Anduril has a panic mode where it drops from turbo to a more sane level once a threshold is crossed. It could be that. I remember TK saying something about it being hard to deal without how fast small lights heat up initially, although I thought it was disabled in the D4s builds because TK found it wasn’t needed in heavier lights.
I recall seeing a variable called something like “therm_faster” and thinking it was probably related, but I never looked closely at those sections of code. Is it possible something related to that feature is active in your code?
Thanks. I have such text, but due to poor translation it is not possible to adjust the color of additional diodes. I do 7 clicks and a delay on the last one, but the LEDs no turn on. When pressed 7 times (without holding) it turns on, but I can’t change the color.
Is it possible to set the high mode (constantly) of additional diodes when turned on (by pressing 7 times)? Now, to turn on in high mode, you need to start low
There are 2 separate settings to contemplate. The first is the Aux LED state (off, low, high, flashing) and this is changed with 7 clicks. The second setting is the color. This is accomplished with 7 clicks but hold on the 7th. The aux leds must not be in the “off” state to change the color. They must be on low, high or flashing.
First thing you should do is get the aux LEDs in the “high” state. From there, you will press 7 times and hold on the 7th and then keep holding until the color you desire is reached. There are 2 color settings where the leds are changing colors one of which will have it just cycle the colors, the other is a battery check mode and will change with the battery charge level.
“…The aux leds must not be in the “off” state to change the color. They must be on low, high or flashing. …”
Many thanks. Fulfilled this requirement and the opportunity to replace the color
Well, this thread has caused me to order one in cyan (I’m a sucker for blue and this is my first non-black/grey light). I’ve got a Rofis MR70 as my EDC light for work, not sure if this will replace it or become a “household use” light. Looks too nice to get it all dinged up. Now I have 2 lights I’m waiting for (BLF GT90 is the other )
I ordered this flashlight from Hank and got it in record time (12 days) very pleased with the build quality. I ordered my batteries from someone sees and they are at least 14 days away…Any other recommendations on 26650 batt? I ordered the Liitokala 5000mah 50A. I was looking at some keep power 5200/15A, will these be sufficient? I will order these in a 24h in home service because I want to play with this light and don’t want to wait 14 days till the Liitokala’s arrive……Any other recommendations? What would the minimum maH be and the minimum Amperage?
Where were you able to find Shocklis in Europe? I’ve been looking around forever, to no avail. Nkon doesn’t have them.
According to HKJ’s tests 5500 Shockli are hugely better than the much praised cyan liitokalas. Much higher capacity and higher current too.
In another thread, one of the gurus said the D4S XP-L Hi draws 13 amps on turbo. So I just use a Shockli 5500 battery and it seems to do fine -even though I abuse turbo regularly. The cell under the wrap is the PLB-55A and it was in other brands like Keepower and Vapcell. Someone said PLB stopped making that cell. But any high capacity battery rated for 15 or 20 amps will be fine and will provide a longer runtime than a high drain cell.
the best is using as high capacity as possible… im using in my d4s efest 4500mah high drain because at the time there wasnt any other batteries with similar capacity, if i was to buy today extra i would get some keeppower 5000mah or similar.
