As others have said, and i’m not a grandma either, it would be very nice to have stepless dimming (and without PWM) by a thumb wheel or slider.
Sure, you could make it click (with ‘detentes’) in 4 positions (OFF - LOW - MID - HIGH), but if you use only 1 hall sensor, it will probably determine the output level according to the magnetic field it senses anyway, so the positions in between the clicks will be brightness levels in between the 3 ON positions.
It doesn’t have to start at some silly firefly mode, especially for the elderly, which can make you think you have turned it off, like the Sofirn SP10A for example…
The only reason i have never bought a thumb slider diving light is because of the PWM they all seem to have…
But for the user interface it’s far more natural, physically and psychologically and also ‘old fashioned’ to switch the light on and off with your thumb by moving a button forward and backwards.
So i.m.o the ease of use for the elderly (and in fact for anyone) would not be optimal with a twisty ring.
IMO, the only drop-dead simple light, which is a no-brainer for anyone to use, is one that is either on or off using a clicky switch.
A rotary switch with three distinct levels of brightness, starting on Low, then Med and then High seems to me, to be the next simplest thing and has the big advantage of three levels. 50 - 200 - 500? Everything else is just confusing if you are not a flashlight freak.
A TIR sounds okay to me as I do not think the intended user base needs a light for throw. They want to find stuff in a dark place, see where they are about to place their feet when walking, etc.
USB charging is a big plus. A C-type port with resistors Behind a rubber flap has the advantage of being visible and may be better for the memory impaired. ? Just a thought?
I can think of two people/places I would use them.
I’ve had 2 lights with magnetic ring switching and i didn’t like it at all.
Tended to need 2 hands for turning it on.
They were not the best examples of ring twist switch lights though, so maybe i’m biassed.
A sensible and well built flashlight for the masses. No crazy UI’s, no ridiculous blinkies, it won’t set puppies on fire and you can give it to anyone. I am wickedly pleased to hear this voice of reason. Don’t hide any modes anywhere. The more you try to hide the more complicated it becomes. We all have lights that are overly complicated and too bright for their own good.
This is the single best post of 2019. Why? It’s reasonable and logical, both seem to get lost in a sea of hot rods and overpriced lights. djozz, I salute you sir. Put me down for half a dozen.
Don’t you or Sofirn bend on the shear simplicity of such a light. TIR would be sufficient for most but, it would be nice if you could swap in a OP or pebbled TIR if you so choose. Still not a deal breaker.
@hank, My Jetbeam RRT01 has a hidden strobe by two fast rotary twists to max, and while fiddling with the light it unwantedly comes on (no problem for me, I know what happens). And fiddling is something that non-flashoholics are far better at than we. I want this light to have no surprises for the users.
@jerommel, the 10 lumen lowest mode is easy to see, well above firefly, a good reading level.
I have no objection to infinitely variable but for this (budget) light it is a luxury I think. But once the design starts (in case we ever reach 1000) I will ask if it can be done without adding costs. I know that Sofirn makes stepped magnetic drivers, I do not know about infinitely variable.
About a slider: since this light must appeal to flashoholics too, not just arthritic eldery people , IMO a magnetic ring is a much nicer choice and easy enough for almost everyone.
Btw, I still must send you the Luminus Cube leds
@MtnDon, I will ask for the resistors, that seems not like it is making anything more expensive. The USB port behind a flap may prove easiest and cheapest in the end for Sofirn anyway, but I still hope for a less ugly and robust solution.
In for two. The details of final design are less important to me than the fact it is made with “grandma” in mind… you guys and Sofirn will do your best with that. BTW, the waterproof ness is not mentioned in the specs. Looking forward to a great “gift light.”
The waterproofness is not mentioned but since all our flashlights and all Sofirn flashlight have that I think it is not needed to mention. It is mentioned that this light is based on the SC31 which is waterproof.
If the thumbwheel/ring/whatever were oversized, either heavily-knurled or at least knobby, and ideally a contrasting color from the body, then it should work for gramma.
Yep. That’s why I gave my gf my ’10A, as it’s one of the older/original ones that goes l/m/h and 2click for strobe, vs my ’10B which is f/l/m and 2click for h and 3click for strobe. There were times I had to look and see if it were off or just in firefly mode, so didn’t want to burden her with always having to check it.
But why?
I think there are definitely nicer twisty ring lights on the market than there are slider lights on the market, and the slider travel is often quite short (maybe a limitation of the 1 single hall sensor they use?)
My limited experience with twisty rings (2 lights i took apart long ago, one i actually threw in the trash, which i never do otherwise) was not positive.
With one of them i needed 2 hands, and the sideways movement of the thumb is less natural and less powerful than the forward / backward movement, but i can only guess that’s also the case with arthritic hands (i’m not that old yet, so i don’t know…).
I’ll send you something in return when i get them.
I have no idea if Sofirn has expertise in this. The specifications in the OP are a combination of specs that all can be found in one or more Sofirn lights, which in my expectation helps in the speed and costs of this project. But asking does not hurt, it may just be no problem to do the infinite variable or this type of dimming.
It seems i have what you describe as ’10B (wasn’t that the colored body version?)
I quite dislike the light for that firefly mode, actually.
Just like the Astrolux A01…
And the jump to the next mode is huge too…
May the Dark Purple Lord B’harni (pbuh!) forgive me for saying so, but strangely enough the eee-vil Tac-Light you see on teevee comes close. It’s got a tailswitch driver, a nice big fat (yet slightly recessed) soft-touch tailswitch, and it just has one simple main cycle with no multiclicks nor holds nor anything of the kind. It has h/m/l/strobe/SOS/off.
Trade those modes for just l/h/off or l/m/h/off, but keep the tail-driver, and you can have a winner. Easy to actuate even for arthritic fingers, nothing complex about it, just chop off the head and put the appropriate TIR or whatever you want.
I got a 4×AAA LuxPro that comes close. Same tailswitch driver (uncapping and shorting makes it just come on high) can be used with the same feather-touch switch-button.
There are 20mm stars that have 1- or 2 7135s already mounted (or at least pads to do so), to make it simple-stoopit to fire up the LED while limiting current. Regulated, and no ballast resistor needed nor wanted.
I’m in!
I’m a tir guy so that’s a big plus for me.
But I would prefer (and not only me) 4000k instead of 5000k.
And smooth brightening like RRT01 instead of 3 modes.
And maybe the 21700 version?
That’s the whole SP10 saga. There was the original ’10A as I described, then the newer ’10B also as I described. But then the black ’B became the new ’A, while the same new red/blue ’Bs stayed ’Bs.
And then there were newer UIs in ’As or ’Bs or whatever, then the ’S, and other variants which still make my head hurt just thinking about it.
I got enough SP10s that I really didn’t need to buy any more, so that keeps my brain from exploding.
One of my often used and “can you lend me a flashlight” is my Nitecore SRT6. I really like it’s easy UI, forward clicky at the tail and the rest is done by the magnetic ring.
I think everybody who has Electronic dimmers at home will understand that.
What I do not completly like about it, are the blinkies, hidden behind their detents and that you can turn it off completly via that dial.
In my eyes on/off by a forward clicky and infinite ramping starting at moonlight would be perfect.
I simply do Not know anybody needing blinkies.
And from what I’m used to by my Dad, let that blinkies be hidden in the very last closet in the very last corner. They will find them!
Hit the switch - light
Turn the magnetic ring - more or less light.
Not much to explain.
