Interest collect for a new Sofirn design: tube style18650, magnetic ring control, USB-C charging, 500 lm max (AKA grandma light)
Oh, i just thought of something else:
For an elderly person, or perhaps for anyone, although there are drawbacks too…
Thinking of a mechanical motion detector, like in automatic bicycle lights, but implemented differently.
I’m thinking of a blinky mode of some sorts (SOS ?), activated when the light hasn’t moved for, say 5 minutes (or less?).
It alarms the user who forgot to turn it off, but it also functions as an emergency beacon, for when the user stopped functioning… …so to speak…
The drawback is that you can’t use it tail standing for more than those 5 minutes…
It’s always released before Christmas. :wink:
Interested in 3.
I’m in for 1.
drillbit
I’ll take one.
Good. Because the term is highly patronising to senior citizens AND to BLF members who when it is done right see below gonna want to EDC it themselves anyways because the light corrects all the shortcomings endemic to what is available till now.
Project needs a decent working title.
The underpinning philosophy is that the ideal of a great design always functions as a great design regardless of the user(s). Everyone rest assured that we are most definitely trying to create the best i.e. most usable hand held single cell light of its cell class. That means its fool proof. I stress that there is no need to try and think of something to be spastic friendly. Pardon my deliberate non-pc rude term to stretch a point. By creating the best i.e. most ergonomically usable light so what it does it does really well, one shall already de facto create a product suitable for senior citizens. It kills two birds with one stone.
Yes, absolutely if it’s really thought out and done right then I you and any BLF nut gonna want it. Making it good means you make it foolproof hence reliable and inherently usable to ALL people in ALL situations. As an example; Is a hypothetical end user going to want water immersion resistance to IP8X and beyond? … Some will. It doesn’t harm.
Yep. But I am going to vote in this day and age magnetic charging is a must. Either instead of, or ideally together with usb. We want it BLF Nut Pro right? No nonsense quick and indestructible charging connect is the way to go. Think Olight, Klarus, Rofis.
USB=PITA !!!
Good point. As a rule outdoor use demands something like x10 lumens compared with working indoors for comparable tasks. Note for battery choices.
Professional grade end-point voltage control for floating the cell allows keeping any battery on charge indefinitely. I’d hope that corners would not be cut.
Except that it likely involves potentiometer sensing. This would be difficult and expensive to make robust and leak tight to be reliable. IMHO Hall effect stepped switching is optimal ideal with the on-off provided by mech clicky switch for zero standby parasitic drain.
interested if with infinite variable control ring
and very warm Led
That is not the flashlight of the OP.
I will add that to the wishlist
Sofirn made a new version of the SC31 with more lumens, so I would not be surprised if such a version will be made after this one too.
@No-2-Ageing, as said before, I will not allow this light to become bulky or ugly, so a “bone shape” will not happen if it is up to me.
But adding a subtle anti-roll structure to the design could be useful, added to the wishlist. :slight_smile:
Btw, some of you guys have pretty extreme ideas about ability loss of old people, most old people I know can physically operate a flashlight fine. Of course there is a category that is actually physically disabled and this flashlight is not for them, maybe a 2D Maglite is a better gift.
I almost wished that I left out the term “grandma light”, even though all grandma’s I know will be fine with the light of the OP.
Wow, that helps a lot, thanks for starting that. I will follow the list on TLF to get accurate subtotals
Control ring, I’m in Jos.
That is my opinion as well, aim no 1 that I will not let go is making a good flashlight, and that will naturally be a good flashlight for all kinds of people.
Btw, I find “grandma light” not that patronising and I doubt that many senior citizens will, but that may also be the european in me. It is a reference to older discussions on BLF and has a function in the title as such, even if the term does not fully overlap with the light that this thread is about.
I don’t think he means it should look like a bone, Jos. :laughing:
He means that the head and tailcap diameter should be larger than the battery tube.
This is not uncommon in flashlights, it usually looks good too.
The actual design will be done by sofirn anyway, then we can ask for a couple of adaptations if needed.
I’m in for at least two
Chris
I’ll commit to at least one or two.
Put me on the list for one. Looks like an interesting project
Add me to the list
