Noctigon K1 info / review
Here you go. Notice that both switch LEDs are lit. Both are fully functional.
So that’s the battery tube from the FT03 on the K1? Impressive! Is the K1 head light still water proof?
I have a question about battery choice for the K1 W1. In one place early in the thread it was reported that a battery capable of outputting more amps would have the extra amps converted to heat ad so be wasted. In another comment it said that a higher amp battery would be able to hold turbo longer.
Is it both?
Also, since the W1 uses 3 A less on Turbo it should have a much longer run time, right? Or does the extra power just go to heat? Am I missing something?
Bottom line:
What battery is best for the W1 version which will be used in the upper 1/3rd of the power range for 20-40 seconds then be off for minutes?
Thanks!
For W1 I think it has been agreed on Samsung 50E 5000mah is your best bet.
On the left side is the W2 larger hotspot. JoJo said in the video that the W1 on the right side is brighter
I think it is waterproof.
The o-ring on the FT03 tube does get fully compressed into the K1 head, but
the end of the battery tube can’t reach all the way to the driver board so I had to use a conductive spacer to complete the connection to the ground ring on the driver board.
The o-ring on the K1 tube does not get compressed on the FT03 head, because the tube contacts the driver before it is fully threaded into the head.
The threads on both lights match, but the threaded section on the K1 tube is longer than the threaded section on the F03 tube.
Also, the 26650 battery sets lower in the tube because of the spacer between the tube and head. The springs just barely make contact with the battery. A long, protected, 26650, or 21700 would work great.
This is just in theory since no measurement has been taken comparing side to side: Both drivers setting should draw about the same from the battery but while the W1 burns it off as heat W2 is being sent to the emitter resulting in extra lumens.
As the battery gets drained the voltage gap gets smaller and it becomes more efficient, with a high drain battery it will maintain turbo longer but overall runtime will be less. With a low drain cell it will continue to power the light much longer once it drops out of regulation when it doesn’t have to burn extra volt as heat so in the end you get a higher lumens-hour reading.
If you’re interested in highest output you should stick with high drain cells.
I would have thought that since the W1 driver is current limited to protect the White Flat then it only draws 5A from the cell, regardless of the capability of the cell. Or that’s been my experience in the last 1000 lights or so that I’ve dealt with…
Posted earlier in this thread-
I would not expect any performance differences between cells if it only draws 4.9A max.
Thanks, everyone!
@Gerrit: are your W10 and W30 the vn/skylumen version or they from somewhere else?
Dale is correct.
Runtime will be longer with higher capacity. At load as low as 5A, that’s it. End of story.
The report that the extra amps will be converted to heat is not really correct but probably is referring to the fact that the higher amp cell can maintain a higher voltage at a given current (because of its lower IR) and that means extra voltage to be burned off by the driver. But the extra heat is probably not significant.
Anyone else’s K1 just sitting at JFK? I ordered November 30th :frowning:
Same here, maybe the tracking is not keeping up with actual location? In any case, it will get here when it does…
That 26650 tube looks good but not the best fitting as you said. I wonder will D4S or other 26650tube fit that intl-outdoor can just offer both? I would buy it.
D4S and D4SV2 tubes are too wide.I ried a lot of different battery tubes and the only one I have that matched up was the FT03.
Took my new K1 W1 for a 5 mile hike last night. It is really amazing to light up a house on the other side of the lake, over half a kilometer away.
Great for spotting Opossums, Nutra Rats, Herons, Ducks, etc. Really freaks them out when you hit them with that blinding beam :smiley:
But, as was mentioned by others, this really is a specialized light, not at all practical for just walking around. It’s kind of an all or nothing type light.
So I just ordered another one with the XPL HI V2 5D :smiley:
I blasted a skunk the other night with my W30vn. It got freaked out and ran. I thought animals are not afraid of bright light lol.
arrived
