… impossible. Same chromaticity bin is impossible, this is because a chromaticity bin also defines its CCT. If you mean CCT off-axis equivalent, then that is possible, the first letter in the chromaticity bin defines CCT. So GA3 is 3500K, A3 chromaticity rhombus, and HA3 is 3000K and same rhombus of coordinates.
Concerning same flux, that is unlikely. This has to do with the way lumens and luminous efficacy is defined. Led emitters with the same radiant flux bin do their job equally well, but if rated in lumens, which is defined over an average human mind-eye bias, emitters with CCT curves which contain a higher amount of light to which the average human is more sensitive will look brighter. It's the way it is. ¯\_(ツ)_/¯
Sad i missed out on these SST-20’s. If anyone who bought a ton would like to sell me some, please PM. If not, i’ll wait till, hopefully, the next round.
Would you be willing to sell the large springs separately? After my last order it sounded like you would rather not do that since they’re a pair. I just rarely need dual springs.
I’m using the large ones a lot for the Convoy C8+ lights and others similar. I also stopped installing them into the Sofirn C8F because dual springs made it too stiff with how tight fit a 21700 was. I was thinking it might start to dent in the positive contact.
Finally created my own website to sell on so that’s all going well
Awesome, thank you. I’ll send you a pm when I’ve decided how many I need.
Do you get them made in China? Would it at all be possible to get a bulk lot shipped direct and I just pay you? If it’s some crazy number you have to order at once then that wouldn’t work. Max would be 1000
Currently I’ve been offering these springs as an upgrade at a cost but thinking it would be better to install them in everything. If I advertise with better springs it would sound better then mentioning the stock bypass possibly breaking.
Ahaha I worded my original comment pretty poorly. Thanks for clarifying though. By “same” I was referring to the same flux and chromaticity bins that were offered for each respective emitter in the 2nd group buy that ran previously, hosted by Bluesword.
For reference, the following options were offered in the previous GB:
3500k: J4 Flux bin, GA3 tint bin
3000k: J2 Flux bin, HD2/HA4 tint bin
