Test/review of BlitzWolf 36W Quickcharger BW-PL3
Official specifications:
  • Input voltage: 100-240V 50/60Hz
  • Output: 2x 3.6-6.5V 3A, 6.5-9V 2A, 9-12V 1.5A
  • Output power: 36 Watt
  • Dimensions: 61 x 61 x 30mm
  • Weight: 125g
I got it from Aliexpress dealer: BlitzWolf Official Store
Measurements
  • Power consumption when idle is 0.13 Watt
  • USB output is auto coding with Apple 2.4A, DCP and QC3
  • Minimum QC3 voltage is 4.3V, will reset when lower voltage is selected
  • There is a blue led above the USB connectors.
  • Minus is common for the two USB outputs.
  • Weight: 108.4g
  • Size: 96.5 x 61.0 x 30.0mm
The overload protection kick in at 3.5A, this is fine for a 3A charger.
The other output is the same.
THe 9V output can deliver 2.5A, but the overload protection first kick in at 3.5A.
At 12V the charger can deliver 1.8A, but again the overload protection first kick in at 3.5A
For output test I runt one output at 5V 3A and the other at 12V 1.5A and the charger could maintain that for one hour.
The temperature photos below are taken between 30 minutes and 60 minutes into the one hour test.
M1: 64.1°C, HS1: 71.1°C
M1: 63.2°C, M2: 57.5°C, HS1: 65.1°C
M1: 55.9°C, M2: 55.6°C, HS1: 58.5°C
M1: 58.1°C, HS1: 60.4°C
M1: 53.1°C, HS1: 69.5°C
At 0.5A the noise is 43mV rms and 1421mVpp.
At 1A the noise is 47mV rms and 1509mVpp.
At 2.5A the noise is 55mV rms and 1765mVpp.
At 0.9A the noise is 52mV rms and 1606mVpp.
At 1.2A the noise is 72mV rms and 1738mVpp.
Tear down
This can make it hard to get the circuit board out.
Mounting the base in my vice I could break the top off with my mallet and the circuit board was not that hard to get out.
At the input is a fuse, then a common mode coil, there is 4 smoothing capacitors with a inductors (L1 && L?) between them (Each switcher has a inductor and capacitor). Between the transformers are two safety capacitors, one for each USB output.
On the low volt side is some large mosfets (SFG10R10G) for synchronous rectification. Each output also has a QC controller (U2 & U4: Marked N06 / PJK953)
Why is there a heat transfer pad on top of the transformers, it do not touch the enclosure as can be seen on the white stuff that goes well above it.
On this side is the bridge rectifier and two advanced mains switchers (U1 & U3: INN2215k).
The distance between mains and low volt side is large enough.
Testing with 2830 volt and 4242 volt between mains and low volt side, did not show any safety problems.
Conclusion
A dual QC3 charger with a lot of power. It is is a nice design with two mostly independent QC supplies, but also some issues. The QC3 cannot go much below 5V and there is a lot of noise (probably common mode).
Notes
The USB charger was supplied by a reader for review.
Index of all tested USB power supplies/chargers
Read more about how I test USB power supplies/charger
How does a usb charger work?
Thank you for this review HKJ :+1:
Looks like the thermal pads are on the wrong side, should have been on top of the two mains switchers instead.
@HKJ, could you provide some sample/information about the noise issue of DC output when the device connected ?
Im still confusing for the noise meaning of DC output. Thanks
If there is a lot of noise it may interfere with the phone, it can be lower sensitivity or it can be the touchscreen that do not work well when the charger is connected.
Most phones are fairly well protected against noise and you may not see any interference.
Thank HKJ for your reply, if that, it means we will not care about the noise of the charger, just care for the safety distance ?
It also means a charger got the noise 30/300 or 15/150 or 67/949 will be the same quality of DC when connected to a phone with its good protected noise ?
[quote=chargerlover]
Lower noise is a better quality DC and may also mean a better design of the circuits inside the charger.
@HKJ : Does it impact to the battery of phone which is connected to a charger with high noise ?
No
The battery inside smartphones, tablets, computers and such never sees the power of the adapter supply as it comes, they're behind control circuitry which carefully manages and regulates the power which goes to the battery. And even if it were to get through, batteries don't care about noisy charging voltages.
Blitzwolf has many other, better made, power adapters. Due to high noise, I would certainly choose a different model or a different brand unit.
Many thank for your reply, it is clear for my side now. So, the high noise is not important to let me choose the charger anymore :smiley: as I tried to buy the good ones with the low noise (surely its cost was expensive than other model with high noise) to my friends and kept in mind there might have some different (better for the phone battery, for phone…etc) to convince them to use those charger instead of use whatever we easily bought in the local store :smiley:
