Apollo Max graphene power bank
https://www.indiegogo.com/projects/apollo-max-the-power-bank-recharges-in-19-mins
I did not understand what level of charging current was selected for this device in order to fill this battery with a capacity of 10 Ah in 19 minutes?
Depends on its battery configuration volchyonok. For starters, it has a 37 Wh rated battery and is powered by 100 W USB PD input so, technically speaking, if both its internal converter and battery were 100% efficient, a fully discharged 37 Wh battery charged at a rate of 100 W would take t = 37 Wh / 100 W = 0.37 hours. This is 22 minutes and 12 seconds so, without any need to refine my estimations even further by taking into account losses, we already now the claimed 19 minutes recharge time must be a lie.
It could also be that the battery capacity is actually lower (a different lie) and it meets the claimed time.
Concerning recharge current a 2S 5000 mAh graphene lithium battery (7.4 V nominal) directly connected to its charging converter would need between 16 and 17 A (I presume) of charging current to go from 0 to 100% in 19 minutes. My quoted range is because it depends on how low the internal resistance of the battery is (should be ultra low).
If the new battery has low internal resistance, then due to its charge with high currents, this resistance eventually starts to increase noticeably, quickly turning the new battery into the old one. Unfortunately this is the case. Long-life batteries turn into fast-discharging capacitors. Therefore, batteries cannot be charged with excessively high currents, and a sufficient amount of time is required for a normal life resource to charge.
The Apollo Max is a gimmick for people who wipe their asses with $100 banknotes. :-))
It is a USB power device and, unless the brand donates a review unit or a bunch of people here (!) raises funds to buy a review unit, no chance to see it reviewed.
I think that such a device will be useful for showing it in feature films when it comes to fantastic action films and when there is not a single extra minute during some scenarios in which everything happens very quickly. It is on the TV screen that people will like how their main characters steal information from their enemies, who, according to the plot of an interesting film, wanted to completely capture all the states completely. However, in one of the scenes, the good guys who will fight the criminals and want to save the world, at a crucial moment, the energy needed to save the USA suddenly ran out. Therefore, they urgently needed to charge their batteries. So, when they plugged it into an outlet, then interested viewers will be able to see how literally in a matter of minutes before their eyes the rescue heroes their battery will quickly charge, because rapidly growing numbers will appear on the display during charging. And after the successful completion of charging, the beloved heroes will finally save all of America. Is this happiness not worth some 100 dollars?
Vapcell 26650 5300mAh
Supposedly Vapcell has a new 10A capable 14500 that was released early 2020 as well.
Is there a review for the Xtar 4200mAh 21700 battery? (I think Xtar bundled a piece or 2 with the Xtar powerbank/chargers sent for review to HKJ).
I was able to order a few of these when I bought Xtar powerbank (that’s the only way I was able to purchase Xtar batteries — need to purchase an Xtar powerbank/charger and ask them to include batteries with the Xtar powerbank/charger).
They seem to be slim and short — one of the shortest 21700 I’ve encountered (they will fit in a Lii-100 or a ZanFlare C4 charger, where other 21700 batteries do not fit the Lii-100 nor the Zanflare C4). Also, using YR1030 internal resistance tester I got AC IR of 9.5mOhms, which is one of the lower IR values I’ve tested for 21700 batteries (I’ve only tested the Samsung 40T and 30T to have lower AC IR than that Xtar 4200mAh 21700)
It is a very long time since I have reviewed Xtar batteries, they always send one of each type and I need two for a review. I have told them that.
I was too fast to complain abut Xtar, I already had a box from them and it contained some 18650 batteries for test (No 21700).
Hoping we could request Xtar to send you their other Xtar batteries (in pairs) so we have an idea how they perform.
So far, I can only order Xtar batteries only if the item has an option to include batteries. And I have ordered a few 14500 (Xtar 800mAh 14500 flat-top) and Xtar 4500mAh 21700. When I ordered Xtar powerbank with 18650 batteries, they didn’t include Xtar-branded 18650s but instead gave (genuine) Samsung 30Q 18650s) — it was not specified what kind of 18650 to be included with the Xtar powerbank when I made the order…).
So right now I’m interested to know how Xtar batteries perform (in particular, I’m getting low AC IR for the Xtar 4200mAh 21700, and they’re about 1mm shorter than other 21700 batteries — making these Xtar 21700 batteries fit properly on the earlier Fireflies PL47 and Fireflies E07 which will dent other longer batteries like the Liitokala Lii-40A 4000mAh 21700 battery due to these batteries being a bit longer)…
… When I ordered Xtar powerbank with 18650 batteries, they didn’t include Xtar-branded 18650s but instead gave (genuine) Samsung 30Q 18650s) – it was not specified what kind of 18650 to be included with the Xtar powerbank when I made the order…
Interesting. This leads me to think Xtar is rewrapping Samsung 30Q cells. On the other hand, unless that powerbank uses very few cells and has a pretty high output power (super unlikely), there is no reason for it to use high power cells. I would keep the 30Q cells to feed power hungry flashlights, and employ some inexpensive energy cells in the powerbank. Check out some BAK 18650-34Ts in disguise.
Sat, 05/02/2020 - 06:23
Hello! :-)
I just found some new, interesting 26700 LiFePO4 cells:
That is the highest capacity and energy density I've ever seen in LiFePO4 chemistry. Edit.- Well, not exactly as (for example) PLB has some 3800mAh rated 26650 LiFePO4 cells. But quite close.
Some inexpensive seller sale links:
Thu, 06/11/2020 - 22:35
Hello!
This is just to ask if someone else besides me would like to see the new LiitoKala 26700 4000mAh LiFePO4 cells reviewed. I could send Henrik a couple of the above cells for just under €6 (got a €0.83 coupon), and I was wondering whether someone else would send me a small donation to share the costs, like €3 from one source or €4 total from two persons.
So say something while I ask Henrik if he is willing to make such review. Thanks. :)
Vapcell now offers 26350 cells. They are 2000 mAh like the generic ones and 6A doesn’t suggest that they are any different but maybe?
Would be nice to see them tested.
http://www.vapcelltech.com/index.php/List/index/cid/99.html
HKJ - firstly, thank you for your reviews, which make you an international treasure IMHO.
Is there any chance of reviewing Soshine’s (new?) batteries with built-in USB ports? I have recently purchased them in 26650/5500, 18650/3600, 18650/2600 and 14500/700 sizes, and it would be wonderful to learn just how good (or bad) they are.
A link to where I can get them would be nice.
Ah, yes. Well I’m in the colonies (South Africa) and I bought them from a local distributor here, so I’m not sure how useful that is to you? I’ll PM you a link, in case it’s of any use to you…
Probably not very useful. If he will sell to me, it will cost a fortune in shipping.
How is your queue looking these days for li-ion cells?
