The end of Lithium cells ?
Meh, mine is so flaky, it only runs for an hour, then shuts down. Fail.
If I had a dollar for every battery breakthrough over the past 8 years, I could buy Panasonic’s battery division.
Chris
The question is: what looks very promising?
This is pretty sparse on details even for the over-saturated category of battery breakthroughs.
I’m sure they’ve got something interesting that is worth investing more development into, but announcements like this have been coming out from various companies and universities for years now.
Most of them seem to quietly fade away, although admittedly, the path to commercialization is often slow. The first lithium ion battery was tested in the lab in 1979, but it didn’t become a commercial product until 1991.
Brutal…
I saw yesterday,that the new Huawei phone has a new graphene battery,so it exceeds 5000mAh.
It’s not exactly a graphene battery though: it has a graphene composite battery.
Pure graphene compound cells have a looooong way to go.
Another note:
Having read and understood how graphene composite cells are manufactured (pure graphene compound cells have yet to come in mass production as mentioned before), they are actually cheaper per Wh to make.
But not to manufacture, as while it does not cost much to make in a lab per unit, the machines used to automate them cost a buttload more than the usual.
you also have to consider cost, cubic inches, and grams, to have a real winner
any battery can be 5000 mah, that doesn;t mean anything
the main thing in a phone is apparently the volume [size].
My understanding from this article is that it’s still a Li ion battery, but it uses a modified cathode and electrolyte.
Interested in new battery technologies. As long as it’s already for sale at NKON.
It will also soon be possible to extract current from the body. Then they will be able to operate in Leds above your eyebrows, and you will never again need a flashlight.
First thing I’m getting is red LED implants in my eyes.
Graphene is such a buzzword. I haven’t been able to find what exactly is this pure graphene battery? Is there a particular design of graphene battery that everyone is so excited about?
As you’ve said, I think all the so-called graphene batteries in production are just Li ion batteries with a slightly modified graphite anode that they market as graphene. Afterall a bunch of single graphene layers stacked together is just graphite.
Pure graphene cells are the ones you always hear about having massive charge rates, massively higher gravimetric energy densities, and are made of simple compounds.
Graphene composite cells are different in this regard: by using layered graphene sheets behind multiple ultra thin separators(which are really hard to make, a reason for being expensive), which allows for a higher surface area/mass ratio, and therefore, lower internal resistance.
On the other side, by having the same amount of surface area as regular graphite anodes, we get less volume dedicated to graphite, and we can put more energy dense compounds compared to what we usually put in.
Duracell AA
warning
satire video
AA car
Heh.
I’ve heard the claims, but what is the design of the graphene battery? Like what carries the charge inside the battery and what are the two electrodes?
Man, battery tech articles are like cancer cure articles.
I’m excited, but I expect things to arrive in the 2030s.
:smiley:
That is probably a realistic expectation. Things aren’t happening quickly.
