I repackaged those myself. They are sold in a bulk tray.
What am I supposed to test?
I see you have a 4000K on order so thought you were planning to test one.
Of course I will do some spectrum testing, but if you refer to output/voltage, I was not planning on that because I expect it not much different from the 5000K one.
I’m waiting on a XHP35 driver, I was thinking of first do the mod and then check the tint.
I had been wanting to upgrade my Jaxman Z1 for a while and this emitter seemed like a good opportunity to do it. I had a Kiriba-ru Cu pill and when the H2-C driver arrived the other day I jumped on it
Now I don’t have to go through the H-M-L-strobe-SOS modes it came with. And as a bonus when zoomed in I don’t have just four panels but 16!. One thing that is visible when zoomed in is that the individual panels are not uniformly colored. It’s a little hard to tell in this image because I can’t bring the emitter surface into complete focus, but some of them are yellower than others (upper left) and there is a dark spot lower right of center.
It doesn’t really affect the beam when zoomed out (flood mode) and I will typically use more flood mode than zoom mode. I just wanted to show you guys an example of what you may get. So now I have improved modes and high CRI in my Z1! Thanks rngwn.
An additional note, I’m not sure what driver they sent me. It has four modes that correspond to very low, low, medium and high, but double clicking goes to turbo and triple clicking goes to strobe, modes not listed for the H2-C description at the place I ordered it. It’s drawing over 4A on turbo but I only have a Fluke meter to do tail measurements so I’m probably measuring too low.
I’m surprised at the huge difference in tint within the same emitter. I was thinking of modding a Cometa with copper pill but you just saved me the trouble. Thanks for letting us know.
Finally put one in a suitable host. The manta ray C8.2 w/ 10mm hole.
https://www.reddit.com/r/flashlight/comments/ejt0qh/nld_manta_ray_c82_w_selfsourced_4000k_95cri/
Wow you found a perfect fit spacer too. Where did you get the spacer?
It comes with the host
It is sized for XHP70.2?
Long version Manta Ray C8.2 black flashlight host
https://a.aliexpress.com/KwYly5nRV
Yes, check in the item description. Make sure you take the 10mm reflector option.
I bought the short version though. They also come with XHP70.2 gasket.
Edit: you want to wick off the excess solder blob on the sides of the emitter, or else the gasket won’t fit.
What the heck, i'll take another one.
I have found two more hosts that are suitable for this 12V led. It works nicely inside the Sofirn C8G and the Haikelite SC26.
As the Sofirn C8G and the Haikelite SC26 both use a XHP35 they both have a 12V boost driver.
The SC26 originally uses a 16mm PCB but if you cut a bit of copper away where the switch board is to make sure they don’t contact a 20mm works fine.
The C8G does not use the standard 20mm PCB size so the GT-FC40 20mm MCPCB has to be trimmed to 17-18mm until it fits the PCB cavity.
What you need to do is swap the reflectors for others with a bigger 10mm opening for the 7070 led format. I have used OP reflectors to smooth the beam a bit which can be ringy because of the individual dies on the led.
In the C8G I have used this kind of reflector: C8 reflector 10mm led opening
This reflector fits perfectly in the Haikelite SC26 with 7070 led: kaidomain.com/Flashlight-DIY-and-Tools/Reflectors/29_6mm-x-24mm-Aluminum-Reflector-for-CREE-XHP70
I really like the tint and color rendering of these two flashlights now. It is much better than with the XHP35. Of course they won’t throw as far anymore but still decent enough and with 95CRI.
Good Job! Looks very nice! Thanks for sharing.
I notice that Getian has also a 50W LED.
Does it have XHP70 footprint as well? Is it also high CRI? Any chance for a GB?
I think they are one and the same as this 40W emitter, and I remembered they even listed 60w with the same number of die and footprint (also with less lm/w, which confirms my suspicion).
As Djozz have tested, these “40w” parts could easily be run at 60w (as long as you can cool it), and might even survive a brief period (minutes) of 100w without degradation.
I see…but why have different model numbers? Pure marketing “We have a model tailored to your needs”?
That’s very possible but maybe it would be good to ask for clarification?
If anyone wants to sell me one of their unused ones PM me.
D80v2 with GT-FC40 4000K and 20mm MTN-BST3 driver, reamed reflector (probably more than necessary)
High (stock lens) |
High (with diffused lens) |
