as well! With shipping, the UCL alone would amount to more than half the entire flashlight price.
I think I forgot to mention how delighted my daughter has been with that nice lanyard (I never use them).
What a bargain this seems to be. I have my thrower needs somewhat covered but seeing this makes me wonder if I should try to mount a XR-E EZ 900 to my X8 and drive it at 1,8 A. Just for the fun of it and to see what Lux readings I can obtain.... Decisions decisions.
Anyway super review. As others mentioned this is potentially bad for the wallet! LOL
That's my plan with the X9! I already have a new XR-E EZ900 for the switch. Stock driver, pulling 1.8A with the XM-L installed, should work fine.
But now little Jacob needs all my loving care.
AB, how wide is the hotspot at 3 meters distance? Hows the overall light output?Thanks
I was going to ask how wide the hotspot is at about 10 meters to compare to my Dongrui, but I guess I could compare at any distance.
-Garry
At 3m, hotspot size is:
Jacob A60 ..... 20cm
UltraOK ..... 18cm
HS-802 ..... 10cm
This relation remains pretty much unchanged at grater distances.
Jacob's XR-E ringiness is not pronounced, practically invisible at working distances (100-150m for me). There is no corona to speak of, only a nice soft-edged spot. Compared to an aspherical, the outer spill is quite bright, but less so than with any of my XM-L lights. Target image is crisp, there is no haze (the big issue with my X9).
Interested if any aluminium reflectors will fit too.
I looked up DX and didn't find any.
Dimensions are in post #14.
BTW, I applied thermal paste to the pill/head screws, without much effect. The stupid thread anodizing there seems to raise an effective barrier, unless the bottleneck is the emitter star to pill contact. Didn't try to lift the plastic insulator to see how the latter looks.
Yeah I saw the dimensions and looked a few places too without any luck.
Last night I spotted a deer at 75m. Jacob almost smoked her.
I think I heard some profanities coming my way...
