Why no C10 zoomie in there - yours is xml, no? Ok, ok, because it would look totally different than everything else lol. I haven't modded mine, yet, so I'm curious
I have two 50mm from DX but they're terrible at full focus :( That's really too bad because the 50mm would be awesome improvement to tractor supply 3xD zoomie...
The lens fits perfectly into the tr-500 tr-1200 head. I made a copper pill, heatsink, what I pressed and glued into the battery tube. Now it works with 1 cell.
this is the modified SMALL SUN ZY-C10-S:
I threw away the orig lens and replaced with a better one. I had to lift up the emitter, because the focal lenght of the lens is short. Now the original bezel doesn't fit, temporary got a protective plastic bezel.
Can you give us some details on the driver mod? Was it an upgrade or a repair, what's the difference before and after, which replacement driver did you use? Thanks.
*EDIT* Nevermind, I think I found it... here (posts #50 and #70). Thanks!
Hard to tell an exact value, because the brightness changes through the projected die image. The upper part always the brightest. A good average value for the 50mm ~ 50-60kcd (upper part 70-80k!), and for the 40mm ~ 35kcd (upper part 45-50k), I don't know the exact emitter current, both direct drive, somewhere 4A...
