Can’t you just hit that Ti with some fine emory cloth to chill out the knurling?
I mean I know you use your flashlights and appreciate the patina, so why not accelerate the wear pattern a little?
Also maybe take a fine wire brush across the threads to take away some micro burrs maybe.
Just a thought.
Later,
Last night I managed to open the pil with boiling water method. Replaced the LED with Nichia Optisolis and TIR optic from Clemence with a bit tweaking.
Sorry no picture. My phone is broken and awaiting for replacement.
@Jon_Slider WOW that 3500k e21a is great! I’ll be getting some of those for sure!
3500k should be my preferred cct but till now I’ve been let down by tint in other emitters I’ve tried, the e21a looks perfectly white in that comparison, how is it in real life?
I really like the 3500k e21a, when my brain is white balanced to incandescent (3000k). At that white balance the 3500k does look white, as in this picture
I tried a few N219b 3500k 9080, and they shed more of a yellow cast over everthing. The e21a shows crisper reds and blues. It is my personal favorite 3500k LED, with an emphasis on High R9 CRI.
in all fairness though, there are times when my brain is whitebalanced to daylight, and then the 3500k is not my preference, because it looks warmer (oranger), than daylight.
this photo attempts to show the effect of daylight white balance, and reveals that the 3500k is a warmer white than daylight.
6000k XM-L2 on left, 3500k e21a on right (same light that looks “whiter” above)
so in my real life, I love the e21a at night, and still rely on sw45k for daytime edc, because it is “whiter”, at that time of day. In the evening sw45k can be unnecessarily cool (blue).
I did the same but just used a 4000k 95cri SST-20 I had laying around. VERY easy mod as the heat liquified the thermal epoxy under the mcpcb as well. Lost some output, naturally, compared to the xpg3 but its a very pleasant beam still. Hows the output of the Optisolis compared to the xpg3? Is it a direct swap or do you need to change the reflector/optic also?
The output of Nichia Optisolis was a bit lower but barely noticeable (at least to my eyes).
The optic is shorter than the stock reflector so I inserted a sanded aluminium pill (with extra thermal paste in between) under the current MCPCB to gain more height.
Drop Tool is on the right, the left was ReyLight Tool.
The LED swap is about as easy as they come. Just put the head in a plastic bag and dip in boiling water for 30 sec to 1min. When it comes out the pill unscrews easily. The heat also softens the thermal paste under teh mcpcb. Just unsolder the wires and then you can easily reflow any 3535 LED in its place.
You’ll never guess how mine arrived…submerged in water…Just how I like it! How did they know?!!
Ok seriously though how did they manage this? It came after nearly 6 weeks soaked in water. I think maybe they left it to dry cause the inside was wet but the outside wasn’t. Luckily the torch was in a sealed packet so the water couldn’t touch it. They also sent me the XP-G3 ugly cool beam version.
At first no modes worked, then 1 worked. Now there’s 3 but the third is the same as the second. Will the others start working as the capacitor charges?
Check your batteries mine does the three modes fine, but if batteries aren’t the best med/high on mine is same output, High mode on mine only works properly with alkaline and Eneloops
Be careful, Jon. Safe tritium installation is usually a recessed slot where the vial is protected more than 180 degrees. In this case, 270 degrees is exposed. Vials are very fragile.
the vials are embedded in adhesive, not just stuck to the side. But I took your warning to heart and added another drop of Norland to make sure the vial is completely encased in clear adhesive.
At this point I do not fear the vial breaking, but I will report back if the adhesive fails and the trit falls off or is damaged from pocket carry.
