Simple wins with me everytime. I’m not a granny or incapable of working more complex lights but, I surely don’t go out seeking complex lights. If this thing gets Andruil step less dimming into it, it just won’t be what it’s intended to be.
I love sublumen modes. I use them every night. I have a few lights that do those modes well, very well. I have no need for those modes in every light I have. I would never want those modes in my EDC light. I don’t think granny would need them either. To us these lights are a part of our lives. To them they are just a light in an otherwise dark room. I wouldn’t want to lose good mode spacing by adding a sublumen mode. Same for the blinkies. Down with the disco modes.
This got me thinking of the Xeno Cube. It would be great if the head would rotate for Off, Low, Med, High. Steps up clockwise, steps down counter clockwise. It wouldn’t roll away easily. That project is for another time though.
that was before zeroair.org understood thermal configuration. A better graph would be his second attempt on his FW1A. But even then he is using batteries with much less capacities on all of his FW## tests.
That is his 2nd attempt on the FW1A. Scroll down just a little further and you’ll see his see 3rd attempt. I can’t link it. Edit actually look at his 3rd attempt.
I’m interested in two with battery at that price point.
In order for me to actually carry it, it would need a good deep carry pocket clip to carry inside my back pocket. Otherwise it would be for occasional use.
My wife doesn’t use a clip, so a clip wouldn’t matter for her.
Something that I haven’t seen mentioned, but I think would be handy on any “granny” light is something that glows in the dark, so that the light can be found when needed.
I’ve never used any magnetic ring light, but wouldn’t grooves or ridges in the ring contribute at least a little to the anti-roll function?
You mean this one? Compare it with the Olight that maintains 500 lumens for almost 4 hours, the efficiency is still no where close. Interesting that it can maintain 650 lumens or more though.
Yeah ……
Gentlemen: What we see presented by the ever industrious Mr. Lightbringer is the fusion of form to function.
One might say ‘Bah’ indeed; for to the present this thread has been eerily bereft of protestation, that this light, nay, moreover; any light, equipped with on-board charging equates in function, but not necessarily in form, to the fruit of Mr. Lightbringer’s researches.
About the flashlight being visible in the dark, that sounds useful, but I hesitate that it should be done with a small led, like many BLF lights have behind the switch button. Apart from that it does not have a switch button, a even faintly lighted led that is continuously on when the flashlight is switched off will have say 100 micro-amp drain, no problem when the battery is charged once every two years, but when the light is in the drawer for 4 years it has emptied the battery. Is that worth the advantage of a locator light?
B. Grandma is dead.
On a more productive note. I prefer lanyard holes that are large enough for paracord. I’m going to tell Grandma that she should hang this light up by her keys or her coat or by the door and if she’s stepping out after dark it should go with her.
I’d rather put a bright “on” light at the “switch” to have a clear visible indicator that the light is still on. On low (especially in ramping) that is often not easy to see otherwise and will be a common problem “oh I thought its off”.
A locator light will just be confusing and in my opinion its not necessary as most people know where they put it at home (it is usefull when the light is in a backpack or similar, but at home there is dedicated place for the flashlight).
In addition, please make all switches/rings large enough and “grippy” while also easy to turn. Important is a easy visible and tactile feedback for the switch und positioning. hand eye coordination is just one of the things older folks loose too fast, so make it easy to know what one did by looking (visible marker) or feeling (physical marks)
The charging port needs to be easy accessable. those floppy plastic covers and most of the twisty srcew-on covers are a no go for grandma. she could never use it.
I hope for a “best of two worlds” solution for the easy operation of this flashlight: magnetic ring visible and grippy enough while still making the light look good and not like a some bulky eldery-aid.
But we are many months away from a first prototype, there is ample time to evaluate these type of features.
