Nightwatch NI40 modded with SST70 6500K dedomed and XHP70 boost driver
Recently I have swapped the dedomed 3V XHP50.2 in my Nightwatch NI40 for a dedomed SST70 6500K. As the SST70 is a 6V led, I had to use a XHP70 boost driver. The boost driver is from MantaRay, has four modes and delivers 5A. In comparison to the dedomed XHP50.2, the shaved SST70 has a smaller hotspot with more throw, produces less heat on turbo and is maybe slightly less bright.
I shaved the SST70 6500K close to the phosphor with a razor blade to get more throw and more neutral white light color. It is a bit above 5000K, maybe around 5500K and has some green in the beam. Below some fotos:
Close look at the shaved SST70
If you shine a light from the side at the led you can see that the bonding wires on the phosphor are soldered to a shiny dark green pad.
Some whitewall beamshot comparisons (all at 5000K, 30cm from wall, flashlights from left to right):
Nightwatch NI40 SST70 shaved ~5500K, Sofirn SP31 V2.0 5300K, Wildtrail BLF D80V2 SST40 5000K
Nightwatch NI40 SST70 shaved ~5500K, Astrolux FT03 SST40 5000K, Convoy C8+ SST40 5000K
Nightwatch NI40 SST70 shaved ~5500K, Sofirn C8F XPL HD 5200K, Emisar D4S Nichia 219C 5000K
Nightwatch NI40 SST70 shaved ~5500K, Sofirn SP70 XHP70.2 5000K, Convoy L6 XHP70.2 4000K and resistor mod
Outdoor beamshots
Comparison of the dedomed XHP50.2 and the dedomed SST70 in the Nightwatch NI40 (3.2s, F7.1, ISO 400, different seasons as you see, tree at 150m). The different sizes make a comparison a bit difficult. The XHP50.2 has a bigger hotspot while the SST70 is more concentrated.
This is the FT03 SST40 5000K at 150m.
The tower you can see in the following pictures is at 700m distance.
Control
Nightwatch NI40 with dedomed SST70
Astrolux FT03 with SST40 5000K
Astrolux MF02 with XHP35 HI 4000K
Animated
As you can see the Nightwatch NI40 with the dedomed SST70 led has a bit less throw than the Astrolux FT03 SST40 but it is pretty comparable. The throw is decent for the smaller reflector. With the XHP50.2 the NI40 barely reached the tower at 700m. I don’t have comparison fotos at 700m as the XHP50.2 is no longer in the NI40. Maybe the difference would be more noticeable if I would mod the driver to deliver 6A current.
EDIT: The previous beamshots of the NI40 have been replaced with fotos of the actual turbo mode that is hidden and can be activated only with a fast double click.
