[New Release] Mankerlight E05 II AL/Cu 1300 Lumen Highest Output Pocket EDC Flashlight in 14500/AA Class
What is upgraded in U11 “upgraded version” ?
Any 219 versions of the E02? I even tried all 3 colors, got ” :exclamation: the combination you selected is unavailable” or somesuch.
I wanted to get a couple, but I really don’t want those any of those hateful little G3s. I have to slap on like 3 layers of diffusion film to mask the ugly ugly beams that G3s make in reflector lights.
Lightbringer A few Nichia E02 left on AE: https://www.aliexpress.com/item/32811337744.html
Available at Aliexpress.
Headlamp
https://www.aliexpress.com/item/32822166381.html
Flashlight only
Ugh, PP is disabled as a payment option. Wtf??
Where do you see this mentioned? Never mind, I found it. I don’t see any difference either. You would think they would mention what is improved on it.
Different UI.
After some searching I found reference to “Manker upgraded driver, UI, switch…”
The UI has definitely changed, Turbo has moved to the blinky mode group. And it no longer allows you to choose 1,2,3 for each level. Can only configure moonlight level.
OLD:
NEW:
As for driver and switch upgrade, I can find no extra details. But indeed there were many reports of unreliability in 2016 so perhaps the changes were warranted ?
The ‘upgraded version’ is not actually new, it appeared in 2018 best I can tell from wayback.
I received my CW E03H that was 1/2 price on clearance from Manker and it has the new mode sequence listed above - same a the Folomov “wave” mode sequence, which I don’t like.
I prefer the sequence to go to low from turbo, rather than going to high from turbo.
The headband can’t hold the light stable - the light bounces when I walk.
The diffuser does glare down into my eyes and glasses - might be reduced by applying black marker to the bottom edge.
I like the beam pattern.
The CRI appears to be adequate for EDC use.
It seems heavier than a AA headlamp needs to be, but it might survive being ran over by a tank.
Mine goes to moonlight after cycling out of the turbo group. Or if double pressing into and out of turbo, it goes to whatever mode it was on before.
Agreed, the diffuser, whether engaged or not, can shine some light into the eyes especially when on the headband, if the light is pointing low enough.
Mine, also, but it goes to medium from high, rather than going to ml or l. ml-l-m-h-m-l-ml.
Yes, mine too in the normal mode group. But you mentioned turbo which is in another group and that behavior is different.
Yes, I erred in my first post.
I received my E02 and E03. Both seems OK.
E02 came in retail package, E03 has a simple cardboard box.
The E04 clip is a trash. Diffrent than advertised and not fits to the groove well. It tends to pop out. Simply not designed to this light. I wrote the seller asking for a good one.
The E02 clip is original and fits perfectly.
E14 II 50% OFF:
https://www.aliexpress.com/item/4000821929621.html
MK34 50% OFF:
https://www.aliexpress.com/item/4000804743531.html
MK34 bundle 47% OFF:
https://www.aliexpress.com/item/4000805543646.html
E14 II 50%OFF / MK34 USD50.00 OFF:
http://www.mankerlight.com/clearance-sale/
That E14 needs to be at least 50% off, $69.99 for that is madness when you look at what it’s competing against.
New model Striker Mini is released.
Striker Mini the Longest Range Pocket EDC Flashlight in Its Class, also the Smallest Tactical Flashlight on the Market.
Key Feature:
  1. Compact Size, Lightweight for Perfect Everyday Carry
  2. High Efficiency Performance in its Size
  3. Multi-fuel (14500 li-ion, Ni-MH AA, Alkaline AA etc)
  4. Single Tail-switch Control for One-handed Operation
  5. High-cost, Durable Construction & Engineering (Dual constant current driver design)
  6. Unique Two-way Strike Bezel
  7. Well-made Two-way Pocket Clip
  8. Full Metal Tactical Ring
  9. Additional EDC Element (Tritium Glow Bar Slots Design)
  10. Versatile Usage Applicable
More info, welcome to http://mankerlight.com/striker-mini-pocket-edc-flashlight-tactical-flashlight/
Mini size for perfect everyday carry.
You can see the photo as below:
Striker Mini VS iPhone 14 Pro in size comparison.
Ultra Compact Size, length is less than 4 inch
Lightweight, weigh 81.6 gram
Palm size is perfect for everyday carry.
Unique Two-way Striker Bezel
high material + high cost surface finish
