Nice list, you have been busy!
I might have to try one myself, got some old strips under the kitchen counters that could use some upgrading.
I didn’t know where to put my latest finding…so I put it in here:
5V FOB strip, available in 3000K and 6000K. CRI80.
https://www.aliexpress.com/item/32954872800.html
Wow, that’s a lot of research there.
Some amazing specs among those strips.
Indeed, the high power LED manufacturers could perhaps learn a thing or 2 from this.
Thanks for doing this. :+1:
Great list!
I wish I had access to this before redoing my kitchen. I used Flexfire LED Strips and the DUV is def positive.
Thank you for doing all the work and recommending Auxma strips. I have purchased 2400K 3000K and 5000K rolls. Awesome light quality.
For the 24V 3000K strip, resistors are 56 ohms.
At the beginning of the strip, close to the power supply connector, there is a 3.46V drop on the resistor so LED current is 62mA.
3.46V is 14.4% of 24V so resistors waste 14.4% of total power, and LEDs get 85.6% of total power. Not so bad.
At the end of the 5m strip, 2.7V on the resistor, so only 48mA LED current. Thus 5m is a bit too long for a single power connection.
Note efficiency depends on LED color. For 24V having six white LEDs in series is okay, it wastes only a few volts in the resistor. But manufacturers use the same PCBs for all colors! So RED strips, with much lower Vf LEDs like 1.8-2V, will waste like 50% of the total power in the resistors… Not good!
Thanks for the data bobflux.
The efficiency loss is a bit of a problem atop of the uneven brightness thing caused by the uneven distance to the power supply which each strip stage has. It is a cheap and simple way to have led lighting, but far from being the best. I'd rather prefer strips in series (without resistors) powered by standard (usually AC powered) led drivers; this requires good isolation and limits concerning minimum and maximum strip lenght, though.
I’d say “it depends”.
A 10W light (about 1000 lumen) which is on 4 hours a day will use 14 kWh per year or about €2.20 of electricity every year.
Replacing incandescent lights with LEDs really saves energy and money. But optimizing LED efficiency beyond 100 lm/W isn’t really interesting IMO, it gets into diminishing returns. I’m willing to trade some efficiency for better color rendering, better look and aesthetics… but modern LEDs, even the high CRI ones, are already very efficient, so the energy cost isn’t that much anyway.
Bottomline, lowering the heating thermostat by 0.1°C will probably be unnoticeable and save much more energy than optimizing LEDs…
Meh, bypass the resistors with solder blobs and use a real driver for the lengths you cut yourself.
not good with variations in led vf and drop due to length.
the ones closest to the feed will be overdriven.
the resistors relieve this.
SKV89,
I took the liberty of putting your data in a spreadsheet (google sheet).
High CRI LED light strips (and a few bulbs)
Maybe you can add the link to your OP?
If you want to be an owner of the spreadsheet to make edits, PM me.
I saw the inclusion of SOME SKV89 data in this spreadsheet:
from this thread:
compiled by fneuf.
But it seemed that fneuf only included measurements that included R12 data (it factors into his “grading” formula) so most of the SKV89’s data is not included. (R12 was measured for only 3 out of 34 products)
CRI_Grade was created by me, I added it to his spreadsheet for him. It uses Ra, R9, and R12. It really targets the weak areas of modern LED technology works stellar. There is a link in my signature about it.
Thanks! I added it to the OP
Never caused me any problems, but i do tend to underdrive them.
YMMV, as they say.
I’m totally new here. Where can I find explanations about all those parameters?
It’s a good question, I just don’t have much time to type. Maybe this along with google will help… CCT is the warm/cool choice you have. DUV is unwanted tint shift, usually green or rosy. CRI is a measure of the how balanced the rainbow is, under 90 is not very good. R9 is one of the rainbow measurements, it’s the hardest with modern tech, it is usually far lower than 90.
The others are a bit harder to explain in a short amount of time. I hope this helps.
Thanks Joshk.
Which parameter is relevant for blue light level? I guess that low CCT and an even spectrum mean low blue light but is there a more direct measure of it? Do you have a definition of the blue peak value and typical values for incandescent bulb, for example. Google didn’t help me with that.
In general, the higher the CRI, the lower the blue wavelength because the phosphor needs to convert more blue wavelength into other wavelengths to achieve the high CRI. Of course lower CCT means lower blue light because more blue light needs to be converted in order to achieve the lower CCT. But you never know unless you test them. You can compare the blue peaks in the ones I tested.
Thanks Joshk.
The 460nm “blue peak” of a 2700k LED bulb is about 1000x LESS than the sun at noon today. “blue fear” mostly comes from shady salesmen and click-bait writers.
