Thank you for bumping this thread. I was wondering the current on my Acebeam K75. All the other reviews didn’t have it. Nice! Now if we could just get the Vf curve…
Tonight or tomorrow I will set it up on the bench and take some more readings.
I brought a second one and plan on scratch building a host with better cooling for the other. Now i have a k75 host thinking an osram LED with L4P driver.
yeah… throw… woooo it’s de-domed… :money_mouth_face: Heat not so much these Big Luminus LED’s are current hungry, they pull big amps…and are tough as iron nails…
I took the window off the led
The k75 as a host is light weight with a huge reflector so i will put the 2mm2 osram and led4power driver in it, see how it goes. The astrolux battery tube fits and I have changed the battery carrier to 4s which fit the acebeam tube. However the acebeam carriers dont fit in the astrolux tube
I am waiting for more leds so i will do a test with Q8 driver and the sbt-90 from the k75. I have a host knocked up for test.
The k75 driver and led will go in a aspheric with a collar and 150mm lens with 177mmFL. i have done some tests without the collar and and 145mm lens, looks like it will be alright
Yes this is what I find as well. My low voltage indicator starts blinking when on Turbo mode and my batteries are at 3.5 volts. The light then shuts off completely as the voltage sags below this. I stick the batteries in my VC4 charger and the dial is 3.5v
