1. Try to simplify your circuit as much as possible. Just include a 1,2V source.
2. Putting 3 cells in parallel isn’t good for balancing, unlike with lithium-ion cells.
I mean, I’ve run NiMH in parallel before just fine. In parallel, the voltage will be the same 1.2V with just a larger capacity. The only thing you don’t want to do is charge NiMH in parallel due to the way voltage peak detection on NiMH chargers work. Charging in parallel is a good way to kill a whole bunch of cells at once, but I’ve never heard of draining them in parallel being an issue.
Part 2: Driver “Prototyping” (12/21/2019)
Sorry chaps! I haven’t had that much time on my hands as I’ve been waiting for parts.
I’ve come to the decision that since my circuit outlined above was basically a slight modification of a manufacturer’s recommended setup for their 2218 3v voltage regulator chip, I’d just buy one of those tiny factory implemented 3v boost circuits and go from there, as buying the parts to make the boost section would have cost me $25+shipping with a ton of capacitors and resistors left over since you can’t really buy what you need in small quantities, and if you did, shipping wouldn’t really be worth it. All I needed to do now was throw a resistor on the end of the circuit to regulate the current as voltage would be constant until battery voltage dropped too low. Also, this factory implementation is fairly efficient, so I wouldn’t have to go mucking around improving efficiency. I intended this light to be relatively practical, not just an exercise in manufacturing via blood (I’m clumsy).
Here’s my trusty old bread board testing out a 5v boost driver and 100 ohm resistor on one of rngwn’s 2300k 5mm LED’s This limits the current to 21.9 mA +/- 0.1mA with the resistor dissipating 38 mW.
You might be wondering why the hell I’m using a 5V boost circuit after saying I was going to use 3V? Wouldn’t that mess with my efficiency? Answer: Yes, it would definitely decrease efficiency as the resistor would need to dissipate more energy. However, when my LED’s arrived, I didn’t yet have a 3V boost driver, and as of this point, still do not although a pack of 8 is on the way. I still wanted to test the LED’s and didn’t have anything else. After trying both the 3400k and 2300k 95+ CRI LED’s, I found the 3400k to be too cool a color temperature for the lantern’s intended use and settled on the beautiful 2300k. Honestly, I might just buy a huge pack from rngwn because I love these little warm LED’s so much. I need to get more so that I’ll never run out and stuff them into everything. :D.
Part 3.1: Wood Selection and Layering
Tools to be used
Work area
After mulling over it for a bit, I decided to settle on poplar for my wood of choice for this build. If you’re wondering if that is a bit at odds with my intent to use a darker wood, you’d be correct. There were a few things that factored into this choice.
I took the board and cut six pieces of 3.5” x 1.5” x 0.25” to glue together in order to make a layered stock. Titebond Original Wood Glue was used as it is one of my two personal preference for wood glues, the other one being Elmer’s wood glue which I didn’t have on hand at the time.
Clamped together using 1.5” Hazard Fraught (Harbor Freight) plastic clamps.
It was as even as I could get it, but it looked like it could use quite a bit of sanding
Here we go with the sanding. 80 Grit 3M Sandblaster Pro! That sandpaper is great. It’s well worth the extra buck or two for a much better sanding experience compared to every other sandpaper I’ve ever used.
… Three Hours Later
Time to square off those ends with a Stanley saw and a cutting jig. You’ll also see the diffuser I intend to use, although in its base state. It’s a high quality Carlisle 1.5 oz. plastic shot glass that I’m going to chemically “frost” with paint thinner. Cheap and durable, though I had to buy it it in a pack of 24. Good thing I don’t intend for this lantern to be a one-off.
That’s all for now folks! I intend to round out the square body and make the fittings to hold the light diffuser/shot glass to the body. Also, a flared base might be in order! It might be a while before I find more time to work on this, but I promise I’ll update as soon as the next phase is complete.
I know that one
Good to see you making progress :+1:
The plan is taking shape.
Welcome to the challenge Asian8640 :) I’m liking the look of this “Dark Stained Wood, Brass, Copper, Dark Red”
Good luck, mate
I am eager to see what's next low lumen mate !
It is good to see the progress you are making.
I still have a pile of parts and an idea.
Looks like you have a good start Asian8640! I like your design of a “high CRI with the lowest color temperature possible to mimic low power incandescent.” Looking forward to seeing it all come together.
Part 3.2 Stock Removal
It’s time to remove the stock for a nice round base!
Wait a second….
CRAP…. I didn’t think this far ahead.
Not to mention I can’t saw straight down over long distances very well with the tools and skills I have.
This step is a FAILURE
BACK TO THE DRAWING BOARD!
Part 3.3 Lantern Battery Compartment 2nd Try
Let’s build this one from the ground up using the same construction methods, but in parts.
Note: Length width and height are with the chamber on its side as that is how I am building it.
First, the base and cover for the AA Battery. It should have been a 55.4mm length x 14.6mm width x 14.6mm height chamber but I decided to give myself a little wiggle room. It ended up being within .1mm of 15.5 for both width and height as far as chamber width is concerned.
Then the top and the bottom. Top: 15.5mm length x 15.5mm width x 16.1 mm height. The bottom 18mm length x 15.5mm width x 16.1 mm height
Those parts are finished!
Time to make the sides in the same manner. 88.9mm length x 12.7mm width x 40mm height.
A little clamping
A little sanding
A little test fitting
And a little gluing
Part 3.21 Interlude: Paint test, light diffuser frosting preview, and potential dimensions for the top of the lantern.
I decided that staining the wood might not be the best idea in winter weather. I don’t have an area that is both dry, warm, and contains sufficient ventilation (no fume hood anymore) As such, I decided acrylic paint with clear lacquer over it might be a better fit. Here is a test piece using left-over wood. The center is FolkArt Imperial Red, the right is FolkArt Real Brown, and the left is Nicole’s Craft Studio Dark Chocolate. I’ve already decided to use Imperial red due to how saturated it is, but I’m leaning toward the Real brown versus the Dark Chocolate. What do you think?
I got a little lazy and forgot to document the process of testing out different ways to get even diffusion. While I do have each of the failed finished products, I don’t have as many photos of the in-between steps. Here’s a preview of one I tried with varying grits of sandpaper from R80 to R600 grit sandpaper.
EDIT: UNCLE SAYS ONE MORE THING! I might not be able to implement copper in this build. I think I’m going to stick to brass as most of the washers, screws, and nuts I have purchased are brass.
Nice comeback Asian8640. Its coming along nicely.
Hey mate! Thanks for the visit! However, this isn’t your 5mm LED sale thread. It’s my BLF contest thread. I’m honored that you’re following it, but you probably should re-post in your sale thread.
Looks like you’re making good progress!
One thought if you still want to have variable output is to use a potentiometer (perhaps one with an off position) to vary your resistance. Cheap and simple.
Thanks for the thought! However there were a few reasons I ruled out a potentiometer. The first would be repeatability of run times. All I want is 2 modes, low and high with predictable battery life. Second, audio taper pots, which is what I need as the way we interpret magnitudes of light and the loudness of sound are both logarithmic functions, may not always be available in a replacement size. Mechanical switches will be around in their current form for a very long time.
Nice progress Asian8640
Part 3.3 Diffuser Tests
I previously mentioned that I would use Carlisle shot glasses made of plastic for the diffuser.
My first try was using sandpaper of different grits to frost the surface. While it produced a very even distribution of light, the frosting wasn’t as even no matter how I tried.
Next, I tried using lacquer thinner. That turned out to be a disaster. I didn’t have the correct ventilation and I couldn’t get an even frosting. Not to mention the light was horribly distributed.
I tried the old reliable Testors DullCote. Not so reliable this time. It pooled on the plastic making spots on the light even after 2 coats. It also was rather fragile as it didn’t stick to the shot glass.
I finally decided to return to the first method as it gave the most even light, except this time I used a scotch-brite pad for nice even frosting. You could still see streaks, but they were small and relatively uniform. Success!
*Part 4.1: Gluing the Top Cover
This is two layers of poplar cut to 60mm with a coping saw and held together with two 4 inch squeeze clamps and ye olde reliable 6 inches I “C” says the Clamp.
Part 4.2: Drilling the Center Hole
This is where I learn that I can’t drill a hole straight enough with a hand drill. That drill is about 70 years old. It belonged to my grandfather from before my father was born.
Part 4.3: Rounding the Edges of the Lantern Body
Reminder: The following was done with 80 grit sandpaper, 2 hours of elbow grease, and 2 hand cramps.
Part 5.1 INTERMISSION: Free Drill Press Restoration
Due to the kindness of a family friend, they gave me a drill press that was ancient when they received it in 1980. It had been sitting around doing nothing, so if I could clean it up, it was mine. I didn’t take many photos of the process as I was so happy to have one, despite its shortcomings. These are the photos I was able to take. If anyone can tell me how old it is, I’d be really happy. The family friend thought it was from somewhere around the 1930s or ’40s.
When the drill came to me, it was absolutely covered in layers of grease. It took about 2 hours of crud cutter to remove it all. The rust was subjected to a brass wire brush and vinegar bath with ultrasonic cleaning where possible.
Lucas Oil Xtra Heavy Duty Grease was used to re-lubricate everything. The green stuff does its job well and doesn’t wear away even under high temperatures and fast-moving parts, neither of which apply to this drill press. It’s still a fantastic grease though
All Done!
Part 5.1: Attaching the Tee Nut
I decided that I would attach the diffuser to the body using a Tee Nut and a #10-32 Stainless Steel screw.
Here is the first time I used the drill press. I drilled a 6mm hole and tapped it in with a small mallet.
Part 5.2: Drilling the Hole for the Switch
I decided to go with an SPDT 3 position sliding switch. The center is off, the top is high, the bottom is low. I used a 5.2mm drill bit and filed the rest. I did clean it up but forgot to take a picture of it. The lighting isn’t good in the work area and while I would use my flashlights, diffuse daylight makes for better pictures with a crappy smartphone camera.
Part 5.3: Drilling and Dremeling out a space for the boost driver
The main cuts were done using a 4.8mm drill bit and the drill was stopped at the correct depth using masking tape around the main pole of the drill press. The Dremel was used to smooth things out and widen the space for the two resistors that would be above the driver. That little extra depth is to fit the inductor, which is higher than the rest of the parts.
Part 5.4: Removing the Test Paint and smoothing out the Top
I had tested the red and brown acrylic on the failed top but decided not to waste all the work. The top could always be centered by the acrylic which would hold in the LEDs. I also used the drill press and 80 grit sandpaper to even out the circumference of the top relative to the location of the center hole. It also had the benefit of decreasing the overall diameter so as to interfere less with light from the diffuser.
Part 5.5: Test Fit
Now it’s starting to look like a lantern! I’ve decided to stain it with Old Master’s Burgundy Wipe Stain and Minwax water-based polyacrylic for a much more even finish. It will take more coats but I’ve gotten better results compared to oil-based polyurethane. I still need to drill the guide rods that will prevent the diffuser and top from moving, install said guide rods, create the LED board, wire the LEDs, install the contacts for the battery, and drill the hole out to install the magnets that hold the battery cover. We’re getting close and I’m happy.
Of note, I found that this process is taking WAY too long to make more than one. After this one is done, it’s back to the drawing board as I’ve got eight more of these suckers to make and place around the house. I can’t be taking this long. Guess we live and learn :D.
A beautiful looking lantern Asian8640! Can’t wait to see how it gets completed.
Hey! That looks very nice!
I use nothing but Minwax polycrylic for clear coats. I especially love the fact that it adds no color of its own, unlike the oil based products.
Looking nice!
Actually I intend to do add some diffusion to a certain TIR lens in a couple of weeks, it’s nice to see your experiments.
