Interest collect for a new Sofirn design: tube style18650, magnetic ring control, USB-C charging, 500 lm max (AKA grandma light)
In for 3.
Seriously, put on your spouse’s eyeglasses and a pair of welding gloves, and see how easy it is to use the device.
We’re all in denial about what abilities we’re going to lose as we age.
Interested for 2 units.
:innocent:
In for one depending on emitter options.
A minimalistic low battery indicator makes sense for this light, people are used to such indicators already and they are very helpful.
Something like a tiny led near the charging port: off when battery level is sufficient, red blinking when battery is low and charging is adviced, red when charging, green when fully charged.
I put it on the wishlist.
In..for at least 1
Just worried about parasitic drain and the 'easyness' to open and 'replace' the battery.
I am in for one please
An idea for a battery condition /charging indicator….
When the light is turned on….
Blue light constant on (Turned off after 5s) = Battery 100~85
Blue light flashes (Turned off after 5s) = Battery 85~41
Red light constant on (Turned off after 5s) = Battery 40~16
Red light flashes all the time the light is turned on = Power less than 15%
When USB is plugged in, a constant red indicates charging taking place
When USB is plugged in, a constant blue indicates charge is complete
Sub green for blue if desired
Sounds wonderful for my own lights, but is confusing without a manual. Hence the simple red/green indicator that I described above, even without manual most will have an idea what is going on.
Interested :slight_smile:
interested for the magnetic ring! please add me to the list!
So true. Have to be able to use it without a user guide. So few things are made like that these days. Have to keep it simple for grandpa. Wait a minute I am one @73.5 …… (most days I don’t think I feel that age, but I’ve never been this old before, so am not sure)
In for 2
Interested.
Interested - sounds Good.
We passed the 100, so 10% of the needed interest is met in little more than 1 day. I’m happy about that. Lots more needed but I feel that I can already show Sofirn that this light has potential. :slight_smile:
interested!!
Over on TLF there ist also a survey based on this Thread here.
It seems there is also a large demand on such a ´grandmas light´
Sofirn AKA grandma light - TLF Interessenten Abfrage | Taschenlampen Forum
At the moment there is a demand on nearly 50
Make sure it doesn’t have to require having the light turned on for the USB charging to work.
I have a couple of lights with that requirement and they’re quite confusing to new users.
