[M4D deal] Nightwatch NI40 with Luminus SBT90 Gen2 interest list OPEN
Vapewild.com
the LEDs have been "dicovered" by many manufacturers and are hard to get atm :(
Any indications on when neal will have stock to ship again?
Updating post #386
My NI40/SBT90.2 of the first batch stock “is not ship because of the shortage”, order #8378.
In mi account that order continues appearing FULFILLED.
The tracking number that appears corresponds to the previous order (received).
Two last PM sent to Neal, on December 6 and 12, with no response.
Neal was in BLF 4 hours ago but did not deign to respond…nor correct the order status in my account.
Summarizing…
Without any change in the situation.
Neal continues in radio silence.
I have two efest batteries but they seem to be too long to fit. I feel like it’s compressing the spring way too much.
There are many other batteries that will work well and have already been mentioned on this thread. ALL 26650’s of course
Vapcell 5500mAh,Orbtronic 5750mAh,Shockli 5500mAh
For a bit more output and Less capacity:
Golisi 4300mAh, Aspire 4300mAh
For now I have lost interest in this light and it is on the shelf until work is done on it.
I hike every night with my friend Randy and his Dog Max. Randy and I both love Turbo when on the hiking trails. I get enjoyment for 2 minutes of Turbo and then it is constantly stepping back up to Turbo every 60 to 90 seconds.It becomes Very annoying.
My Mateminco MT35[FT03] XHP50.2 NW has Narsil. I disabled the step down. The light never got too hot even in August.
When my NI40 is able to do that, I will enjoy it more than the MT35 because I like all the other aspects of the light.
I had filled out the form and submitted it, expected a notification when the lights would be ready again. Never happened, which is ok because I too have had so much problem with Neal getting it done that I no longer care to make a purchase if he’s involved. Sad but true.
So I’ll be looking for the 90.2 and will build my own Stalker if/when I find the emitter. In the meantime, the one I have here works pretty well with the original SBT-90. :slight_smile: (built a driver for it, hated the UI)
please PM me the email you left in the form
I want to check where your notification has been stuck
What? How you do that? My XHP50.2 NW FT03 gets hot quickly and definitely can’t sustain turbo for 4min+
Ran it 10 minutes on turbo tonight, changed battery and repeated.Not even close to hot. Temperature was 25F/-4C.
In the warm weather I can do the same. I have a high tolerance to heat. With this light by the time I pass the 5 or 6 minute mark the battery is certainly weakening along with the output, resulting in less heat.
+1 4 SBT90.2
Isn’t there an NTC that can be removed from the driver?
I do not know. I do not know how to work on these lights like a lot of you. A member on here is going to make positive changes for me. Completely eliminating step down,new driver, bypass springs ect.
Yes, I’m interested!
please use the form in OP
I have 2 orders from Neal but since it was out of stock I asked if he can replace it with one Acebeam K30GT since I can’t wait anymore. He agreed and I received it in 3 days… Also uses the same LED, SBT90.2
What version Ft03 is that?
It was the xhp50 version.
Ahh ok. The sbt90.2 version comes with the stainless steel bezel. I was wondering if you had one already.
