*BLF LT1 Lantern Project) (updated Nov,17,2020)
For those who have lanterns with missing solder on the pads labeled as 3, 4 or 5, my recommendation is to connect the pads with graphite from a number 2 pencil. This won’t void the warranty. It also works if you want to add the additional driver chips at 6 or 7.
How much current can a graphite bridge carry? (can it handle closing 3/4 or 5 if 6 and 7 are also pulling current through the graphite?)
What hardness of pencil works best?
Does a graphite bridge have enough resistance to impact the amount of power getting to the driver chips?
Very little current flows through the graphite, as those bridges are in series with a control input for the drivers. #2 pencil as mentioned above. Other pencils may work also.
I also would like to know this as my orange ring keeps popping off so I would like to use a smaller o-ring but not sure what size to get.
A tighter Oring won’t help as the groove is too shallow.
I added a bit of superglue in the groove and this does the trick
see if this link works / helps:
Save 10% on LT1
discounted code ” SAVE10% ”
Price will be $53.99 for LT1 without batteries; $65.69 for LT1 with batteries after code.
Happy New Year!
Received mine yesterday, Dec. 28. Ordered from amazon.com on Nov. 25 from list position in the very low 2,000's.
Amazon tracking still shows "Out For Delivery" as of Dec. 29 @ 08:35.
USPS tracking was much more accurate in the days leading up to delivery.
Minor dent in box, light undamaged.
Light itself is fully correct and in fine cosmetic & operational condition; pads are bridged correctly, bail is symmetrical & stays put when folded down. UI will seem smarter than me until I learn it better. ( I hate being out-thunk by a piece of rock...)
The set of BLF LT1 custom re-wrapped cells I purchased from amishbill fit perfectly, showing no interference with the pot on the driver.
My Lovely Wife, a competent motorcyclist & mechanic's helper in her own right (but hopeless muggle when it comes to tech) even said "Wow!"
LT1 will (mostly) take the place of our ancient Coleman liquid fuel lantern for camping, although it, too, will always have it's place due to sentimental value (Lots of courtin' & sparkin' occurred under it's illumination).
Thanks to Sofrin for making it a quality device, and for making it at all!
Our heartfelt Thanks to our dedicated and very patient LT1 development team. Well Done!
slmjim
Found my LT1 in my mailbox a few days ago …although tracking still says it’s in NY. My soldering is correct and I have no desire to make it brighter. It lights up my living room equally as well as a ~800 lumen ceiling bounced flashlight. Camping with this will be a joy.
Thanks DBSAR, LT1 team, and Sofirn for making such a great lantern!
Can some experts put a sticky around the bridging on why/hows or least point me one single post explaining it…yep… a muggle but goes by -have it and not need it than need it and not have it
My LT1 is due to arrive Monday. As others have noted, Amazon tracking doesn’t keep up with this once it hits the USA but usps tracking picks up the slack.
Is anyone else’s stuck in a Chicago Limbo? Mines been “in transit” for the past week from Chicago to my states processing facility. Probably customs checked, even though it was already processed through. Post Master is doing an investigation on Monday, as they’re also confused.
I’ll try.
The LEDs produce light when current is passed through them. The LT1 has two sets of LEDs, Warm White (WW) and Neutral White (NW).
The LT1 has seven current regulator chips in parallel with each set of LEDs, 7 for the NW LEDs, and 7 for the WW LEDs. In the design of the LT1, 3 of these driver chips are always connected. The other 4 have the driver control signal brought out to a set of pads, one set for WW and one set for NW. These pads have numbers next to them, 7, 6, 5, and the last set has both 4 and 3 next to it. I don’t know why the 3 is there, as there is no option to connect or disconnect driver 3. For the remainder of this I will refer to the pads with 4 and 3 near it simply as 4.
The LT1 should come from the factory with the pads 4 and 5 soldered together. This configuration produces roughly 600 lumens maximum if I recall correctly. The way the board is designed, the pads at 4 must be connected for the remaining pad connections to be effective. The connections are all in series. I don’t understand why it was designed this way, that may change of future. If your LT1 came with pads 4 and 5 connected, you are all set. If not, then connecting both is recommended. Methods of connection will be discussed below.
If you want more light from your LT1, you can connect pads 6 (one for NW, one for WW). If you want even more light, then connect pads 7. If you connect the pads 7 without 6, you will not get any more light, pads 6 must be connected for the connection at pads 7 to be effective. This is because the connections were made in series for reasons I don’t understand.
There are two methods I know that are effective at making these connections. One is solder, presumably with a soldering iron. The other is to use a pencil and fill in the space between the pads with graphite. As mentioned above, the connection being made is the control line for the driver. Very little current flows through this connection, and the graphite provides enough of a connection for the signal to get all the way to the driver. I have experimented with making the connection at pads 6 and verified by measuring the current drawn from the batteries that making this connection with a #2 pencil is effective. Someone asked what hardness of pencil. I just used one in a drawer at home. Just fill in the space between the pads with graphite. The advantages of using a pencil to make this connection include being able to remove the connection with an eraser (verified in testing), as well as not requiring special tools.
I hope this helps, if DBSAR chooses he can add this to the first post, that’s the only “sticky” that will happen with this explanation.
Thanks sb. This should be stickied or referenced to in the first post.
Yea thanks sbslider, The front page is very busy. Maybe this sort of information should compiled in new topic that’s easier to parse through.
My button/switch backlight on “low” setting is barely distinguishable. Does this mean my unit is faulty, or does it happen across all units? It’s rather hard to find the button in the dark when the light is on at lower levels. It does come on full brightness after a certain level and you can easily see it.
There are edit levels on button illumination. Low, which you show above. I find this perfect for finding the LT1 in a dark room, but without being an annoyance. High, which is easy to see in a lit room, a flashing mode, and off. You can switch between the four levels with 7 quick clicks from off.
The light comes on to full brightness when the LT1 output is higher than about half full range.
Yeah but the problem is the lower level isn’t really (read: at all) visible to the naked eye (while the light is on at <50% brightness). Can’t find the button in the dark (while the light is on <50%), have to shine another light at it, or spin it around a few times…
Hmmm… I seem to have a fourth mode, lightning flash.
Yes, you are correct, I’ll update my post above.
