Yeah thanks for making us want to spend more money. This forum is dangerous for the wallet.
You are welcome, guys.
I looked up 'flashlightlens.com' for an UCL lens, but Jacob's size 50 x 1.9mm isn't available.
Just as well! With shipping, the UCL alone would amount to more than half the entire flashlight price.
I think I forgot to mention how delighted my daughter has been with that nice lanyard (I never use them).
What a bargain this seems to be. I have my thrower needs somewhat covered but seeing this makes me wonder if I should try to mount a XR-E EZ 900 to my X8 and drive it at 1,8 A. Just for the fun of it and to see what Lux readings I can obtain.... Decisions decisions.
Anyway super review. As others mentioned this is potentially bad for the wallet! LOL
That's my plan with the X9! I already have a new XR-E EZ900 for the switch. Stock driver, pulling 1.8A with the XM-L installed, should work fine.
But now little Jacob needs all my loving care.
AB, how wide is the hotspot at 3 meters distance? Hows the overall light output?Thanks
I was going to ask how wide the hotspot is at about 10 meters to compare to my Dongrui, but I guess I could compare at any distance.
-Garry
At 3m, hotspot size is:
Jacob A60 ..... 20cm
UltraOK ..... 18cm
HS-802 ..... 10cm
This relation remains pretty much unchanged at grater distances.
Jacob's XR-E ringiness is not pronounced, practically invisible at working distances (100-150m for me). There is no corona to speak of, only a nice soft-edged spot. Compared to an aspherical, the outer spill is quite bright, but less so than with any of my XM-L lights. Target image is crisp, there is no haze (the big issue with my X9).
Interested if any aluminium reflectors will fit too.
I looked up DX and didn't find any.
Dimensions are in post #14.
BTW, I applied thermal paste to the pill/head screws, without much effect. The stupid thread anodizing there seems to raise an effective barrier, unless the bottleneck is the emitter star to pill contact. Didn't try to lift the plastic insulator to see how the latter looks.
Yeah I saw the dimensions and looked a few places too without any luck.
Last night I spotted a deer at 75m. Jacob almost smoked her.
I think I heard some profanities coming my way...
Ok, I measured my Dongrui All-920 this morning and I got about a 20cm hotspot as well at 3m. Interesting since my Dongrui is just a standard C8 (42mm) sized head/reflector. The reflector in mine is aluminum, but I don't think the pill is solid (haven't verified though). I have run mine just fine for 5 to 10 minutes at a time. The description of yours sounds exactly like mine - no ringiness at all, and a very nice defined well-focused hotspot. I do like the styling of the Jacob A60 better though.
-Garry
To me, the difference between the Dongrui and the UltraOK seems perfectly normal, as I don't think that all C8 sized reflectors have the exact same profile.
Also, on the UltraOK the hotspot edge isn't defined sharp enough to eliminate all subjectiveness while measuring its size.
Know what? I just ordered one more.
I use a thrower daily, as an occasional burst complement to the floodier XM-L walking light. So well does Jacob A60 fulfill what I expect from a midrange thrower that, aware of its soft-spots, I decided for a backup.
At least this time the wait will be an easy one.
Right tonight I found a solution to the issue that the light comes on on Low (i.e. next mode) if it has been resting for less than 5 min. Now, when I'm done spotting, I move to Strobe at full ease and switch off. When I next turn the light on (and it's important that I have the full blast right-away to freeze an animal), it will always start on High, either because the 5 min have passed or because High is the next mode to Strobe. Now, isn't that clever?
Did you see ILF's thread where ezarc posted that DX status is "waiting on supplier"? Might be a long wait again!
I wonder if this is a driver where you can do the "resistor" mod to drop that 5 mins wait down to a few seconds. I never noticed the 5 min wait on my Dongrui (perhaps it's the same). I thought mine always came on in the next mode.
-Garry
In my case the "waiting for supplier" status endured for 2 1/2 months, until I complained. This time I don't care much, as long as I get it.
I read about the resistor mod when the same behavior of the Small Sun aspherical was discussed. I might look into that once I have the backup, not before. I must admit I'm not comfortable with those microscopic driver components.
My second A60 order has been notified shipped two days after order placed!
Does that mean the end of the recent DX troubles?
I for one hope so :-) For your sake since I'm on a resisting binge!
My second A60 arrived today, 15 days after placing order. Real fast, even by the old DX standards.
No difference from the first one: same hard to clean lens, same (battery dependant) current pull and same powerful beam, although with a bit of a doughnut hole this time.
EDIT: I'm not very picky about tint, so I noticed only after some more comparing to my other throwers - both my A60 samples have a warmer tint, neutral perhaps.
