I did try putting the light closer to the ceiling and the numbers didn’t really change. The NI40 is not a lot brighter but the difference is noticeable when comparing ceiling bounce.
whatsthepoint
Your observations are consistent with mine: a 0.01-0.02V drop in the immediately-measured voltage of the charged cells within one day.
Considering the resting voltages represent only ~5% less capacity than a full charge at 4.2V, I’m not overly concerned about it, as I prefer a built-in charger to err on the side of safety. Battery charge percent
Unscrewing the tail cap will stop charging since it breaks the contact between the unanodized part of the tube and the tail cap. I like how little it needs to be unscrewed because it makes mechanical lockout easy and reliable. That is the case for both the SP40 and SP33v3.
I have not found the side switch too sensitive in my case. Actually if pressed softly from an edge sometimes the press does not register at all.
During your runtime test starting on Turbo, after stepping down, did it never step back up again? In my test of the SP33v3 the brightness oscillated based on temperature and I did not notice any abrupt changes corresponding to modes.
Also, it’s been a while but I think the Sofirn 18650 was at 2.5-2.6V when the SP33v3 finally shut off. I forget what the voltage was in the SP40, but it was higher, maybe 2.8V. For both flashlights, the light output was quite dim by then, so in actual use I would have swapped cells or recharged it before that point.
Now that both regulated and unregulated models are out, any opinions on which is best? I’m not seeing the advantage of the regulated v2 model. Can’t the battery be self regulating, only gradual as opposed to stepped?
During the early part of the 2 hr 50 min run on high the displayed surface temperature of the head fluctuated between 47.3C and 48.1C but later increased to a high near 49.0C.
After the voltage measurement when the light stepped down to Medium the reinserted battery was able to go into High but not for very long before going back down to Medium until it finally shut off several hours later at 2.61v.
My 2 ShockLi 5500mAh cells discharge capacity test more than 500mAh greater than the Sofirn 5500mAh does so run time should be better using them.
The aluminum driver retaining ring,bezel and power button ring unscrew easily but the driver is in there very tight.Does it push out the top or bottom of the head?
I only have the V2, but I’ve had similar lights to V3 with FET drivers. I think it depends on your needs as far as which is better. The V3 can get brighter, but it also gets hotter quicker and the brightness/battery voltage goes down faster due to the higher amperage.
Personally, I prefer the V2 with it’s Boost driver. I like the consistency in output and the longer runtimes. (I use it every day for work purposes)
If you don’t need consistency and longer runtimes and prefer a light that maxes out higher and don’t mind that it heats up faster (on Turbo), then V3 might be better.
How many max. candellas is Sp33 v3? i cant seem to find this info anywhere
thanks
Hi All
I have been following this thread with interest as I had a SP33 V3 on order. It arrived a couple of days ago.
I am very happy with it. I ordered it with a battery so I’m not sure if the included battery can provde enough amps to allow LED to run at its max brightness but in Turb mode it is still very very bright, quite enought for the WOW factor I dont have any other 26650 to test, may see what 18650s I have.
I find the switch a bit of a problem, it does need improvement. I have to click it just right otherwise it dosn’t respond. Probably as I get used to the switch it will ‘improve’. The 2 ‘ramps’ are a bonus.
I really like the built-in charging, the main reason I bought it, plus the extended run time with the big battery.
My Convoy C8 has a better throw so this complements it quite nicely.
cm64,imo the Sofirn 26650 5500mAh is a good cell but there are better.
If you want the longest run times then look for greatest capacity.The ShockLi 26650 5500mAH comes close to or goes over 6000mAH in testing the 2 I have.They offer capacity and continuous 20A to 30A
Some here on the forum recommend the Golisi Gold 26650 4300mAH for max lumens.
A Molicel 21700 4200mAh 45A in the plastic sleeve may also give some measure of higher lumens.
I don’t know if banggood sold me a fake Shockli 26650 cell or what but my orbotronics 26650 Cells blow the Shokli out of the sky . When I compare them at same voltage I get much more lumens out of orbotronics 22a continuous discharge
Which cells?
Orbtronic 5750mah and Shockli 5500mah?
Those should be the same cell, the PLB-55. Do the ends look identical? Does your charger show about the same internal resistance (clean contacts, try several times, only use the lowest few results). Have you tried measuring their capacity?
BTW, what is “22a”? Orbtronic only shows a 30A rating which is not the continuous rating. Did you measure 22 amps? If so, how did you measure and what was the amps for the Shockli?
I need to get home to check the exact batteries I used. The 30a is written on the orbotronics but the description of the cell states 30a discharge is momentary and continuous is 22a. I didn’t measure the capacity, will need to do more testing to answer the other questions, but I believe the capacity you listed is what I had. I only checked the lumen output between the two at several different voltages ( same voltages for both batteries) and the difference was striking
Banggood should only be selling legit cells. If it looks or measures to be a cell other than the Shockli 5500mah then they may have received some bogus cells. You should let them know along with how you figured it out. They should then send you some genuine cells if they have them in stock or else they may have to wait for a new shipment.
If it appears to be a genuine Shockli, make sure the ends are clean. Any sticky residue or build up can add resistance and FET powered lights are sensitive to that.
Also, how are you measuring the difference in output, just by eye or a lux meter and ceiling bounce? Judging by eye can be deceptive. Ceiling bounce can be more accurate if measured consistently.
Can you measure amp draws? This would tell you a lot right away.
I have built a light box and measuring lumen output with a lux meter in the box. Ceiling bounce would favor throwers tremendously. The contacts appeared clean. I will try to measure amp draws
Are the ShockLi 26650 green or black?
Mine was black
I purchased my black ShockLi from Mountain Electronics LLC in Utah($8.50 ea).
A discharge capacity test of both were well over 6000mAh
My Sofirn 26650 5500mAh just barely makes it to 5500mAh
“I see all their reviews are 5 stars.” — Whenever I submitted a negative review to Banggood, as I did about a seriously-defective Astrolux MF01S they shipped me, Banggood refused to post the review. All the reviews Banggood shows on the MF01S are positive yet I’m certainly not the only person who received a defective MF01S.
Yeah, might be biased.
Ceiling bounce is fine when you are comparing batteries or mods. It’s the same flashlight so the same beam angle. It’s not so great when you start comparing different models of lights. For battery tests it’s okay.
A light box is better and should be consistent enough to test differences in batteries. I would only test fully charged cells. FET lights are known for their inconsistent output, but if you did several tests, that should rule out contact issues in the battery tube and springs. The only variable is the battery and assuming they are the same length, to eliminate differences in the compressed spring height, it should be a pretty accurate test.
Make a note that heat can be a factor. A room temperature light can be brighter than one that’s been heated up. Maybe test the first battery for 10 to 15 seconds so the output has a chance to stabilize a little. Allow it to cool a bit before testing the second battery for the same duration.
If there is a decently large difference in the output then I think it has to be the battery.
Using a clamp meter to measure amp draws is a bit simpler. It eliminates the heat related output differences you get from the led.
Using a Samsung 40T 21700
Turn On - 3700
20 sec - 3500
30 - 3420
That is excellent for no mods. Very close to Sofirn’s rating, I’m very surprised
