I think he mean the FC-40, yes.
LOOOOL
YES!!!!
Thx Rgwn hahahahaha
I would need one 20mm boost driver for the MantaRay C8.2 with a XHP70.2.
One 17mm boost driver would go in a Convoy S2+ with a XHP50.2 and maybe one in a Convoy C8+ with a XHP35.
I would be in for one. If it could be modified for 9V so I could use it on a triple in series I would be in for a second one.
Hm, 9V...damn that sounds interesting...
interested in 2 each of the 17mm and 20mm but that depends on the final price
I would be interested in at least 2 of each, if 22mm came along I would not be unhappy. If you decide to do the fet tail boards, 4 or 5 of them as well.
Always admired Loneoceans’s designs, would like to try one please.
Been thinking about the tailswitch and will likely get a bunch of the boards made, and perhaps a small lot of the pogo programmer boards too, but I will leave it up to everyone to build them. They are not too difficult to assemble and is a good way for those to get used to SMD work
Well if its possible to run in 12V, im assuming this would be possible to modify for 9V also. Loneoceans may be able to provide more details on this.
Interested in two (of each, if you do 20mm).
Since there is alot of interest in the 20mm version, I may as well ask the manufacturer how much more it would cost if they can do half the batch in 20mm, since its the same components, it wont be too difficult for them to do both runs together, but will still be seperate cost for another pcb design, stencils, etc so not too sure what saving there would be at this stage.
Count me in for 4 of the 17mm’s.
Interested in 2 of each… thanks for doing this!
Interested. 1 x 17. 1 x 20.
Changing R13, the 0402 resistor to 120k should give you 9v operation.
Sense resistor R1 would probably need to be changed also to some where in the 15mohm range.
“Though she be but little, she is Fierce”
Interested in 2 of each. Thanks
Interested in 1 17mm and I would likely take a 20mm if you make it.
I’m not clear on what the firmware will be.
Interested in 2x 17mm for now. Will there be firmware options to choose from? Or at least some decent default firmware??
