Glad you eventually received it.
I did say it is a fair chunck of brass, a lot heavier at 150g versus the zippo’s 55g.
150g weighs about the same as 150g or 5.3oz, so easy to compare
The full ti version with fuel tank which I carry is 109g, I find that a nice weight.
I agree the brass does feel extra heavy.
My brass version sits on the worktop with fuel in it with the standard insert, doesn’t get used much but seems to retain the fuel for months.
Yeah, these are table lighters and not EDC lighters unless you’re used to carrying bricks in your pocket. So far the one I have has held fluid and not dried out.
I had to put another dispute in for the second lighter and the usb arc lighter that I ordered. After I put in the dispute, the same dealer you guys ordered from said I had not received my usb arc lighter because they cannot ship them to the USA. What?
This dealer fought me for a refund but luckily, PP came to my rescue and refunded me. NEVER order from AE unless the store accepts PP!
Even though AE stores offer items you can’t get anywhere else and that is really great and a lot of you have received your items eventually, I’m burnt out about using AE and I’m done with them!
I know, old thread but I wanted to update. I filled the lighter with Ronsonal lighter fuel, (which is quality fuel), about 1 1/2-2 months ago to see if the fuel would evaporate over that time.
I checked it today and not only had the fuel evaporated but the thin rubber gasket which supposedly seals the lid and helps keep the fuel from evaporating had completely disintegrated! Just tiny bits of it remaining and the rest completely gone leaving a somewhat sticky residue behind.
Who would have guessed they would use a rubber or whatever it’s composition is to seal the lid could be attacked and destroyed by lighter fuel, the very thing it’s supposed to contain? Kind of dumb!
It’s still an overbuilt quality lighter and the fuel will last longer than a regular Zippo but don’t expect it to hold fuel for months which is disappointing to me.
There are quite a few other versions, even a lighter weight ti model.
Never seen an alu version though. 7075 would be nice.
I use 0.5mm thick watch gaskets for sealing o-rings, forget the diameter, got a multipack years ago.
A tiny amount of lube helps too for sealing/ longevity prior to installation, like on our lights plus use extra refined fuel.
spyderco
monkey, That’s truly amazing but for $120.00 it SHOULD hold it’s fluid forever! I agree that a aluminum version would be great as my version is too heavy to even consider as an EDC but it was relatively cheap and is built like a tank.
I replaced the original gasket with one of the extras that was included with it and it seems to be holding up but it’s a long way from being proven long term.
CRX, it seems like a good tip on lubing the rubber gasket before installing. What do you use?
All in all, for $20.99, (what I paid), it is how a Zippo should have been and should be built. If they constructed it out of high grade aluminum, it really would be a winner.
Oh yeah CRX, what’s EXTRA refined fuel? Here in the U.S. Ronsonol lighter fluid, (refined naphtha), which has been around forever here is as good as it gets.
Although silicone & petrol don’t mix I’ve just been using a tiny smear of silicone grease for the o-ring.
There is most probably a more suitable grease though.
I believe the o-rings I use are some type of chemical resistant NBR or similar and are a firm neat fit.
I appear to be on my last one though so will need to find more.
My lighter gets used a lot and I do a monthly maintenance clean etc of it as any dirt or debris on the CNC machined seal edges will affect proper sealing closure.
I also use swan extra long flints. I keep two in the flint tube by replacing the brass plunger on the spring with an extra flint plus one tucked into the slot in the bottom of the ti fuel tank.
I say extra refined fuel but that is my judgement after using quite a few brands over the years and not what is printed on the can.
What I judge on is the smell.
Some fuels stink to high heaven with that petro-chemical smell while some others I can hardly notice.
Obviously the least smell coming from the lighter is desirable too.
I don’t know why some fuels smell more than others but assume it is because they are less refined or have extra crap in them/ made from different substances.
Ronson Permafluid is the least smelly I have used probably followed by a cheap brand called atlas.
Ronsonal isn’t too bad. Been a long time but zippo brand & others like that seem to be worse smelling.
There seems to be dfifferent cheap brands in the local shops every time I look with varying differences to them.
The O-rings used in the Titanium War Armor we’re very high quality. Perhaps someone can find a source for them; presumably its a specific grade of rubber designed for petroleum product / naptha resistance:
Thanks for that CRX! I did clean up all the seal edges when I replaced the original O-ring and the replacement went on fairly easily.
spyderco
monkey, quality O-rings with your Titanium War Armor are probably the reason you’ve had such good luck with sealing. The ones that came with my Zorro are definitely lacking. It would be great to find some quality replacements.
The question is, what size O-rings for the case? Once we know that, we can get samples of different 0-rings, and leave them submerged in lighter fluid to see if they are disolved.
You people….You damn people sent me down a damn rabbit hole and now….I have a Zorro 912 - Curved Lid - Polished Brass on its way to my mailbox!
This thread…I swear it almost moved me, I am the proud owner of a very…VERY optimized edc, the thing has been going on for close to 10 years and I am truly running out of things to optimize!
The lighter (I am a smoker) I currectly use is a lovely polished brass armor Zippo whith a nice patina on it and a few dings and dents which I’ve come to love on a brass lighter, but it always felt like a very vanilla choice, it is a Zippo after all.
Anyways this got me going on a hunt for something different, I’ve checked expensive stuff like DuPonts but…MEH…I have a solid silver Dunhill from my Great-grandfather, which is far classier than anything new and if I want to go fancy, a Heriloom is always a solid choice.
I’ve checked cheaper stuff like Douglass lighters and whilst very interesting, they are a tad too much for my tastes as I’ve always been drawn towards more streamlined shapes rather than a Steampunky feel.
And then I see this…A gorgeous Zippo-like lighter, that weights 3 times as much, with a perfectly indexing lid, flush integral hinges and machined from a solid block of brass??
A clear case of “Shut up and take my money!” for me.
I wanted one exactly like CRX’s titanium one but in brass, somehow that curve line on the lid pleases me greatly, and a lot more than a flat one…God only knows why…
The closest one I could find with a curved lid has a hinge setup that’s a little different, CRX’s one is defined by the sellers as a 3-hinge design, I went for the 5-hinge one, I doubt it will make any difference in daily use and I am seriously considering straight up copying CRX and getting a Carson Wararmor in titanium as apparently they are still available from some AE sellers
A bit long I know but this thread was truly a wonderful find for me, many thanks to everyone who posted, you made an obsessive madman happier…And now far more obessed
s. I will give my 2cents review with pictures and wahtever else anyone might like to see, as soon as it arrives, ETA 27 November at the latest, hopefully it’ll get here sooner XD
