WTB: Jetbeam RRT01 – Any place to buy it?! + [RRT01 2019 discussion]
Im posting to consolidate some 18650 tube options for the Original RRT-01
a link to the Crelant
here is the link to a convoy S2 host
@Firelight2, That is not correct.
I just bought an Astrolux S41, and its 18650 tube is NOT compatible with an RRT-01. The threads bind, and the light does not work.
RRT-01
Ah crap.
I have an 18650 tube that I thought was from an E14 whose threads perfectly fit the old RRT-01. The threads do not bind and the light functions normally. The tube has too many threads so some are exposed, but a little time with a hacksaw and file would fix that.
I thought the tube was from my E14, but failed to double-check. Must’ve been from a different light. Maybe a BLF A6. I’ll double-check and report back.
I am curious about sourcing a sapphire lens for my Original RRT-01
here are my research notes…
1. Need to verify the size of the Original RRT-01 lens
here are some sites that sell sapphire lenses of various sizes…
source for domed watch lenses this one is glass, not sapphire, $7
18mm x 1mm (does it fit Original RRT-01?)
https://mccawcompany.com/watchparts/crystals/mineral-glass/domed-mineral-glass-flatt-bottom-1mm-thick.html
source for sapphire watch lenses $25
22.5x1.5 could work for HDS/Novatac?:
sapphire lens for $5 for fw3a (how does he do such a low price?)
23x1.5 mm (wonder if it fits HDS/Novatac?)
sapphire lens for hds $51
https://www.hdssystems.com/Products/LensSapphire/
(same as novatac lens 22.61 x 1.9 mm ?)
Novatac lenses need to be 22.61mm x 1,90mm
a source for 22.61 x 2.2 mm UCL, for size reference info… they do not sell sapphire
a useful list of different flashlight lens sizes:
If anyone knows the dimensions of an Original RRT-01 lens, please share (or I will figure it out).
If anyone has experience sourcing a sapphire lens that fits the Original RRT-01, please share….
I am NOT trying to argue the pros and cons of sapphire, vs UCL, vs acrylic… choices are good
sapphire is just bling!
bling is good… lol!
I bought some sapphire lenses on aliexpress, as far as I can check it, they are legit. This store has a good collection. Check if they are flat and the correct thickness, because they are sold as watch christals, some are convex.
thanks for the link and suggestions to avoid domed lenses
I have not actually found any sapphire listings in the 18mm diameter range (intended for original RRT-01), yet
I’m not around a lot anymore, made a lovely career change in my 50’s that’s all encompassing at this point.
Try this fellow for sapphire, if he doesn’t have what you need, he will more than likely recommend a source. I just used his lenses for a NiteCore mod last year, very happy. Be cautious of crystal thickness and also of replacements with rounded edges, you made need o-ring changes, depending on the torch. .005 matters :slight_smile:
Link
Thank you Sir!
that link includes this size:
18.5 x 1 mm for $8, that may be in the ballpark for the RRT-01.
(need to confirm the lens dimension…)
and thanks for the 0.13 mm tolerance ( 0.005) relevance, advance warning about rounded edges, and potential replacement O ring awareness
all very helpful
visualizing
a Sapphire lens :wink:
and tritiums
Jon can you check the size of Eye10/15? If they are the same as rrt01 then just give a call to Fanny.
She sent me one spare for eye15 for few bucks
yes, I just have to decide which Eye10 or RRT-01 to open, when Im in there for other tasks like ring lube and LED swap…
thanks for the suggestion to ask Fanny for a replacement lens…
My lenses are actually fine
Im researching Sapphire lenses… that cost $51 for an HDS,
or $5 for an FW3a (I think this is more in my ballpark… lol)
thanks to Archibald Tuttle, I think it may get done for $8 for an RRT-01…
RRT-01 LENS
thank you very much for the help
1.62 x 20 on your pics
1.5 x 20 on ebay
the 0.12 thinner sapphire, should work well with the slightly taller kaidomain reflectors we are using in the Original RRT-01 mods…
time to put my money where my mouth is…
will report back after I try one of those sapphire lenses
thank you all for the sleuthing
:+1:
That’s exactly what I was thinking.
I shared that suggestion with someone, but it did not work out as expected… I dont know why, I have not tried the Crelant myself…
they reported
Crelant 7G3CS arrived today. It does NOT fit the JetBeam RRT-01 as I had hoped. I put an 18650 battery in it and it has two speeds, 1226 lumens and 350 lumens … Note that the Crelant 7G3CS tube threads are slightly different than the RRT-01 and will not engage in the JetBeam’s head
any solution I can pass on would be appreciated
Edit
it is possible the mismatch Im hearing about was between the head of a NEW 2019 RRT-01 and the Crelant. imo Archibald Tuttle knows what hes talking about. In no way do I doubt his recommendation that a Crelant 18650 tube fits an ORIGINAL RRT-01
Some tubes working on the old RRT01s (even if not perfectly…)
SOFIRN SP32 / SP32A
CONVOY S2+
ACEBEAM TK16 (can only be used for momentary ON, due to the e-switch it uses)
This thread really needs to become a sticky. Sincere thanks to everyone who contributed.
Late last year, I lost my Nitecore D10 to American Airlines, and began using a long stored JB TCR1 as EDC.
The adjustment ring on the TCR1 was just pure trash. I almost treated it as such, and nearly binned it.
Some BLF knowledge and some Nyogel ( it had no grease, none) turned the TCR1 into a world class flashlight.
It’s hard, for me, to go back to another EDC interface after using the dimmer type dial.
A stock BLF Q8, modded Thrunite TH20 & modded JB TCR1 are a extremely versatile trio. :+1:
Very sorry for your loss of a D10, really happy for you to have a TCR-1 to enjoy.
When I got my TCR-1 the dial was not smooth, it took a lot of massage and lubricant to get it to feel buttery smooth (without disassembly).
Some of my RRT-01 were also not smooth, but after disassembly and lubricating with Nyogel 767a they became a joy to use.
The feel of a smooth the ring with no grittyness, nor excessively easy to turn, transforms the experience from apparent low quality, to feeling like a High Quality instrument.
The convenience of operation of the Jetbeam Rotaries have spoiled me. I still use a couple clicky lights (one set to 0.02 lumens for bathroom visits, and one that turns on at 20 lumens for brief illumination needs on my desk, but I have greatly slowed my accumulation of lights with buttons.
For me, the RRT-01 has been a game changer… not sure why, but I seem to have accumulated more than one… lol!
I agree this thread is full of a wealth of info. Thanks to all who participate and contribute.
Thanks, and more thanks, you have helped make this a one stop shop for JB rotary info. This is a easy, intuitive, and depending on one’s age, very familiar UI.
I spent a lot of years with the D10, but perhaps the loss was for the best. It wasn’t hard to overshoot a desired level with the D10 , due to ramping speed. And at it’s lowest level, on a minimal battery charge, the PWM was easily seen.
The clip was broken off of this TCR1, I still have to deal with drilling out the sheared machine screws and tapping new threads. I’ve got a original, McGizmo clip to fit. Then it’s on to led selection. I like so many different emitters and kelvins, it’s gonna be hard to find a middle of the road emitter and matching reflector.
Such a cool design, cant help but think of Spinal Tap :wink:
there are links in this thread to consolidate the reflector options that moderator007 researched for us
they work with the 219b options I enjoy
my personal general purpose grail is the sw45k and that link also lists a source for those
along with other parts useful in a TCR-1, including an XP compatible mcpcb, the driver that has a Strobe option, and a shorter clip. (though I respect your choice of a McGizmo option)
(I was not in USA in my youth, and missed the Spinal Tap experience. Thanks for supporting and contributing to this Stepless Rotary conversation. :slight_smile: )
