There are edit levels on button illumination. Low, which you show above. I find this perfect for finding the LT1 in a dark room, but without being an annoyance. High, which is easy to see in a lit room, a flashing mode, and off. You can switch between the four levels with 7 quick clicks from off.
The light comes on to full brightness when the LT1 output is higher than about half full range.
Yeah but the problem is the lower level isn’t really (read: at all) visible to the naked eye (while the light is on at <50% brightness). Can’t find the button in the dark (while the light is on <50%), have to shine another light at it, or spin it around a few times…
Ahh, I get it now. I agree, the low button light when the LT1 is on is sort of worthless. Nothing wrong with your unit, just an opportunity for improvement in the firmware. It would be nice to be able to chose button illumination level while on, this could be 7 clicks from on. But I think the current build uses almost all the memory, so I don’t know if there is room for this.
Thank you for the very informative post. I’m gonna assume that bridging 6 & 7 will draw more volts resulting in less run time from your batteries? Has anyone assessed what the difference in runtime is?
Just to elaborate a bit on MtnDon’s reply, if you enable both channel 6 drivers, you can expect 5/6 the run time as reported here. If you enable both channel 6 and 7 drivers, then 5/7 what is reported here.
The only downside of enabling more drivers is less ability to get fine tint mixing at very low levels. If you run at one tint all the time, then you SHOULD be able to just run at a lower level of control to get the same lumens. However, in order to do so you would need to add more steps if you used stepped control, or just use the ramp side of output control
Mine is the same and I noticed this almost immediately. Though it seems too dim at first, the Low setting is generally visible in the dark if your eyes are adjusted somewhat, which should generally be the case when you’re searching the switch. It’s pretty much invisible when the light is on at a low setting, however.
Is it ok to run the lantern without batteries but with the battery tube attached, and the charger plugged in?
I read in the instructions that you are not supposed to run it at more than 70 % of maximum output while it is plugged in so not to over stress the circuitry. How easy is it to mess it up?
It reads,
If operated without batteries the maximum output will be reduced. In order to not overstress the circuitry it is recommended to not operate the LT1 lantern above 70% of its maximum output when running on USB-C power externally,
It should read,
If operated without batteries the maximum output will be reduced. In order to not overstress the circuitry it is recommended to not operate The LT1 lantern will not produce above 70% of its maximum output when running on USB-C power externally, due to the maximum current capability of the charging circuit.
I don’t think its you, mine is also doing something strange here - I need to do a proper test and document. It seems on level 1 and 2 (lowest power output) its not lit up, but once you get above 3 the power button glows visibily like it does when the lamp is off.
Don’t really need help to find it when its on so not a big usablity issue, but something is definetly off somewhere with what mine is doing.
Its a great lamp though, been using it arround the house a bit much to the wife’s annoyance/amusement….
Want more amusement? Simulate a power outage and turn all lights off and use the LT1 only. :smiling_imp:
I didn’t have ours very long before we had a for real outage and the value of the light was plain to see even though we have a whole house backup for the mains.
