SALE: Low-cost copper pills, spacers, optics, drop-ins.
1846 posts / 0 new
kiriba-ru
kiriba-ru's picture
Last seen: 2 days 28 min ago
Uhh, good question.
You have purchased many of them.
Previous batch (when Cu ones were also oversized, and driver cavity was not as deep as before) design got minor changes. Many years ago I added an extra step at the top, it was needed to align centering ring for triple config. Since centering rings are sold out, nobody asked me about this option, so this time I decided to exclude this feature. Now there is just 1mm flat rim around PCB place.
https://imgur.com/pnwv8hn
https://imgur.com/YzSyWn8
https://imgur.com/zyfvGOx
https://imgur.com/rjUHgT2
P.S. Anyone else have problems with photos in OP?
KawiBoy1428
KawiBoy1428's picture
Last seen: 3 hours 59 min ago
kiriba-ru wrote:
Uhh, good question.
Thanks!
KB1428 “Live Life WOT
Chatika vas Paus
Chatika vas Paus's picture
Last seen: 2 hours 11 min ago
kiriba-ru wrote:
I wanted to make high walls (around optics) and put nice gitd o-ring in gap between optics and bezel, but I’m not now I’m not sure in this decision. I guess many triple boards are not round or oversized (while optics is very precise).
Pulling the walls to the top, under the glass is a bad idea and you answered why. They are of different sizes. L4P are slightly thinner than e.g. Noctigons.
1mm flat rim is enough, just to center the mcpcb.
And instead of a glowing O-ring you can paste gitd tape from the inside and it looks good too.
I bought a quad spacer for Convoy S11 from you which have high walls. I wanted to put 4x Luxeon V there and I don’t know if I can just put the mcpcb on the thermal paste or I need to solder it.
If I put it on paste, I don’t know if the mcpcb will be properly pressed to dissipate heat. This is because the L4P quad is 1.6mm high and the Noctogin is 2mm.
If I have to solder it, I don’t know how to center the mcpcb, because it is 20mm, while the place is for 21mm Noctigon.
I can see photos.
kiriba-ru
kiriba-ru's picture
As far as I remember, you have S11 set (Cu spacer+brass ring). If you need to use thinner PCB, you can sand down the bottom of the brass ring. Also, you can fix brass ring on spacer in right place with a solder or thread locker. Anyway, if you are not sure in right combination, putting them together without solder/thermal paste/wiring is always a good idea.
You can use the central hole in spacer for PCB alignment. CNC made batches have 4.2mm hole, custom and rare parts have 4.0-4.1mm central hole. If you need, I can add a 4.2mm drill to your next order. Use work side (for undersized holes) or shank side (for 4.2mm holes).
1.5mm o-ring can be compressed by 0.3mm with ease, while thickest 20mm triple boards are 1.75mm thick.
I just don’t see another way to get optics centered. Parts are not aerospace precise and need some room for easy fit. I need to give some extra room, if the next batch of hosts will be made by another vendor, my spacers still should work.
Pill top is flat, a spacer is roughly centered inside head walls. PCBs are not perfect in size and roundness, also some of them don’t have chamfer at the bottom (this means I need to add at least 2x minimum tool radiuses to the ID size). All this gives a reasonable amount of side gap, and the build will always end up the same way – you will get optics off the bezel hole. This is not a problem for S2+ (when 1.5mm of optics hides inside bezel), but S21A bezel opening is 0.2mm over optics size – so you will see any misalignment and it will look awful.
Alen
Last seen: 11 hours 38 min ago
kiriba-ru wrote:
No. I’m thinking about triple spacers for S21a.
A solid copper pill for triple would be better than spacer that will be hard to solder well on the flat surface
a1sealbeach
a1sealbeach's picture
Last seen: 23 hours 28 min ago
I got the spacers the other day safe and sound. Thanks and Happy New Year.
"Three things you should never break: promises, trust, and someone’s heart.”
MascaratumB
MascaratumB's picture
Last seen: 4 hours 35 sec ago
Just wanted to say thanks to kiriba-ru that manufactured the copper pill and brass ring for my Amutorch VG10 that I will use in the OL contest!
Perfect pieces Wink Thanks for your work!!!
SlaytheIncubus
Last seen: 6 months 4 weeks ago
Mr. Ru… I’m looking for parts for S2+ and a C8. Throw throw throw throw. Don’t give a hoot’n‘shit about CRI and I prefer blue-er light. Got anything in stock to fill the bill?
(I am aware of that thing called the ENTIRE EARTH in-between our locations, which I am fine with waiting on long shipping)
__________
id30209
id30209's picture
Last seen: 12 min 21 sec ago
kiriba-ru wrote:
All items 25% off till end of this month.
PM sent
WTB Titanium 4sevens 2xAA tube
MascaratumB
korpzgrinda wrote:
I was excited to see a small package from Russia in the mail today! A quad spacer for the Convoy S11 is all the rage these days… Big Smile or should be soon. The host and emitters are still in transit from China though. Thanks kiriba!
kiriba-ru, can you tell how much do these S11 spacers cost?
I don’t even have an host, but that light seems quite nice, so I’m just thinking of what to do !!
Thanks in advance Beer
kiriba-ru
kiriba-ru's picture
$13 set
MascaratumB
kiriba-ru wrote:
$13 set
Thank you Wink
As soon as I decide for the host, I will let you know and ask the piece Thumbs Up
kiriba-ru
kiriba-ru's picture
Few S11 spacers left:
2020-03-14-16-25-54
This micro batch is solid copper spacer, no brass tube left.
kiriba-ru
kiriba-ru's picture
Ruble have fallen down (as usual) so I was able to reduce prices by 15-20%.
kiriba-ru
kiriba-ru's picture
I still have several quad mod sets for Manker U11, no ideas about how they fit the new hosts. Available for free.
forsh
forsh's picture
Last seen: 1 month 4 weeks ago
will the quads fit in a s2 convoy?
https://www.facebook.com/groups/163189738353433/?ref=share
Join my Facebook FW3/4/1 selling and buying group guys
kiriba-ru
kiriba-ru's picture
No, even S21A is not big enough for quad.
Yoordie
Last seen: 6 months 1 week ago
S21a will fit these kaidomain quads
kiriba-ru
kiriba-ru's picture
They can fit, but I don’t want to force my customers to make experiments with 2-legged optics.
Also, S21A bezel opening is just as big as needed for regular 20mm triple from Carclo. You can put quad and loose 25% output (inside bezel), or use triple and get as much as you can from triple.
id30209
id30209's picture
Kiril, do you have any plan for S21 triple spacer?
kiriba-ru
kiriba-ru's picture
Yes I do.
kiriba-ru
kiriba-ru's picture
Russian post will be closed at least until Apr 2nd.
All custom orders are delayed by a week or more.
id30209
id30209's picture
kiriba-ru wrote:
Yes I do.
Sweet. Keep us updated. I have S21A coming Smile
I think every post office is delayed now and some are closed for a week
MascaratumB
Thanks for the information Thumbs Up
Stay safe!!!
KnHawke
KnHawke's picture
OH sweetness! S21A Triple?
I know I’m late into this thread, wish I saw this earlier Silly
Certainly purchase a few when they come available!
JaredM
JaredM's picture
Last seen: 25 min 5 sec ago
Another one interested in triple s21a spacer or pill.
VaKo
I tried to make a S21A quad using the KD optic. It was a complete failure, without some form of support for the optic the pressure of the bezel will mash the optic into the surface of the LED. A triple would be far more desirable.
KnHawke
KnHawke's picture
Aye, would very much prefer a full pill. A spacer would irk my technical sensibilities Wink
kiriba-ru
kiriba-ru's picture
Little update:
I am able to ship out orders as fast as usual, but all custom parts and future products development is delayed at least until mid of May.
Capta1nFalc0n
Last seen: 1 year 4 months ago
Hi, by any chance would you have a 21mm retaining ring for sale? I have a convoy l2 and I think the threads on my retaining ring are messed up because when I try to screw it in it gets off kilter every time. I’m having trouble finding where to buy a new retaining ring
